What's acceptable for water temperature? - Page 4 - Overclock.net - An Overclocking Community
post #31 of 43 (permalink) Old 08-10-2019, 03:25 PM
Vermin Supreme 2020
skupples's Avatar
Rep: 737 (Unique: 388)
Quote: Originally Posted by The Pook View Post
How is ambient temp relevant to maximum safe water temperature?
true, but the query was properly answered, as asked.
a few degrees above ambient + the advise of actual safe max = if its 50+ you need more radiators, or to go back to air coolers.
Add me on Steam, same name
skupples is offline
post #32 of 43 (permalink) Old 08-10-2019, 05:09 PM
zGunBLADEz's Avatar
Rep: 105 (Unique: 76)
I will start considering over 50c worrysome
And anything under 10c over ambient good performance.
1-5 top notch loop no better than that on air ambient cooling
zGunBLADEz is offline
post #33 of 43 (permalink) Old 08-14-2019, 09:17 PM
Moose-Tech's Avatar
Rep: 9 (Unique: 9)
Personally, I would consider anything under 10c great cooling. (Trying to get there myself)
Under 15c is good cooling, which is where i am running now.
Under 5c is REAL enthusiast stuff.
1c to 2c is basically ambient. JaysTwoCents did it:
I think the title says a lot. It's insane.
Build: Z390 ACE
Core i9-9900K OC 5 GHz, MSI Z390 ACE Mobo, AMD Radeon VII GPU OC 2K MHz
Corsair Vengeance RGB 32GB 3200 RAM, Phanteks Enthoo Pro M SE.
EKWB Z390 ACE Monoblock, Bykski Radeon VII GPU w/b, 2x EKWB 140 Revo D5 Pump & Res.
Aquacomputer Aquaero 6 LT USB Fan-Controller, Quadro, Vision Touch and 'High Flow' Sensor.
(2x) HWL Black Ice Nemesis 280 GTS XFLOW and (1x) Alphacool XT45 X-Flow 280 radiators.
Moose-Tech is offline
post #34 of 43 (permalink) Old 08-15-2019, 01:59 AM
Shawnb99's Avatar
Rep: 66 (Unique: 47)
On idle I’m about 3 degrees over ambient and under load I’m around 8-10 degrees over.
Even with these temps I’d debating adding a Mo Ra3 420 pro.
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is online now
post #35 of 43 (permalink) Old 08-15-2019, 06:27 AM
zGunBLADEz's Avatar
1c to 2c is basically ambient. JaysTwoCents did it: https://www.youtube.com/watch?v=Q2SIrV_4-dM
this is what happens when i open the window on chicago with a MoRa 3 XD
post #36 of 43 (permalink) Old 08-15-2019, 07:20 AM
Vermin Supreme 2020
skupples's Avatar
if that's your video, disable SLI it's not actually working. it's just splitting the load between two cards, which introduces latency & random load spikes.
skupples is offline
post #37 of 43 (permalink) Old 08-15-2019, 08:04 AM
zGunBLADEz's Avatar
it is working perfectly fine i hard cap to 60 (4k 65'HDTV) and frame-pacing its taked care off with rivaturner this is a must if you dual gpu .. been doing it for ages XD
those stutters are related to utube XD i guess 1440P/60 nvidia highest mbit straight streaming act like it
1080ti dont do 60 including 1%s on 4k everything maxed neither the 2080ti manually maxed settings on that title specially capped @ 1800MHz
post #38 of 43 (permalink) Old 08-15-2019, 08:35 AM
Vermin Supreme 2020
skupples's Avatar
so if you take V-sync off, you get 99% on both cards?
which drivers are you on, n are you loading up the inspector profile?
I didn't see any stuttering, all I did was watch your GUI read-out, noticed it being quite similar to mine in Shadow, which results in much smoother game play on a single GPU, 1440p ultra.
I haven't had much luck @ 4K either perf is identical single card, or dual card. for me at least.
your response will help me dial in a continued SLI issue I've been having with my 1080tis.
skupples is offline
post #39 of 43 (permalink) Old 08-16-2019, 03:42 AM
zGunBLADEz's Avatar
Yes i do get good scaling, the gui is just showing a vsync on "60" and gpus running @ 1800MHz with 0.800mV
remember one single 1080ti cant do [email protected] maxed out settings manually no presets.
depend what games you running you get % usage...
im on x299 so i get 16/16x less bus bottleneck better gpu usage..
most likely @ 1440P you have a cpu bottleneck in most games thats why the scaling is poor you can resolve the issue upping the resolution or settings..
post #40 of 43 (permalink) Old 08-16-2019, 08:36 PM
Moose-Tech's Avatar
Rep: 9 (Unique: 9)
I hear ya. I am adding another 140mm rad on the back of my case and I am STILL considering adding a free standing wall mounted 280 or 360.
All on account of because...
Build: Z390 ACE
