What's acceptable for water temperature? - Overclock.net - An Overclocking Community
post #1 of 43 (permalink) Old 07-30-2019, 12:24 PM - Thread Starter
Goooober's Avatar
Rep: 1 (Unique: 1)
I've finally got my first custom loop up and running and I dont actually know what an acceptable temperature is for the water.
Cooling my system (5820K, Vega64) is an EK D5 PWM pump, Black Ice 360 GTS, Black Ice 360 GTR (I think, its the 60mm thick multi port one) with Corsair ML120's on both rads.
I've left Heaven running for about 15 minutes now and the temps are as follows;
Water: Fluctuating between 36-39c
GPU: Around 40C
CPU: Around 44-50c (which i dont understand since its only at about 10% load).
The above temps are achieved with all 6 fans at 1000rpm and the pump at 3600rpm.
I'm a bit concerned that when i start gaming and the CPU comes under the load the above temps are going up pretty sharply.
Thanks
Goooober is offline
post #2 of 43 (permalink) Old 07-30-2019, 12:29 PM
Shooting down fallacies
ciarlatano's Avatar
Rep: 452 (Unique: 299)
You left out a huge piece of information - what is the ambient temp in the room?
ciarlatano is offline
post #3 of 43 (permalink) Old 07-30-2019, 12:31 PM
Manual breath enabled
Streetdragon's Avatar
Rep: 28 (Unique: 23)
Whats your ambient temp? Air in?
My temp different between air and water is at heavy gaming aroound 3,5°(Totally overkill loop).
If you have a temp different of 0-10° is good. lower is better ofcourse
Cube
(16 items)
Ryzen 3900X
Aorus X570 Master
1080 TI Founders Edition
F4-3600C16Q-32GTZR
2000GB Seagate Barracuda Compute ST2000DM008 256MB
samsung m2 970 evo
Leadex 80 Plus Platinum Netzteil, schwarz - 1200 Watt
heatkiller IV pro
EK-FC1080 GTX Ti - Nickel
Alphacool Eisbecher D5 250mm Plexi
Alphacool NexXxoS XT45 Full Copper 480mm
XSPC Multiport Radiator EX240
Scythe Grand Flex 4Pin PWM
thermaltake core x9
Operating System
Windows 10
Streetdragon is offline
post #4 of 43 (permalink) Old 07-30-2019, 12:34 PM
Overclocker in training
ThrashZone's Avatar
Rep: 186 (Unique: 111)
Hi,
Sounds reasonable for a 26c room temp.
i9-9940x With Optimus SigV2 and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Trident Z 3600C16 4x8gb's b-die default timings 16-16-16-36 F4-3600C16Q-32GTZKK
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
10900k batch # X016E724 with Optimus Foundation water block
z490 ASUS Maximus XII Apex
Trident-Z 3600c16 4x8gb kit 16-16-16-36 F4-3600C16Q-32GTZSW
Samsung 970 evo 500gb
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
D5 reservior combo/ 240GTX/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Audio
ThrashZone is offline
post #5 of 43 (permalink) Old 07-30-2019, 12:43 PM - Thread Starter
Goooober's Avatar
Rep: 1 (Unique: 1)
Unfortunately i dont have anything measuring ambient temp at the moment. I'll attach a temp sensor to my Aquaero 6 and just leave it dangling outside the case.
I'm now running AIDA64 stability test (not GPU, just CPU) and the CPU cores are dancing arround the mid 60's with the water temp around 35. Is it normal for the CPU to run that much hotter than the water temp?
Goooober is offline
post #6 of 43 (permalink) Old 07-30-2019, 12:47 PM
ThrashZone's Avatar
Hi,
Funny you don't know or can tell what temperature is in the room you're sitting in
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
Keyboard
Logitech G710+
Mouse
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
Operating System
Keyboard
Logitech G710+
Mouse
Audio
post #7 of 43 (permalink) Old 07-30-2019, 01:07 PM
Vermin Supreme 2020
skupples's Avatar
Rep: 737 (Unique: 388)
les than a few C above ambient.
if I remember, most of us with well radiated systems have a 1-3c delta.
based off the info given, you're doing just fine.
Add me on Steam, same name
skupples is offline
post #8 of 43 (permalink) Old 07-31-2019, 10:15 AM - Thread Starter
Goooober's Avatar
Rep: 1 (Unique: 1)
While gaming the water temp seems to top out at about 41c. Is that too high? I'm using Mayhems soft tubing FWIW.
Goooober is offline
post #9 of 43 (permalink) Old 07-31-2019, 09:59 PM
Moose-Tech's Avatar
Rep: 9 (Unique: 9)
41c is fine. On my Aquaero 6 I have my loop temp set warning set to 45c and alarm set to 50c. Anything past 50c could degrade the tubing, and 60c will soften tubes.
You should set up the ambient temp for permanent use. With the ambient temp your AQ6 could control your fan curves and even your pump speed off the Delta (difference) of your ambient and your loop.
Under Virtual Temperature Sensors you would create an "Absolute temperature difference" sensor based on your Loop water temp (Sensor 1) and Ambient (Sensor 2).
Use that value to drive your fan curves. Your loop can only remove so much heat until it reaches equilibrium. Basing your fan speed on the Loop Delta allows you to maintain stable temps based on your preferred sound levels.
The AQ6 excels at this stuff. Use it.
Build: Z390 ACE
Core i9-9900K OC 5 GHz, MSI Z390 ACE Mobo, AMD Radeon VII GPU OC 2K MHz
Corsair Vengeance RGB 32GB 3200 RAM, Phanteks Enthoo Pro M SE.
EKWB Z390 ACE Monoblock, Bykski Radeon VII GPU w/b, 2x EKWB 140 Revo D5 Pump & Res.
Aquacomputer Aquaero 6 LT USB Fan-Controller, Quadro, Vision Touch and 'High Flow' Sensor.
(2x) HWL Black Ice Nemesis 280 GTS XFLOW and (1x) Alphacool XT45 X-Flow 280 radiators.
Moose-Tech is offline
post #10 of 43 (permalink) Old 07-31-2019, 10:05 PM
High Clocker
bmgjet's Avatar
Rep: 192 (Unique: 166)
0-50C is acceptable.
SLI Voodoo 2 - > GeForce4 MX 420 -> GF 6600GT -> GF 6800GT -> GF 8800Ultra -> AMD 4870 -> AMD 4890 -> CF AMD 5820 -> CF AMD 6850 -> CF AMD 7970 -> SLI GF 680 -> SLI GF 780 -> CF AMD 290X -> GF 980ti -> SLI GF 980ti -> GF 1080ti -> SLI GF 1080ti -> <- RTX 2080ti (DOA/Refunded)
AMD 8120
FX 8350
7970 CFX
680 SLI
bmgjet is offline
