How do you locate very, very small leaks? - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 08-05-2019, 08:48 AM - Thread Starter
Rep: 0
I've got an EKWB hard tube system, custom built, that seems to have a very, very small leak someone in it. In my pump reservoir I've seen the fluid level drop by about 1mm every two months or so. It's such a small leak that I suspect it's evaporating before it ever drips. Or, is this just some kind of normal evaporation somehow?
The prior build never seemed to change its level. When I added my NVLink and the EKWB terminal bridge to cool my double RTX2080Ti's I also replaced the default reservoir from the D5 REVO 140 pump unit with a taller cylinder. So, I'm wondering if it might even be an O-ring on the acrylic cylinder that's not sealing perfectly at the top or bottom that might be causing leaks/evaporation.
Anyone have any similar experience and care to share how you solved it?
BuildOne
(8 items)
Core i9-7900X
Thermaltake Core P5 - Tempered Glass - Black
Asus Prime X299-Deluxe
EVGA GTX 1080 FTW
G. Skill Trident Z RGB 3200
Samsung 970 Pro M.2
Corsair HX 1200i
EKWB
Bighouse is offline
post #2 of 11 (permalink) Old 08-05-2019, 09:13 AM
SubZero is the Goal
HardheadedMurphy's Avatar
Rep: 73 (Unique: 63)
Tiny drops in fluid levels I never worried about. Significant ones I would. That's when I would go through each fitting carefully...
Now, ek sells a leak test device that I'll be picking up for my next loop reconfigure
Sent from my GM1915 using Tapatalk
"It is impossible to defeat an ignorant man in an argument" McAdoo
Peace begins when we care about someone other than ourselves.
"Hell is still Overburdened, I must stand and wait in line" Disturbed
The Beast
(23 items)
MiniFurnace
(10 items)
ThinClient
(5 items)
i5-9600k
ASRock Z390 Taichi
EVGA GeForce GTX 1080 FTW Hydro Copper GAMING, 08G-P4-6299-KR, 8GB GDDR5X, LED, DX12 OSD Support (PXOC)
EVGA GeForce GTX 970 04G-P4-2974-KR 4GB SC GAMING w/ACX 2.0, Silent Cooling Graphics Card
Corsair Vengence RGB Pro
Mushkin Enhanced Source M.2 2280
Toshiba
Optical Drive
LG Bluray RW
Rosewill Quark
Barrow RGB 115X CPU Block
EK-360 Radiator
Phobya 12v DC PWM Pump
Black Ice Nemisis 240mm stealth Rad
Alphacool 5.25 pump / resivoir combo DC-LT
Phobya Balancer 250mm Res - Black Nickle
Corsair Obsidian 900D
Operating System
Windows 7 Professional
LG 34" Ultrawide IPS 21:9
HP 27xw ips
HP 27xw IPS
Keyboard
Corsair Strafe RGB MX Silent
Mouse
Corsair M65 Pro RGB
Audio
Corsair Void Pro RGB
Xeon 5300
Xeon 5300
Dell 2950 v3 Server
ECC DDR2 RAM
Hitachi 1tb 7200rpm
Optical Drive
SLIM DVD-RW
redundant 750w
OEM
Operating System
Windows Server R2
Other
DRAC 6/i
Celeron N2930
G.Skill 8gb 204 pin
Seagate 500gb 2.5"
Zotac Zbox CI320 Nano
Operating System
Win 10 Pro
HardheadedMurphy is offline
post #3 of 11 (permalink) Old 08-05-2019, 09:14 AM
Vermin Supreme 2020
skupples's Avatar
Rep: 737 (Unique: 388)
sounds like evap, not leaking. Hell, there could even still be some air trapped somewhere. depends on how long its been running & how well you bled the system in the first place. Either way, i'd put money on evap. You'd freak out with a large soft tube system. I evap an inch a month, in a 3/4 gallon loop.
What kinda hard line? I know PETG absorbs water more than acrylic, or true glass.. which would absorb the least.
Add me on Steam, same name
skupples is offline
post #4 of 11 (permalink) Old 08-05-2019, 09:25 AM
Tech Enthusiast
deafboy's Avatar
Rep: 446 (Unique: 338)
Yeah, sounds more like a combination of small air bubbles bleeding out of the system and evaporation
I have a pretty massive loop in terms of coolant, a bleed normally takes me 8-24 hours for me to feel comfortable with it. But in reality the system takes a long while to be completely bled from little air bubbles in all the rads and whatnot.
1mm over two months I wouldn't even be concerned about.
IN HONOR OF SYRILLIAN, R.I.P.
ASUS ROG Rampage IV Black Owners Club || PNW Overclockers Club
BMW TJ07 Build Log -- The Ultimate Cooling Machine
2 year anniversary In Remembrance of a Great - RIP Syrillian
Mini Gaming
(16 items)
Overkill FreeNAS
(10 items)
AMD Ryzen R9 3900x
ASUS ROG Strix X570-I
nVidia Titan XP
Corsair Vengeance Pro 3600 32GBx2
Samsung PM981 1TB
2TB WD Blue M.2
Corsair SF600
Noctua U12A
Accelero Xtreme III
6x Noctua NF-A12x25
Lian Li TU150
LG C9
ASUS PG279Q
Keyboard
Logitech G613
Keyboard
Logitech K400
Mouse
Logitech G602
E5-2670v1
E5-2670v1
Supermicro X9DRL-iF
12x HGST 4TB CoolSpin
6x WD Red 8TB
Corsair AX750
2x Noctua nh-u9dxi4
3x Scythe AP-30
Norco 4224
Operating System
FreeNAS
Intel Xeon E5-1680 V2
Asus Rampage IV Black Edition
nVidia Titan XP (2100/5200)
Corsair Dominator Platinum 32GB
Intel 750 400GB
Intel 750 1.2TB
Samsung PM981 1TB
Corsair AX1200i
2x Swiftech D5 w/ EK Dual Pump Top
XSPC EX480, EX360 & 2x Phobya 1080
EK Supremacy EVO CPU Block
EK Advanced 250mL Res
Lamptron FC-5V2
EK Rampage IV BE Water Block
Copper Tubing w/ push fittings
EK-FC Titan XP Copper/Acetal
Silverstone TJ07, heavily modified
Operating System
Windows 10 Pro
Asus PG297Q
Keyboard
Leopold Otaku
Mouse
Corsair M65
Mouse
Corsair MM600
Audio
Sennheiser HD595 / HD428 / HD280
Audio
Corsair SP2500
deafboy is offline
post #5 of 11 (permalink) Old 08-05-2019, 09:37 AM
SubZero is the Goal
My last soft tube run I saw 2 inches of fluid bleed out before it stabilized... But then again, I didn't do any serious tilting and turning on my 900D that thing is a beast to move around empty, let alone with a full build + water
The Beast
(23 items)
MiniFurnace
(10 items)
ThinClient
(5 items)
i5-9600k
ASRock Z390 Taichi
Toshiba
Optical Drive
LG Bluray RW
Rosewill Quark
EK-360 Radiator
Operating System
HP 27xw ips
HP 27xw IPS
Keyboard
Mouse
Corsair M65 Pro RGB
Audio
Xeon 5300
Xeon 5300
Dell 2950 v3 Server
ECC DDR2 RAM
Hitachi 1tb 7200rpm
Optical Drive
SLIM DVD-RW
redundant 750w
OEM
Operating System
Windows Server R2
Other
DRAC 6/i
Celeron N2930
G.Skill 8gb 204 pin
Seagate 500gb 2.5"
Operating System
Win 10 Pro
post #6 of 11 (permalink) Old 08-05-2019, 09:42 AM
Shawnb99's Avatar
Rep: 64 (Unique: 45)
You can build your own leak tester for 10% EK or AQ charges for theirs.
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is online now
post #7 of 11 (permalink) Old 08-05-2019, 10:22 AM
SubZero is the Goal
I was just thinking about that lol... Time to hit the hardware store
The Beast
(23 items)
MiniFurnace
(10 items)
ThinClient
(5 items)
i5-9600k
ASRock Z390 Taichi
Toshiba
Optical Drive
LG Bluray RW
Rosewill Quark
EK-360 Radiator
Operating System
HP 27xw ips
HP 27xw IPS
Keyboard
Mouse
Corsair M65 Pro RGB
Audio
Xeon 5300
Xeon 5300
Dell 2950 v3 Server
ECC DDR2 RAM
Hitachi 1tb 7200rpm
Optical Drive
SLIM DVD-RW
redundant 750w
OEM
Operating System
Windows Server R2
Other
DRAC 6/i
Celeron N2930
G.Skill 8gb 204 pin
Seagate 500gb 2.5"
Operating System
Win 10 Pro
post #8 of 11 (permalink) Old 08-07-2019, 06:28 PM - Thread Starter
Rep: 0
Thanks everyone! I won't sweat it then and just top it off every few months if I don't like seeing a waterline in my reservoir.
BuildOne
(8 items)
Core i9-7900X
EVGA GTX 1080 FTW
Samsung 970 Pro M.2
Corsair HX 1200i
EKWB
Bighouse is offline
post #9 of 11 (permalink) Old 08-08-2019, 04:27 AM
broodro0ster's Avatar
Rep: 9 (Unique: 8)
My loop was filled 8 months ago and the level has also dropped about 4mm, which is about 1mm per 2 months.
My loop is PETG and the drop was even faster with ZMT tubing. So I think it just some evaporation or microbubles that are still bleedling.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #10 of 11 (permalink) Old 08-09-2019, 07:07 PM
News Fiend
ryan92084's Avatar
Best method to detect tiny leaks is still to wrap paper towels or blue shop towels around all fittings and check back after several hours. Tiny drops that would normally just evaporate will change the texture of the paper towel and make the dye run a bit in the blue shop towel. Cheap and effective.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
