CPU BLOCK FLOW DIRECTION? - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 08-05-2019, 04:08 PM - Thread Starter
jimmyhackers's Avatar
Rep: 1 (Unique: 1)
i have a 3770k and a cheapy chinease water block.
the block is omnidirectional and can be mounted for vertical/sideways flow or horizontal/up-down flow.
in its horizontal flow position (left to right) i had all cores at a very similar temp but it caught a small bubble on the exit side at the top corner.
so i changed it to a vertical (top to bottom flow) to stop the bubble catching but ive just noticed that the bottom core is about 3-5 degrees C lower that the other three now.
ive read that as i have a rectangular cpu die that i should have the flow going from side to side, which honestly makes sense. is this the case?
if so should i worry about the bubble?
also looking at the chip die layout.....the cores are on the left and the memory controller io is on the right. would left to right vs right to left make a difference?
thanks in advance for the help
Jim
jimmyhackers is offline
post #2 of 7 (permalink) Old 08-05-2019, 04:14 PM
Missing the Old days
Cerberus's Avatar
no matter the orientation of the waterblock, flow rate should be linear as the path doesn't change.
"But I, being poor, have only my dreams. I have spread my dreams beneath your feet. Tread softly because you tread on my dreams."
Do you FOLD? Maximize PPD by using a PASSKEY!!!
Work Folder
(7 items)
AMD r7 2700x
MSI X470 Gaming PRO
EVGA GTX 1080Ti
PNY Anarchy-X 2x8GB 3200Mhz
256GB Plextor M8Pe m.2
Corsair RM750X
big metal box
Operating System
Microsoft Windows 10 x64
DELL S2716DG
Keyboard
Logitech G910
Mouse
Logitech G604
Mouse
Steelseries Mat
Audio
Logitech G602
Other
steam controller
AMD FX8350
BIOStar TA970
AMD FURY X
Zotac GTX 960
Gskill 2x8GB DDR3
Western Digital Blue 2TB
Corsair 650w
Cerberus is offline
post #3 of 7 (permalink) Old 08-05-2019, 07:03 PM
Moose-Tech's Avatar
Rep: 9 (Unique: 9)
Most likely it's the "cheapy chinease water block" causing problems with your flow.
Good block manufacturers will make sure the flow moves all the around the block, regardless of orientation.
Build: Z390 ACE
Core i9-9900K OC 5 GHz, MSI Z390 ACE Mobo, AMD Radeon VII GPU OC 2K MHz
Corsair Vengeance RGB 32GB 3200 RAM, Phanteks Enthoo Pro M SE.
EKWB Z390 ACE Monoblock, Bykski Radeon VII GPU w/b, 2x EKWB 140 Revo D5 Pump & Res.
Aquacomputer Aquaero 6 LT USB Fan-Controller, Quadro, Vision Touch and 'High Flow' Sensor.
(2x) HWL Black Ice Nemesis 280 GTS XFLOW and (1x) Alphacool XT45 X-Flow 280 radiators.
Moose-Tech is offline
post #4 of 7 (permalink) Old 08-05-2019, 07:06 PM
Vermin Supreme 2020
skupples's Avatar
Rep: 737 (Unique: 388)
I would attempt a re-seat, but no the little bubble doesn't really matter.
remember, water temp doesn't really change before/after a block. cores on the left, and moon over miami, doesn't matter.
all that matters is that the block was properly designed to cool the right amount of space. if not? then go with the orientation that works best... try a re-seat first though if you prefer it how it is now.
Add me on Steam, same name
skupples is offline
post #5 of 7 (permalink) Old 08-06-2019, 04:46 PM - Thread Starter
Rep: 1 (Unique: 1)
yeah i gave up on the cpu block last night.
it wasnt flow rate i was asking about......it was water path over the cpu die. A horizontal flow gave me about 1-2 degrees c lower max temps and a more even temp between each core.
ive drawn a crude pic to illustate what was going on.
i ended up pulling the pump part out of my h100 water block, and ran that instead. which yeilded another 3 -4 degrees c lower. the flow direction of this block is from centre to outside with much finer fins.
Name:	h vs v.png
post #6 of 7 (permalink) Old 08-06-2019, 05:14 PM
Vermin Supreme 2020
skupples's Avatar
that tells me the original pump wasn't anywhere near 1GPM
and as stated, block design may inhibit total cooling ability, so whichever orientation works best, use.
seems you've got it all sorted.
skupples is offline
post #7 of 7 (permalink) Old 08-06-2019, 07:05 PM
Moose-Tech's Avatar
Rep: 9 (Unique: 9)
Good to hear you are getting better temps. Good luck.
Build: Z390 ACE
