Bad EKWB CPU Contact, please help. - Page 8 - Overclock.net - An Overclocking Community
post #71 of 195 (permalink) Old 08-12-2019, 01:08 PM
Tech Enthusiast
oreonutz's Avatar
Rep: 99 (Unique: 65)
Quote: Originally Posted by skupples View Post
i'm not super up on my sensors, as I have an aqauero 6 unit, thus use their mechanical flow sensor.
I believe their "MIPs" devices (does more than just flow too) don't require the aquaero, you just connect em with the USB header cable & install their software. (aquacomputer)
Oh Crap. Dude I didn't even realize. I already have an Aquero 6 XT. Its controlling fans in my Server Build. I may just either buy another or borrow that out of my server for a bit... Thanks!
Regarding my cooling. If you had to guess, what would you say is the limiter on my cooling setup? Assuming the Mount is good. Its an EK 360 Rad, its damn near Identical to the EK-Cool Stream with a DDC and Res built into it. And then the Block which I thought was just a dressed up EK Classic CPU Block, but I could be wrong on that assumption.
Edit: My Bad I just saw you edited your post to address that part. So you think it is most likely the block then (assuming the Block Contact itself is fine)
-MattTheTech
Offical Ryzen 9 3900x Owner!
Offical Ryzen 9 3950x Owner!
DodekaZen3000
(34 items)
Ryzen 9 3950x
ASUS Crosshair VII Hero
EVGA 1080ti FTW3 Hybrid
G.SKILL Flare X Series 32GB (4 x 8GB) 3200Mhz (PC4 25600) - F4-3200C14D-16GFX (x2 Kits)
Samsung 970 Pro 512GB
Samsung 970 Evo 1TB
Samsung 850/860 Evo (x3 Raid 0 Game Drive)
WD Black 4TB (x2 Raid 0 Storage Drive)
860 Evo
Optical Drive
LG Blu-Ray Burner (Model BH16NS40)
Optical Drive
5.25" to One 3.5" and One 2.25" Bay (Model Syba SY-MRA55006)
Corsair RM1000i
EKWB Phoenix 360mm Modular Cooler
280mm Alphacool UT60
280mm EKWB Coolstream CE
Optimus Foundation AM4 CPU Block
x2 Corsair Pump/Res Combo
EKWB Acrylic 1080ti FTW Block
Aquaero 6xt
Old Jonesbo Case
Operating System
Windows 10 Enterprise
Samsung NU8000 55Inch TV (Its a 4k TV But I run in it 1440p 120hz)
LG 1080p 34 Inch Diplay
Keyboard
Corsair k70 RGB Lux Mk2
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Custom Built 7.1 Surround System
Audio
HT-Omega eClaro 7.1 Sound Card
Audio
Focusrite Scarlett 18i20
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
10 ML120 + 6 ML140 Corsair Maglev Fans
Other
Phanteks Halo aRGB LUX x5
oreonutz is offline
post #72 of 195 (permalink) Old 08-12-2019, 01:10 PM
Vermin Supreme 2020
skupples's Avatar
Rep: 737 (Unique: 388)
assuming the block is good, radiator space, of course... A second one may put that pump below optimal flow though, idk enough about what they used.
I'm just barely able to maintain 1.2GPM w. 4x 480s, cpu, 2x gpu, via MCP35x2... however, there are quite a few fittings I could remove to ease the pain, it's just not neccessary with DDCs. They like restriction.
- note this is in a Caselabs STH10, so I've got ~10Ft of tube which affects flow as well.
Add me on Steam, same name
skupples is offline
post #73 of 195 (permalink) Old 08-12-2019, 01:16 PM
Tech Enthusiast
oreonutz's Avatar
So jealous of that case! I so wish I would have gotten one while I had the chance...
Appreciate your input. Looks like I am going shopping today...
-MattTheTech
DodekaZen3000
(34 items)
Ryzen 9 3950x
Samsung 970 Evo 1TB
860 Evo
Optical Drive
Optical Drive
Corsair RM1000i
Aquaero 6xt
Old Jonesbo Case
Operating System
Keyboard
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Audio
Audio
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
Other
oreonutz is offline
post #74 of 195 (permalink) Old 08-12-2019, 01:24 PM
Vermin Supreme 2020
skupples's Avatar
enjoy, and any time.
Yep, she's never going anywhere. I'm planning a true full dream machine rebuild for late 2021 ( depending on if we've gotten the top tier response to PS5 and XBS yet) which means full tear down, cleaning, etc, etc.
skupples is offline
post #75 of 195 (permalink) Old 08-12-2019, 01:25 PM
Section31's Avatar
Rep: 39 (Unique: 18)
Just need ekjake to directly handle the cases here.
The Ever Ongoing Build. 3950X. X570 Hero VIII, 32GB GSkill Trident Z 4000mhz, Seasonic Prime Titanium 1000Watt, 1TB 960 Pro, 1TB WD SN750.
Section31 is online now
post #76 of 195 (permalink) Old 08-12-2019, 01:26 PM
Section31's Avatar
Thats good timing. Im thinking same timeline myself.
post #77 of 195 (permalink) Old 08-15-2019, 09:54 PM
EKWB Forum Rep
EKJake's Avatar
Rep: 18 (Unique: 12)
Quote: Originally Posted by Section31 View Post
Hope they resolve it for you. Fortunate we have EkJake as rep here.
We will find out pretty soon if changes are needed for ryzen 3000 series cpu blocks.
Jakes definitely been busy. he mentioned an internal tipping point in another thread leading to a re-design of packaging due to the # of people that keep using the wrong screws, leading to improper mounts (on GPUs) I'd be willing to bet they'll be discussing AMD ryzen stuff at that meeting too, since this is getting a lot of bad "press" over on reddit from a few users.
My job role has expanded a lot since I started, but I'll be doing my best to be back in the forums actively.
I'm trying to track all of these. Will be putting together a spreadsheet tomorrow. Please PM your support ticket number, Section31, so it's easy for me to find. Wish I could help handle support tickets, though I will say I lack the experience with figuring out causes and solutions as compared to the support team.
Seems like things have improved albeit slowly ever since ekwb founder got back involved. Lot of blame was put on ex ekwb ceo (now corsairs hydro x head).
Things are improving. Unfortunately, it takes time to implement changes across an entire product portfolio. But that was exactly why I was brought on, to see all of the feedback and comments from everyone in the forums using the products day to day.
Quote: Originally Posted by m70b1jr View Post
EK Just offered to send me out a new cold plate. I will deff test temps when I'm back from Indiana. If temps remain high, I will attempt to lap my IHS.
Keep me updated, as well.
Quote: Originally Posted by oreonutz View Post
Thats awesome. Thats better than I got. I basically got a message saying, Sorry, the product we advertised and sold to you as being "Just as Good as Custom Watercooling, but in an AIO Form Factor that is expandable with all EKWB off the shelf products, and using only Copper" was actually no where near as good as a custom water cooling loop, so you should probably upgrade, sucks you spent $400 on our product huh?
I seriously can't believe that. If this can be fixed with just a better pump then its no big deal, but if this is a Block design limitation...
Please PM me about this with your support ticket number. Was this for the Pheonix series, I'm guessing?
EKWB Forum Rep
EKJake is offline
post #78 of 195 (permalink) Old 08-16-2019, 03:13 PM
SDhydro's Avatar
Rep: 38 (Unique: 26)
So just to follow up Ek is shipping me a new cold plate as well. But unless its flat I don't know how much it will help. Seems like a complete new cpu block is needed.
SDhydro is offline
post #79 of 195 (permalink) Old 08-19-2019, 01:36 PM - Thread Starter
m70b1jr's Avatar
Rep: 13 (Unique: 12)
@EKJake
Just an update everyone, I received and installed my new cold plate. Things seemed promising at first, however I'm still getting the same issues. 95c Stock Prime95 test, and radiators are not getting warm at all. 0% fan speed and 100% fan speed does not affect temperatures.
Official Ryzen 7 3700x Owner!
Holder of Fastest Vega 56 on 3DMark
Main Rig
(8 items)
Ryzen 7 3700x
Asrock X370 Pro4
Aorus 1080Ti
Gigabyte Vega 56
Vengence PRO RGB
EVGA 750 G2 SuperNova
Custom Waterloop
NZXT H500i
m70b1jr is offline
post #80 of 195 (permalink) Old 08-19-2019, 02:56 PM
Tech Enthusiast
oreonutz's Avatar
@EKJake
Thats really discouraging. I just bought 2 280mm Rad's and a New D5 Pump and Res to add my loop, hoping to help drop down temps a bit. But if there is not any difference in temps no matter your fan speed, and the Rad isn't getting hot at all, well that suggests bad contact. It would really suck if we had to Lap both the Block and The IHS just to get good contact.
Some other users with EK blocks have reported that they have turned their block Orientation 90 Degrees and have experienced a significant drop in Temps by doing so, I guess the Theory behind this is the flow over the Cold plate is closer to the actual chiplets when you rotate the Block 90 Degrees, I am yet to try it myself, but there are a few respected members who have reported success with this, so its worth a shot.
-MattTheTech
DodekaZen3000
(34 items)
Ryzen 9 3950x
Samsung 970 Evo 1TB
860 Evo
Optical Drive
Optical Drive
Corsair RM1000i
Aquaero 6xt
Old Jonesbo Case
Operating System
Keyboard
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Audio
Audio
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
Other
oreonutz is offline
