Single D5 pump handle this? - Page 3 - Overclock.net - An Overclocking Community
post #21 of 23 (permalink) Old 08-09-2019, 05:59 PM - Thread Starter
Cobra26's Avatar
Rep: 8 (Unique: 6)
Quote: Originally Posted by zGunBLADEz View Post
You mean perf wise? The phobya is the best big rad out there if you can find one and the less restricted of the big ones.
The only way a mora will win if you go in a push/pull config and not by much. Bundy review it only with a 9 fan configuration. They have plates or you can build one for push/pull. This is the best piece of water cooling i have bought so far. I dont even need to run fans at full speed lol. Those 140mm white fans are quiet as hell on low volts. Inexpendive too artic cooling f14.
No not the performance i meant the water flow rate of these Phobya radiators they should be average. No doubt these Phobya rads cools very well
Cobra26 is offline
post #22 of 23 (permalink) Old 08-09-2019, 06:57 PM
Vermin Supreme 2020
skupples's Avatar
Rep: 737 (Unique: 388)
i have a fear of Phobya ever since two of three splitters went up in smoke.
Add me on Steam, same name
skupples is offline
post #23 of 23 (permalink) Old 08-10-2019, 05:07 PM
zGunBLADEz's Avatar
Rep: 105 (Unique: 76)
No not the performance i meant the water flow rate of these Phobya radiators they should be average. No doubt these Phobya rads cools very well [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
But like i said you be fine.. best way is to compare ambient vs water temp that tells you more than your flow rate. Use gpu as a template too dont rely on cpu as this are too tricky to measure.
. Cables? Fan splitters?
I mean their logo is "fear" lol
zGunBLADEz is offline
