All EK aluminum rig Getting very high temps on both cpu and gpu. Help me fix my first system - Overclock.net - An Overclocking Community
post #1 of 85 (permalink) Old 07-29-2019, 04:41 AM - Thread Starter
Rep: 1 (Unique: 1)
I recently got this and the temps are causing the gpu to throttle as it’s hitting 80c during gaming. Idle temps are mid 30s for both but soon as I ramp up they both hit 80c but pretty much stay there. Any idea what’s causing these high temps?
I7-8700k @ 4.9 ghz 1.33 volts
Evga black 2080 , no oc.
All ek aluminum parts. Parts below
COOLING: EK-FG PC-011 Distribution Plate EK-FG Velocity AX Intel 115X – Plexi EK-AC GeForce RTX EK-Vardar S 120ER D-RGB EK-HDC ALU Fitting 12mm – NICKEL EK-Alustream SE 360 Lite (Triple)
Distilled water
Slickdall is offline
post #2 of 85 (permalink) Old 07-29-2019, 04:56 AM
SubZero is the Goal
HardheadedMurphy's Avatar
Rep: 73 (Unique: 63)
Assuming the flow rate is optimal, is there good contact between blocks and processing units?
Sent from my GM1915 using Tapatalk
"It is impossible to defeat an ignorant man in an argument" McAdoo
Peace begins when we care about someone other than ourselves.
"Hell is still Overburdened, I must stand and wait in line" Disturbed
The Beast
(23 items)
MiniFurnace
(10 items)
ThinClient
(5 items)
i5-9600k
ASRock Z390 Taichi
EVGA GeForce GTX 1080 FTW Hydro Copper GAMING, 08G-P4-6299-KR, 8GB GDDR5X, LED, DX12 OSD Support (PXOC)
EVGA GeForce GTX 970 04G-P4-2974-KR 4GB SC GAMING w/ACX 2.0, Silent Cooling Graphics Card
Corsair Vengence RGB Pro
Mushkin Enhanced Source M.2 2280
Toshiba
Optical Drive
LG Bluray RW
Rosewill Quark
Barrow RGB 115X CPU Block
EK-360 Radiator
Phobya 12v DC PWM Pump
Black Ice Nemisis 240mm stealth Rad
Alphacool 5.25 pump / resivoir combo DC-LT
Phobya Balancer 250mm Res - Black Nickle
Corsair Obsidian 900D
Operating System
Windows 7 Professional
LG 34" Ultrawide IPS 21:9
HP 27xw ips
HP 27xw IPS
Keyboard
Corsair Strafe RGB MX Silent
Mouse
Corsair M65 Pro RGB
Audio
Corsair Void Pro RGB
Xeon 5300
Xeon 5300
Dell 2950 v3 Server
ECC DDR2 RAM
Hitachi 1tb 7200rpm
Optical Drive
SLIM DVD-RW
redundant 750w
OEM
Operating System
Windows Server R2
Other
DRAC 6/i
Celeron N2930
G.Skill 8gb 204 pin
Seagate 500gb 2.5"
Zotac Zbox CI320 Nano
Operating System
Win 10 Pro
HardheadedMurphy is offline
post #3 of 85 (permalink) Old 07-29-2019, 05:15 AM - Thread Starter
Rep: 1 (Unique: 1)
That’s my next step but not really sure how to drain the loop.
But 2 different people did the blocks, I did the cpu and the person who helped me with the tubing did the gpu. But let’s assume that’s okay since the idle temps are good. Any other idea? Would bad fitment cause idles to be fine but load temps to soar?
post #4 of 85 (permalink) Old 07-29-2019, 05:25 AM
Overclocker in training
ThrashZone's Avatar
Rep: 65 (Unique: 51)
Hi,
Which fluid did you use ?
What's the top speed for the pump that sure doesn't look like a D5.
EK premix I hope not
i9-9940x With Heatkiller IV Pro Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #5 of 85 (permalink) Old 07-29-2019, 05:30 AM
SubZero is the Goal
Always add a drain port.
I forgot once and was eaten alive by mosquitos draining it into the dirt outside...
The Beast
(23 items)
MiniFurnace
(10 items)
ThinClient
(5 items)
i5-9600k
ASRock Z390 Taichi
Toshiba
Optical Drive
LG Bluray RW
Rosewill Quark
EK-360 Radiator
Operating System
HP 27xw ips
HP 27xw IPS
Keyboard
Mouse
Corsair M65 Pro RGB
Audio
Xeon 5300
Xeon 5300
Dell 2950 v3 Server
ECC DDR2 RAM
Hitachi 1tb 7200rpm
Optical Drive
SLIM DVD-RW
redundant 750w
OEM
Operating System
Windows Server R2
Other
DRAC 6/i
Celeron N2930
G.Skill 8gb 204 pin
Seagate 500gb 2.5"
Operating System
Win 10 Pro
post #6 of 85 (permalink) Old 07-29-2019, 05:36 AM - Thread Starter
Rep: 1 (Unique: 1)
[QUOTE=ThrashZone;28064298]Hi,
Just using distilled water.
It’s a sedna pump.
S1 Pump Spec.
Rated voltage:12V DC
Power consumption:17W
Maximum flow:960L/h
post #7 of 85 (permalink) Old 07-29-2019, 05:41 AM - Thread Starter
Rep: 1 (Unique: 1)
Agreed. I’m going to do that next time I get it drained.
post #8 of 85 (permalink) Old 07-29-2019, 05:47 AM
ThrashZone's Avatar
Hi,
Disconnect the pwm cable and it will at least run at full speed see if that does anything positive.
Which radiator did you use SE/ CE/ PE/ XE series ?
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #9 of 85 (permalink) Old 07-29-2019, 05:49 AM - Thread Starter
Rep: 1 (Unique: 1)
Quote: Originally Posted by ThrashZone View Post
Hi,
Okay, I can try that
SE
post #10 of 85 (permalink) Old 07-29-2019, 05:57 AM
SubZero is the Goal
Slip it in at the lowest point.
The Beast
(23 items)
MiniFurnace
(10 items)
ThinClient
(5 items)
i5-9600k
ASRock Z390 Taichi
Toshiba
Optical Drive
LG Bluray RW
Rosewill Quark
EK-360 Radiator
Operating System
HP 27xw ips
HP 27xw IPS
Keyboard
Mouse
Corsair M65 Pro RGB
Audio
Xeon 5300
Xeon 5300
Dell 2950 v3 Server
ECC DDR2 RAM
Hitachi 1tb 7200rpm
Optical Drive
SLIM DVD-RW
redundant 750w
OEM
Operating System
Windows Server R2
Other
DRAC 6/i
Celeron N2930
G.Skill 8gb 204 pin
Seagate 500gb 2.5"
Operating System
Win 10 Pro
