What's acceptable for water temperature? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 43 (permalink) Old 07-31-2019, 10:19 PM
Iwamotto Tetsuz's Avatar
Rep: 76 (Unique: 52)
Typically 15-25C rise above ambient for a medium low range setup
Typically 5-10C Rise above ambien for a high end setup (3x 360mm doubble standard thickness alloy rad with fans running on low speed Soundless devil build I own)
Typically -5 to 5C diffrence between ambient for peltier cooling the water or warter chiller setup
Hot tubes isn't a concern if they don't bend and block them selvs up reducing the flow
But is a issue if they got so hot and start leaking, though should be rare
My tubes very cheap ones do soften over time even if it is not exposed to temps more than 40C
If you want rock solid operation you can by the springs plastic ones to help it prevent bending, possible for sale on aliexpress.
Also buying the expensive tubing will have high flexibiily relibality and not block flow when bent.
Even better is to route the stuff using combo of straight and 90 degree fittings to get it straight
You can buy 90 degree pices which connect 8mm to 8mm tubing or 10mm to 10mm tubing.
EDIT:
Temps are from my exprience and these are assuming your fully loading the system up using prime testing.
Also running the fans at medium to low speeds
Overcloking is about the passion, not about how much you clock
Overclocking is not about the pefromance gains, it is about the passion
Overclocking is about the Fun, Enjoyment and Passion
Pushing Voltages And Lower Tempertures Makes You The Overclocking Champion
Iwamotto Tetsuz is offline
post #12 of 43 (permalink) Old 07-31-2019, 11:18 PM
Robotic Chemist
Asmodian's Avatar
Rep: 202 (Unique: 134)
Quote: Originally Posted by Moose-Tech View Post
With the ambient temp your AQ6 could control your fan curves and even your pump speed off the Delta (difference) of your ambient and your loop.
Under Virtual Temperature Sensors you would create an "Absolute temperature difference" sensor based on your Loop water temp (Sensor 1) and Ambient (Sensor 2).
Wow! That really makes me want an AQ6! Time to go shopping.
Good advice. That is a feature I have wanted for years, since I got my first 4x140 radiator and realized that all available methods of fan speed control resulted in too slow when gaming in a cold room and/or too fast when idle in a hot room.
"Soldering resistors onto your video card to bypass the manufacturers over current protection kind-of sort-of absolute-definitely voids your warranty"
Desktop
(17 items)
AMD Ryzen 3950X
Asus Crosshair VIII Hero
Nvidia 2080 Ti
32GB DDR4 3600
Intel 900P
Samsung 960 Pro
Optical Drive
Asus BW-16D1HT
Seasonic 1200W
EK Velocity + EK GPU Block
Old Marble Slab
Operating System
Windows 10 Pro
LG C9 55"
Keyboard
Wooting two
Mouse
Logitech G903 Lightspeed
Mousepad
Logitech G PowerPlay
Audio
Arctis Pro Wireless
Other
Mellanox 40GbE
Asmodian is offline
post #13 of 43 (permalink) Old 08-01-2019, 12:43 AM
broodro0ster's Avatar
Rep: 9 (Unique: 8)
I have a 1080TI and 8700k and they are cooled by 2x GTS360's. Both are OC'ed.
My watertemp is 8°C over ambient, which is usually 33-34°C with the fans at 1150rpm in AAA games. Heaven is pretty lightweight in terms of heat output because it doesn't make the CPU work hard.
That VEGA64 is probably dumping a lot of heat into the loop. And something that helped for me, was switching to intake on all my rads instead of intake/exhaust.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #14 of 43 (permalink) Old 08-01-2019, 02:57 AM - Thread Starter
Goooober's Avatar
Rep: 1 (Unique: 1)
Thanks for the advice everyone i really appreciate it. I'll have a go setting up my AQ6 to use the Delta for the fan curves.
Goooober is offline
post #15 of 43 (permalink) Old 08-01-2019, 03:21 AM
Rep: 9 (Unique: 8)
That's how I have mine setup. And I don't setup a fan curve, I just set a prefered delta temperature and the Aquaero will detect how fast the fans needs to spin.
I have setup a 8°C delta target and my fans spins at 400rpm (fans can't go slower) during idle for a 6-7° delta T. When I launch a game, my watertemp will start rising and once it's hitting around 8°C, the fans start to ramp up. When playing an AAA game, the fan speed settles around 1150rpm. When playing CSGO, the fans spin at 750rpm for the same delta. So the fans will only spin fast enough to keep my water delta where I want it.
And if you want to raise or lower the fanspeed, just set your target 1°C higher or lower and see where it brings you.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
EK D5 PWM
Operating System
Windows Pro 10
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Audio
post #16 of 43 (permalink) Old 08-01-2019, 04:09 AM
Manual breath enabled
Streetdragon's Avatar
Rep: 28 (Unique: 23)
the "prefered delta" setting is crap and wont really work for me. Set the temp to 4°(example) and it will speed up the fans till 100% at the end and that will trigger the overcurrent protection(8 fans on a header)(4 on another header)
I like the curve setting more. But thats only my oldschool taste xD
Cube
(16 items)
Ryzen 3900X
Aorus X570 Master
1080 TI Founders Edition
F4-3600C16Q-32GTZR
2000GB Seagate Barracuda Compute ST2000DM008 256MB
samsung m2 970 evo
Leadex 80 Plus Platinum Netzteil, schwarz - 1200 Watt
heatkiller IV pro
EK-FC1080 GTX Ti - Nickel
Alphacool Eisbecher D5 250mm Plexi
Alphacool NexXxoS XT45 Full Copper 480mm
XSPC Multiport Radiator EX240
Scythe Grand Flex 4Pin PWM
thermaltake core x9
Operating System
Windows 10
Streetdragon is offline
post #17 of 43 (permalink) Old 08-01-2019, 05:04 AM
Thingamajig's Avatar
Rep: 138 (Unique: 122)
I get about a 11 degree difference from water temps and ambient in my custom loop but it's all contained within a very small ITX machine. So i think the figures others have stated is rather accurate.
Umbra
(10 items)
i7 7700K
ASUS ROG Strix z270i ITX
Zotac 1070 Mini
Corsair Vengeance LPX (2x8GB) DDR4
2x 2TB Seagate Guardian Barracuda 2.5"
M.2 Western Digital Black 256GB
Optical Drive
Panasonic UJ-265 SATA Slot Blu-ray Writer
700w Silverstone SST-SX700-LPT SFX
Heatkiller v3 CPU Block
Cougar QBX Mini
Thingamajig is offline
post #18 of 43 (permalink) Old 08-01-2019, 05:17 AM
Rep: 459 (Unique: 390)
In my experience the pump usually has the lowest max safe operating temp out of all the components, for the old D5 (non PWM) it was 50C. As long as your water is below the max safe temp of your components then no need to worry.
Darren9 is offline
post #19 of 43 (permalink) Old 08-05-2019, 05:59 AM
Rep: 9 (Unique: 8)
Strange, I have 6 fans on 1 header and I'm not having any issues. The AQ6 can handle a lot on a single header.
And you could also setup a max fan speed in the settings so they don't trigger the overcurrent protection.
I didn't like the curve because it constantly change the fan speeds and that's annoying to hear. With my target controller, it adapts the fan speeds slowly if the loads are changing and if there is no load difference, it keeps the fan speed very constant. You can have some overshoot when starting a game, but nothing too bad.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
EK D5 PWM
Operating System
Windows Pro 10
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Audio
post #20 of 43 (permalink) Old 08-05-2019, 06:14 AM
Overclocker in training
ThrashZone's Avatar
Rep: 189 (Unique: 114)
Hi,
Not sure how the hint was missed this op doesn't even know what temperature the room is where he/ she is sitting
Hard to take this thread seriously
i9-9940x With Optimus SigV2 and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Trident Z 3600C16 4x8gb's b-die default timings 16-16-16-36 F4-3600C16Q-32GTZKK
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
10900k batch # X016E724 with Optimus Foundation water block
z490 ASUS Maximus XII Apex
Trident-Z 3600c16 4x8gb kit 16-16-16-36 F4-3600C16Q-32GTZSW
Samsung 970 evo 500gb
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
D5 reservior combo/ 240GTX/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Audio
ThrashZone is online now
