What's acceptable for water temperature? - Page 3 - Overclock.net - An Overclocking Community
post #21 of 43 (permalink) Old 08-05-2019, 06:26 AM
Manual breath enabled
Streetdragon's Avatar
Rep: 28 (Unique: 23)
Quote: Originally Posted by broodro0ster View Post
Strange, I have 6 fans on 1 header and I'm not having any issues. The AQ6 can handle a lot on a single header.
And you could also setup a max fan speed in the settings so they don't trigger the overcurrent protection.
I didn't like the curve because it constantly change the fan speeds and that's annoying to hear. With my target controller, it adapts the fan speeds slowly if the loads are changing and if there is no load difference, it keeps the fan speed very constant. You can have some overshoot when starting a game, but nothing too bad.
Yeah maybe it was a PWM problem.
Changed the header settings so it controles the fans via voltage. now its working fine. Only thing is that my aquaero is dying somehow. but thats is another topic^^(already emailed support)
Cube
(16 items)
Ryzen 3900X
Aorus X570 Master
1080 TI Founders Edition
F4-3600C16Q-32GTZR
2000GB Seagate Barracuda Compute ST2000DM008 256MB
samsung m2 970 evo
Leadex 80 Plus Platinum Netzteil, schwarz - 1200 Watt
heatkiller IV pro
EK-FC1080 GTX Ti - Nickel
Alphacool Eisbecher D5 250mm Plexi
Alphacool NexXxoS XT45 Full Copper 480mm
XSPC Multiport Radiator EX240
Scythe Grand Flex 4Pin PWM
thermaltake core x9
Operating System
Windows 10
Streetdragon is offline
post #22 of 43 (permalink) Old 08-05-2019, 06:33 AM - Thread Starter
Goooober's Avatar
Rep: 1 (Unique: 1)
Quote: Originally Posted by ThrashZone View Post
Hi,
Not sure how the hint was missed this op doesn't even know what temperature the room is where he/ she is sitting
Hard to take this thread seriously
Hard not to think you're patronising smug prick.
Goooober is offline
post #23 of 43 (permalink) Old 08-05-2019, 07:02 AM
Overclocker in training
ThrashZone's Avatar
Rep: 189 (Unique: 114)
Hi,
Doesn't help on page 1 you ignored three request for room temperature or said I don't know
Clearly nobody past that bothered to read follow up questions which again you didn't know lol but I'm the prick
i9-9940x With Optimus SigV2 and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Trident Z 3600C16 4x8gb's b-die default timings 16-16-16-36 F4-3600C16Q-32GTZKK
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
10900k batch # X016E724 with Optimus Foundation water block
z490 ASUS Maximus XII Apex
Trident-Z 3600c16 4x8gb kit 16-16-16-36 F4-3600C16Q-32GTZSW
Samsung 970 evo 500gb
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
D5 reservior combo/ 240GTX/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Audio
ThrashZone is offline
post #24 of 43 (permalink) Old 08-05-2019, 08:36 AM
warpuck's Avatar
Rep: 23 (Unique: 19)
Most motherboards have have temp sensors on them my Chrosshair has 5. One of them a board sensor at idle it reads almost 10-20 C lower than the others. So by my best guess my current best guess would be 28C inside the case with 30C recorded. The highest temp on the CH6 is the chipset at 49C.
This is a pretty good guess because when I was doing WC and had a thermo-couple inside the case. With enough air flow into the radiators the coolant temps out of the radiator should not be more than 1 degree higher internal air temperature. That is if the radiators are large enough. If the water temp out of the CPU had more than 2-3 C above radiator out, the water block is clogged, needs thermal paste or just inadequate. I do not think there are many available that not capable. Any block capable of cooling a OC FX-9950 is more than what is needed.
My last WC was a FX-9950 with two OC'd WC RX-380s. A 25mm x 140mm raditator and a 280mm x 40mm radiator with push/ pull fans, case mounted. That is about 800-900 watts load at 100% for GPUs + CPU powered by a 1100 watt supply.
Now I just use a air cooled Ryzen and a air cooled GTX 690 an a 700 watt supply.
Pretty much good enough for who it is for.
Water moving slow through radiators transfers the maximum amount of heat to the air. Water moving quickly enough through the water block removes the maximum amount of heat from the CPU.
Primary: Crossover 27" 2560 x 1440, Crosshair VI, Ryzen 1600, Flair 3200 x 4, GTX 690. Secondary: MSI 890FX GD-70 R 2.0, FX-8350, HD 7790, Kingston 8 GB x 2, Western 1Tb hybrid, VisionTek 1000
warpuck is offline
post #25 of 43 (permalink) Old 08-10-2019, 11:22 AM
Robotic Chemist
Asmodian's Avatar
Rep: 202 (Unique: 134)
This is not a good way to think about it. You want the water moving quickly through both for maximum energy transfer. Slow in the radiator means it starts to cool down and colder water will transfer less heat to the air, so the longer the water stays in the radiator the less effective the radiator is. This will cause your water to rise to a higher temperature at steady state. It is not intuitive but ideally the water would be moving so fast we do not see a temperature increase in the CPU block or a decrease in the radiator. In reality we do see a tiny temperature increase and decrease but they should be very minor, <2°C in any decent loop.
"Soldering resistors onto your video card to bypass the manufacturers over current protection kind-of sort-of absolute-definitely voids your warranty"
Desktop
(17 items)
AMD Ryzen 3950X
Asus Crosshair VIII Hero
Nvidia 2080 Ti
32GB DDR4 3600
Intel 900P
Samsung 960 Pro
Optical Drive
Asus BW-16D1HT
Seasonic 1200W
EK Velocity + EK GPU Block
Old Marble Slab
Operating System
Windows 10 Pro
LG C9 55"
Keyboard
Wooting two
Mouse
Logitech G903 Lightspeed
Mousepad
Logitech G PowerPlay
Audio
Arctis Pro Wireless
Other
Mellanox 40GbE
Asmodian is online now
post #26 of 43 (permalink) Old 08-10-2019, 12:41 PM
WaterCooler & Overclocker
Barefooter's Avatar
Rep: 125 (Unique: 102)
Quote: Originally Posted by Asmodian View Post
Wow! That really makes me want an AQ6! Time to go shopping.
Good advice. That is a feature I have wanted for years, since I got my first 4x140 radiator and realized that all available methods of fan speed control resulted in too slow when gaming in a cold room and/or too fast when idle in a hot room.
Quote: Originally Posted by Goooober View Post
Thanks for the advice everyone i really appreciate it. I'll have a go setting up my AQ6 to use the Delta for the fan curves.
I put together a guide that will walk you through exactly how to set up fan curves with an air/water virtual temperature sensor. Just click on the link in my signature
Devastator
(14 items)
Secondary Rig
i9-7900X
Asus Rampage Extreme VI
2x EVGA 2080Ti XC Gaming
G.Skill TridentZ Royal 32GB 3600 16-16-16-36
Intel Optane SSD 480GB
Samsung 850 EVO 2TB
2x Seagate Iron Wolf Pro 12TB
EVGA SuperNOVA 1600 T2
Hardware Labs Black Ice SR2 Radiators 4x 560mm + 2x 280mm
Aquacomputer Aquaero XT + Aquaero LT
2x Aquacomputer D5s with custom chrome plated Bitspower mod kits
2x Aquacomputer Aqualis 880ml Reservoirs with Nano Coating & Aquabus Interface
CaseLabs THW10 with Custom Powder Coating
Operating System
Windows 10 Pro
Intel Core i7-4790K
Asus Maximus Extreme VI
EVGA GTX 980 ti Classified
G.SKILL Trident X Series 32GB (4 x 8GB) DDR3 2400
Samsung 850 Pro 500GB
Seagate Desktop HDD 4TB
EVGA SuperNOVA 1300 G2
EK 420 Rad + EK 280 Rad
Corsair 750D
Operating System
Microsoft Windows 10 Pro 64-bit
Acer XB271HU
Keyboard
Microsofte Natural Ergonomic 4000
Mouse
Logitech G502
Barefooter is offline
post #27 of 43 (permalink) Old 08-10-2019, 01:27 PM
Robotic Chemist
Asmodian's Avatar
Sweet, thanks! My AQ6 should be here very soon so I will try it in the near future.
Desktop
(17 items)
AMD Ryzen 3950X
Nvidia 2080 Ti
32GB DDR4 3600
Intel 900P
Samsung 960 Pro
Optical Drive
Asus BW-16D1HT
Seasonic 1200W
Old Marble Slab
Operating System
Windows 10 Pro
LG C9 55"
Keyboard
Wooting two
Mouse
Mousepad
Audio
Arctis Pro Wireless
Other
Mellanox 40GbE
post #28 of 43 (permalink) Old 08-10-2019, 01:40 PM
jtom320's Avatar
Rep: 128 (Unique: 109)
Your temps sound perfectly reasonable to me.
I find the GPU a better indicator of loop "health" then CPU temperatures. CPU's since they've gotten small are pretty random.
I probably would have done my first non water build in a long time if I had known Ryzen was going to behave the way it does going into it.
Nvidia Sparse Grid Supersampling guide.
Ryzen 3000
(17 items)
R9 3900x
Gigabyte Master
GTX 1080
32gb DDR4 3433 CL16
Samsung 950 Pro 256gb
Samsung 850 Evo 512gb
Seasonic Focus Plus 850 Gold
HeatKiller IV AM4
EK 1080 FE GPU Block
Black Ice 360mm SR2
Black Ice Nemesis 360mm
Aquacomputer Aqualis Fountain Thing
D5 Vario
PETG
Fractal S2
Operating System
Win 10
6700k (EK Supremacy Evo) *4.7 @ 1.312
Asus Maximus VIII gene
GTX 1080 FE (EK nickel/plexi)* 2075/5401
16gb Corsair 3200
Samsung 950pro M.2 256gb
Samsung 850 Evo - 512 - Steam
Samsung 850 Evo - 512 - Other Apps
EVGA 650
EK Res
EK pump top
XSPC EX 360
XSPC EX 240
Fractal Arc Mini 2
Operating System
10
Keyboard
Ducky Shine 3 TKL
Mouse
G303
jtom320 is offline
post #29 of 43 (permalink) Old 08-10-2019, 02:52 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1460 (Unique: 735)
Hi,
How is ambient temp relevant to maximum safe water temperature?
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(9 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
WD Blue 4TB SSD
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate
Audio
Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Keyboard
Dierya DK63 60% (Outemu Blue)
Mouse
Logitech G603
The Pook is online now
post #30 of 43 (permalink) Old 08-10-2019, 03:10 PM
Robotic Chemist
Asmodian's Avatar
Good point, I would consider 50°C to be a maximum safe water temperature, so there is a little buffer before things really go bad fast (~60°C). Knowing ambient is important for understanding the loop but the true max safe temperature does not change. If your ambient is really high is is important to have more/better radiators to be able to keep your water below ~50°C.
Desktop
(17 items)
AMD Ryzen 3950X
Nvidia 2080 Ti
32GB DDR4 3600
Intel 900P
Samsung 960 Pro
Optical Drive
Asus BW-16D1HT
Seasonic 1200W
Old Marble Slab
Operating System
Windows 10 Pro
LG C9 55"
Keyboard
Wooting two
Mouse
Mousepad
Audio
Arctis Pro Wireless
Other
Mellanox 40GbE
