Water Damaged 2080, Thanks EK - Page 4 - Overclock.net - An Overclocking Community
post #31 of 41 (permalink) Old 08-11-2019, 08:50 AM
Vermin Supreme 2020
skupples's Avatar
Rep: 737 (Unique: 388)
Quote: Originally Posted by Mayhem View Post
Yes that's the issue. They need to separate them out.
Add me on Steam, same name
skupples is offline
post #32 of 41 (permalink) Old 08-11-2019, 09:31 AM
Section31's Avatar
Rep: 39 (Unique: 18)
I will say EkJake has always provided good customer support. Seems like caselabs hired and trained good employees.
The Ever Ongoing Build. 3950X. X570 Hero VIII, 32GB GSkill Trident Z 4000mhz, Seasonic Prime Titanium 1000Watt, 1TB 960 Pro, 1TB WD SN750.
Section31 is offline
post #33 of 41 (permalink) Old 08-12-2019, 05:54 AM - Thread Starter
Watercooler
Socks keep you warm's Avatar
Rep: 145 (Unique: 124)
Quote: Originally Posted by ThrashZone View Post
Hi,
If you think about it the longer screws are for the back plate obviously
Not everyone buys the back plate though
Technically the screws for the back plate should be included in the back plate package would probably straighten out that confusion.
Extra screws are never a bad thing
Just to reiterate, i used 7 screws to hold block onto the GPU, i then used the other 6 screws for the backplate( which came in backplate packaging) to adhere the backplate to the waterblock and have 100% contact all round!
The problem with EK atm is they tell you in the online manual you can crack your die via using the wrong screws, yet have no mentions of what screw is what. It's appaling but atleast they are listening to their customers. I'm sure they are dealing with wayyy to many angry customers atm.
It's not even the workers fault it's upper management and the world economy atm. It's all SAVE SAVE SAVE. I get it, but don't blow your only revenue out the door.
I like to have fun.
https://stats.foldingathome.org/donor/110855
https://www.trueachievements.com/gamer/II+TH3PRO+II
16 Threads is Good
(10 items)
Intel Core I9 9900K 4.8Ghz
Gigabyte Aorus Elite
Aorus 2080Ti Xtreme Waterforce WB 11GB
Trident Z
Samsung 250 SSD
Cooler Master Silent Pro Hybrid
Watercooling Custom
900D
Operating System
Windows 10 x64
28" ACER 4K Monitor
Socks keep you warm is offline
post #34 of 41 (permalink) Old 08-15-2019, 10:08 PM
EKWB Forum Rep
EKJake's Avatar
Rep: 18 (Unique: 12)
Fake it til you make it! I, uh, mean yeah! They trained me well!
Its a simple fix, number your bags of screws and add the numbers to the manuals. Nothing more.
Quote: Originally Posted by Socks keep you warm View Post
I think everything is covered! If you guys can just make a way to identify screws that's about all it is. But now after this i have gone out of my way to learn how to read screw sizing lol.
I'm glad you guys are doing something about it, it is restoring faith! Thanks EK Jake!
Identifying and separating the screws both in the manual and packaging was passed along in my suggestions this week. We're actively watching for feedback and doing our best to improve the experience in all ways for everyone. It may take time, but we're making progress.
It's actually not even that so much as misunderstanding what makes it the easiest on users. Essentially, things are oversimplified in some aspects. The manuals aren't detailed enough and the packaging just includes everything. So you can't not have what you need and you shouldn't have any troubles with the manual because it's simple and easy to follow, right? That's great if you've done it a few times and know what you need, but it can lead to confusion for anyone new to watercooling and/or EK products. So it's realigning EK's understanding with what helps out everyone in the community the most without going overboard to where everything is TOO technical.
EKWB Forum Rep
EKJake is offline
post #35 of 41 (permalink) Old 08-15-2019, 10:55 PM
treetops422's Avatar
Rep: 24 (Unique: 18)
Can you post a pic of the different screws side by side? When I go open loop I'll def run it outside the case first. User error happens
treetops422 is offline
post #36 of 41 (permalink) Old 08-19-2019, 03:14 AM
Ashcroft's Avatar
Rep: 92 (Unique: 72)
Watercooling isn't for everyone. Identifying the right screws is quite easy with the size listed. You just need a cheap pair of calipers or even a ruler. An M2.5x5 will be 2.5mm wide on the threads and 5mm long.
Water cooling always has risks but in my experience a little bit of water exposure is not a guarantee of circuit board death. I have had several inadvertent spills caused by me being lazy and doing Linus style loop changes without draining. I have yet to have anything die because of it. A few times there was some artifacting so I just made a better and more thorough go of drying and it all came good.
Don't be dumb and lazy like me and take the time to ensure all is good before adding water. Air leak testing is worth its low expense several times over.
Still confused how a standoff can cause leaking though seeing as they don't touch the coolant.
I haven't been exposed to the new instructions yet so I can't comment on that though outsourcing doesn't sound like the best of ideas.
Ashcroft is offline
post #37 of 41 (permalink) Old 08-19-2019, 09:15 PM - Thread Starter
Watercooler
The standoffs go into the actual path of the water. I can't see any other way as to where the water came from as that is what was loose on the block.
I have been watercooling for close to 10 years and this is the 1st time i have ever sprung a leak.
EDIT: It's also nothing about the screw sizes, they used to have an actual screw list, if you look at my original post which you obviously haven't, you will see the difference in manuals.
I like to have fun.
16 Threads is Good
(10 items)
Trident Z
Samsung 250 SSD
Watercooling Custom
900D
Operating System
Windows 10 x64
28" ACER 4K Monitor
post #38 of 41 (permalink) Old 08-20-2019, 01:07 AM
Ashcroft's Avatar
Well that is very odd. I have never seen a single GPU block from any manufacturer that has holes drilled in the metal through to the water path. The blocks don't look to have holes in them and frankly it would be pretty stupid for them to have holes in them.
If there really is a hole drilled in the block then it would have to be a manufacturing error. Claiming its a non warrantable to have holes drilled in the block without even talking to EK about it seems odd for someone who has your level of experience.
I'm sure the thought of a damaged card is very stressful but getting hysterical won't help.
Did they just update the manuals because it seems like they tell you the screws to use just like the older manuals.
The manufacturers try to make things like water blocks seem like regular consumer products but they really are not. They are enthusiast modification tools that require some know how. There is a reason you can buy cards that already have blocks attached after all.
Ashcroft is offline
post #39 of 41 (permalink) Old 08-20-2019, 01:15 AM
broodro0ster's Avatar
Rep: 9 (Unique: 8)
I agree here.
But maybe TS can make a picture of the coldplate where you can see the holes between the waterchannels.
But as far as I can see on this picture, I don't see any spots where there are holes in the waterchannels: https://www.ekwb.com/shop/ek-vector-...b-nickel-plexi
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #40 of 41 (permalink) Old 08-22-2019, 09:14 PM
Bartdude's Avatar
Rep: 4 (Unique: 3)
Quote: Originally Posted by broodro0ster View Post
I agree here.
Agree here too, I can't see anywhere in that link that the screws impact the water channel. Also is that installation manual on the link above the same as referred too? because to me it seems pretty self explanatory and no different to all the manuals I've used from EK in the past, both CPU blocks, GPU blocks and backplates BUT I also work in facilities so screw sizes etc are easy for me.
"No s*** lady, does it sound like I'm ordering pizza!"
Corsair 900D
(29 items)
Intel E4790k Haswell
Asus ROG Maximus VII Watchdogs
EVGA 1080 SC Gaming
Corsair Dominator Platinum
Samsung SSD
Samsung SSD
Samsung SSD
Optical Drive
LG Blu Ray Rewriter
Corsiar AX1200i
EK XTOP Revo Duel D5
2X EK Radiator 360 PE
EK Supremacy EVO
EK 1080 Full Cover Waterblock
Aquero 6 XT
Aquero MPS 400 Flow Sensor
9X Gentle Typhoon Fans
Aquacomputer Hubby7
4x Aquacomputer Splitty9
Aquacomputer Poweradjust USB 3 Ultra Version
Corsiar 900D
Operating System
Win 10 Pro 64
Asus ROG Swift PG279Q 27" 2K WQHD 165Hz IPS G-Sync 2K Gaming Monitor
Keyboard
Razer Blackwidow Soft Touch
Keyboard
Razor Orbweaver
Mouse
Razer Deathadder 3500DPI
Mouse
Razer Mouse Mat
Audio
Sound Blaster X-Fi Titanium Fatal1ty Champion Series
Audio
Yamaha RX-V381 5.1 Channel Receiver Amplifier
Audio
Tannoy 5.1 Speakers
Bartdude is offline
