1 res, 2 pumps, 2 loops? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 15 (permalink) Old 08-05-2019, 06:38 PM
Moose-Tech's Avatar
Rep: 9 (Unique: 9)
https://martinsliquidlab.wordpress.c...s-vs-parallel/
On a single loop, Parallel pumps are not going to provide any real benefit. Serial pumps will.
Also, you really need to separate the res outlets, to one for each pump. At max flow you could slow down the fluid to the pumps going through a single set of fittings.
If you were hoping to separately manage loop temps, you can't do that with a single res.
Suppose you placed both pumps in serial operation with one outlet from the res. THEN run your parallel loop with 2x 360 and one Heat Load on each side.
Same as what you have EXCEPT 2x pumps increase the flow and you have redundancy against one pump failing.
BTW - Wow! a Caselabs Magnum M8! You better put that in the will for your kids.
Build: Z390 ACE
Core i9-9900K OC 5 GHz, MSI Z390 ACE Mobo, AMD Radeon VII GPU OC 2K MHz
Corsair Vengeance RGB 32GB 3200 RAM, Phanteks Enthoo Pro M SE.
EKWB Z390 ACE Monoblock, Bykski Radeon VII GPU w/b, 2x EKWB 140 Revo D5 Pump & Res.
Aquacomputer Aquaero 6 LT USB Fan-Controller, Quadro, Vision Touch and 'High Flow' Sensor.
(2x) HWL Black Ice Nemesis 280 GTS XFLOW and (1x) Alphacool XT45 X-Flow 280 radiators.
Moose-Tech is offline
post #12 of 15 (permalink) Old 08-06-2019, 06:32 AM
broodro0ster's Avatar
Rep: 9 (Unique: 8)
It should be a problem.
And this is not the typical parallel pump setup. The flow will be like in split loops, but it will have a shared reservoir and loop temps will be equal. But you have a lot of radspace so temps should be fine :-)
I'm looking forward to the result.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #13 of 15 (permalink) Old 08-06-2019, 07:23 AM
Overclocker in training
ThrashZone's Avatar
Rep: 186 (Unique: 111)
Hi,
Four 360mm rads doubt it would matter how many reservoirs there is in your condominium sized case
i9-9940x With Optimus SigV2 and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Trident Z 3600C16 4x8gb's b-die default timings 16-16-16-36 F4-3600C16Q-32GTZKK
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
10900k batch # X016E724 with Optimus Foundation water block
z490 ASUS Maximus XII Apex
Trident-Z 3600c16 4x8gb kit 16-16-16-36 F4-3600C16Q-32GTZSW
Samsung 970 evo 500gb
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
D5 reservior combo/ 240GTX/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Audio
ThrashZone is online now
post #14 of 15 (permalink) Old 08-06-2019, 08:03 AM
Shawnb99's Avatar
Rep: 66 (Unique: 47)
Two loops is completely unnecessary. You won’t see more then a degree of temp difference in any part of your loop so no need to separate them.
Plus even with the M8 you’re going to run into spacing problems. The 2080tis are so big they really limit what can go in the front bays.
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is online now
post #15 of 15 (permalink) Old 08-06-2019, 08:12 AM
Meep
Gilles3000's Avatar
Rep: 333 (Unique: 235)
Quote: Originally Posted by Sean W. View Post
Hey guys,
I am thinking about doing a build in a massive case, I want to do 2 loops, but I dont quite have enough space to do 2 tube reservoirs like I would like to do, but I do have space for one huge one.
Can I have one res feed 2 pumps separately for two separate loops, one for the graphics cards and one for the cpu then come back to the res? In theory I don't see why it wouldn't work, but perhaps there is something I'm not thinking of.
Kinda like this, excuse the terrible lines, I did this on my laptop in 2 minutes
It would work, but why would you do this?
By "splitting" the loop like this, you get no redundancy and less of a pressure increase than you would get with the 2 pumps in series.
Gilles3000 is offline
