Bad EKWB CPU Contact, please help. - Overclock.net - An Overclocking Community
post #1 of 170 (permalink) Old 08-06-2019, 06:26 PM - Thread Starter
m70b1jr's Avatar
Rep: 10 (Unique: 9)
Hey guys!
I recently picked up a EK Classic for my Ryzen 7 3700x, but I'm experiencing very high temps. I made a thread explaining the situation and asking for help. Here's a YouTube video I made for a quick recap:
So, I emailed EK's support, but they're taking too long to give me a definite answer on what I should do, so maybe you guys can help me out? It seems as if the IHS on the CPU and Cold plate are not making adequate contact. What should I do now?
UPDATE 8/19/2019
I received the new EK Cold plate, while it *seems* to have made better contact due to the better thermal paste spread, it still gets very hot. Rads and water are cold to the touch after a prime95 load, and changing fan speed doesn't seem to effect temperatures at all. I might have to bite the bullet lap the original Cold plate, and POSSIBLY Lap my CPU. I really don't wanna void the warranty on the most expensive and fastest CPU I've ever purchased.
Official Ryzen 7 3700x Owner!
VEGA 56 with PPT Mod
16GB Corsair Vengeance LPX 3000
Asrock X370 Pro 4
NZXT h500i
All on a custom water loop
m70b1jr is offline
post #2 of 170 (permalink) Old 08-06-2019, 06:29 PM
SubZero is the Goal
HardheadedMurphy's Avatar
Rep: 73 (Unique: 63)
Lap the block?
Sent from my GM1915 using Tapatalk
"It is impossible to defeat an ignorant man in an argument" McAdoo
Peace begins when we care about someone other than ourselves.
"Hell is still Overburdened, I must stand and wait in line" Disturbed
The Beast
(23 items)
MiniFurnace
(10 items)
ThinClient
(5 items)
i5-9600k
ASRock Z390 Taichi
EVGA GeForce GTX 1080 FTW Hydro Copper GAMING, 08G-P4-6299-KR, 8GB GDDR5X, LED, DX12 OSD Support (PXOC)
EVGA GeForce GTX 970 04G-P4-2974-KR 4GB SC GAMING w/ACX 2.0, Silent Cooling Graphics Card
Corsair Vengence RGB Pro
Mushkin Enhanced Source M.2 2280
Toshiba
Optical Drive
LG Bluray RW
Rosewill Quark
Barrow RGB 115X CPU Block
EK-360 Radiator
Phobya 12v DC PWM Pump
Black Ice Nemisis 240mm stealth Rad
Alphacool 5.25 pump / resivoir combo DC-LT
Phobya Balancer 250mm Res - Black Nickle
Corsair Obsidian 900D
Operating System
Windows 7 Professional
LG 34" Ultrawide IPS 21:9
HP 27xw ips
HP 27xw IPS
Keyboard
Corsair Strafe RGB MX Silent
Mouse
Corsair M65 Pro RGB
Audio
Corsair Void Pro RGB
Xeon 5300
Xeon 5300
Dell 2950 v3 Server
ECC DDR2 RAM
Hitachi 1tb 7200rpm
Optical Drive
SLIM DVD-RW
redundant 750w
OEM
Operating System
Windows Server R2
Other
DRAC 6/i
Celeron N2930
G.Skill 8gb 204 pin
Seagate 500gb 2.5"
Zotac Zbox CI320 Nano
Operating System
Win 10 Pro
HardheadedMurphy is offline
post #3 of 170 (permalink) Old 08-06-2019, 06:31 PM
skupples's Avatar
Rep: 544 (Unique: 309)
get a metal ruler type deal & see if the cpu IHS is derformed, if so lap. more likely the IHS than the block.
or maybe that one radiator simply isn't enough for that chip? idk enough about amd heat production these days.
if block is flat, & chip is flat... does your radiator get nice & warm after it runs for a bit? but based on that chip imprint, chip ihs isn't flat/bad crank job... you seem pretty competent though, so chip ihs.
skupples is online now
post #4 of 170 (permalink) Old 08-06-2019, 06:42 PM - Thread Starter
m70b1jr's Avatar
Rep: 10 (Unique: 9)
Watch the youtube video please.. I have 2x radiators (1x 120mm and 1x 240mm) and they do not warm up at all during a sustained prime 95 load, my water barely gets warm. However if I do a GPU Stress test, the rads will heat up, which makes me deff think there's a heat transfer issues between IHS and Waterblock.
Does lapping void the AMD Warranty?
Asrock X370 Pro 4
NZXT h500i
m70b1jr is offline
post #5 of 170 (permalink) Old 08-06-2019, 06:44 PM
skupples's Avatar
yeah, i ended it @ 3/4s thru.
yes, lapping voids warranty. Even scrubbing the info off the front voids warranty, at least @ Intel...
You may be able to talk them into sending another sample though, if you can prove its the IHS causing the temp issue. not sure. haven't dealt with team red in many moons, & now give intel the extra money to insure my chip past spec.
post #6 of 170 (permalink) Old 08-06-2019, 06:47 PM - Thread Starter
m70b1jr's Avatar
Rep: 10 (Unique: 9)
Alright. Thanks! I talked a lot in the video so I see why you ended it.
I'll see if I can get a straight edge and look up methods for testing flatness. I don't want any downtime with my PC, so hopefully AMD can cross-ship with me.
Asrock X370 Pro 4
NZXT h500i
m70b1jr is offline
post #7 of 170 (permalink) Old 08-06-2019, 07:48 PM
ssateneth's Avatar
Rep: 43 (Unique: 38)
I'd lap the CPU. Use a high conductive paste like Prolimatech PK-3 too, but not liquid metal; copper will soak up the LM and you get worse thermals over time. have personally seen it 3 times. It's fine on nickel, but it will stain the laser-etched surface of a CPU IHS if you don't lap.
Intel Core i9-9900k (Silicon Lottery 5.1GHz @ 5.3GHz 1.36 VCore)
ASUS ROG MAXIMUS XI APEX
G.SKILL F4-4000C19D-32GTZSW (2x16GiB 4000MHz 19-19-19-39 2T, tuned to 4133MHz 14-17-17-31 2T)
EVGA NVIDIA GeForce GTX 1080 Ti FTW3
Seasonic PRIME 1300W 80+ Platinum
ssateneth is offline
post #8 of 170 (permalink) Old 08-06-2019, 07:55 PM
skupples's Avatar
yeaaap, i found out the hard way what LM can do to a CPU warranty, though I never saw it increase temps... I can confirm it'll pit copper over time though. I believe its the galium or whatever?
post #9 of 170 (permalink) Old 08-06-2019, 08:06 PM
Overclocker in training
ThrashZone's Avatar
Rep: 65 (Unique: 51)
Hi,
Take apart the water block see what thickness razor blade jet plate is in it and the block should of came with an extra
Swap for the thinnest
Block is suppose to bend to conform with any imperfections on the chip or so they say.
Otherwise do the spin test with the chip on a piece of glass see if it take off or stops pretty quickly
If it want to take off rma the chip.
i9-9940x With Heatkiller IV Pro Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #10 of 170 (permalink) Old 08-06-2019, 08:22 PM
skupples's Avatar
I thought EK was shipping them per SKU these days... Meaning, assuming he purchased the "correct" kit, the correct plate should already be in there for his chip. Either way, jet plates affect temp by a few degrees these days & the newest intel series has a giant plastic insert instead of the razor plate!
I still love the sexiness of my all copper supremacy over this modern all metal black block i got.
