Any idea what this is inside my block? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 23 (permalink) Old 08-09-2019, 04:31 PM - Thread Starter
Work Hard Play Hard!
merlin__36's Avatar
Rep: 0
Quote: Originally Posted by ciarlatano View Post
Do yourself a favor and order a Mayhems Blitz Kit (parts 1 & 2) like @skupples suggested. Or a Part 2 at the absolute very least. Sysprep is fine (as in not good....but ok if it's all you can get your hands on) for unused parts after cleaning the rads, but does little to nothing for abnormal fluid situations. You're likely just going to be saying "why is this stuff coming back?" after you refil by using only Sysprep.
I will order some looks like $50 for the kit does that sound right?
2600k 5.3Ghz
8700k 5.2Ghz
The New New
(8 items)
Half X
(9 items)
I9-9900k
ASUS ROG Maximus XI Formula LGA1151 (Intel 8th and 9th Gen) ATX DDR4 HDMI M.2 USB 3.1 Gen2 Z390 Gaming Motherboard
RTX 2080 TI
Corsair LPX 32GB DRAM 3000MHz C15
Samsung 970 EVO Plus Series - 1TB PCIe NVMe - M.2 Internal SSD (MZ-V7S1T0B/AM)
CORSAIR HXi Series, HX1200i, 1200 Watt, 80+ Platinum Certified, Fully Modular - Digital Power Supply
EKWB EK-KIT Extreme Series PC Watercooling
CORSAIR Crystal Series 680X RGB High Airflow Tempered Glass ATX Smart Case, White
I7-8700K Delidded under a Swiftech Waterblock
ASUS ROG LGA1151 (Maximus X Hero)
EVGA GTX 1080 TI FE With XSPC Razor Waterblock SLI
Asus GTX 1080 TI FE With XSPC Razor Waterblock SLI
Corsair LPX 32GB 3000MHz C15 DDR4
Samsung 970 EVO 1TB - NVMe PCIe M.2 2280 SSD
Corsair Platinum HX1200i
XSPC 270mm D5 Pump and Rez
XSPC EX360 Radiator
XSPC EX240 Radiator
Nzxt H440 Mid Matt Black/Red/w Window
34" Alienware IPS AW3418HW Curved
I7-2600K
Asus P8Z68 Deluxe/ GEN3
Titan X Pascal
Corsair Vengeance Pro Series 32GB DDR3 1600MHz C9
Samsung 850 Pro 1TB SSD
Silent Gold Power
Corasir h100
Cooler Master HAF X Full Tower
34" Alienware IPS AW3418HW Curved 160hz
merlin__36 is offline
post #12 of 23 (permalink) Old 08-09-2019, 05:24 PM
Vermin Supreme 2020
skupples's Avatar
Rep: 737 (Unique: 388)
depends where you're ordering it from. It's usually ~$40 state side.
make sure you get the biocide and corrosion inhibitor drops as well. (two bottle set) they're the least expensive high, most reliable coolant option on the market right now. Just add a few drops per gallon, then follow directions for upkeep, and you're good to go. The droppers should last the rest of your water cooling career.
https://www.overclock.net/forum/61-w...sers-club.html
Mick, the owner has been here on OCN from the nearly the inception of his company. He's just now gone "big time" and by that I mean AIO manufacturers and other coolant manufacturers are now buying his stuff by the oil barrel to replace the garbage in house solutions they keep cooking up. The man's gone toe to toe with companies like GALAXY, etc that've accused his showroom coolants of being snake oil... all dispelled with science, & proof.
Reading through his thread will show you just how many times things like this have happened, and just how many times mayhem's X1, etc products have resolved the issue.
Add me on Steam, same name
skupples is offline
post #13 of 23 (permalink) Old 08-15-2019, 02:54 PM - Thread Starter
merlin__36's Avatar
Rep: 0
I got the pro kit in the mail ran #1 in just the radiators and now running #2 in the system with just the pump running. Not sure it's going to get that stuff put of the block for the gpu. I bet it's old dye coloring from the used radiator i put in the system.
Picture is a couple hrs of running with #2 in it. Going to run the full 24 hr max time it says i can do 12-24 hours.
Since the #1 solution doesn't go into the gpu waterblocks just the radiators it didn't disolve this stuff.
Hard going multiple days without the pc.
Took the free time to order a set of compression fitting.
Oh yeah kinda weird the instructions that came with his cleaning kit say 50 ml of #1 and 950 distilled water the bottle label says 250ml #1 and 750ml distilled water.
2600k 5.3Ghz
8700k 5.2Ghz
The New New
(8 items)
Half X
(9 items)
I9-9900k
RTX 2080 TI
XSPC EX360 Radiator
XSPC EX240 Radiator
I7-2600K
Titan X Pascal
Silent Gold Power
Corasir h100
post #14 of 23 (permalink) Old 08-15-2019, 09:40 PM
EKWB Forum Rep
EKJake's Avatar
Rep: 18 (Unique: 12)
Quote: Originally Posted by merlin__36 View Post
I just added a new video card to my loop and i reused the coolant that was in the system that consisted of Distilled water and Primo Chill Utopia all clear liquids but before putting it back in i added some Ek Cryo Fuel clear concentrate to the mix and it started clouding instantly.
Not sure if the two Eutopia and the Cryo Fuel are having a reaction or if there was something in the loop that was killed?
Any ideas?
Oh i also added a used radiator to the system.
I've seen it happen initially and go away as everything fully mixes together in the system. However, if the issue persists, please contact our support team or RMA through the original retailer you ordered with.
Quote: Originally Posted by ThrashZone View Post
Hi,
Can't disappoint
But clear concentrate isn't supposed to be bad just the premix :/
@EKJake was around yesterday post image of the batch ....
Thanks for tagging me!
EKWB Forum Rep
EKJake is offline
post #15 of 23 (permalink) Old 08-16-2019, 08:29 AM
Rep: 1 (Unique: 1)
Use Coca cola. Clean all.
Then lots of destilled water to remove everything.
Mordorr is offline
post #16 of 23 (permalink) Old 08-16-2019, 08:32 AM
Vermin Supreme 2020
skupples's Avatar
you're referring to the tiny bit of "dry" looking white stuff above the fins? I wouldn't worry about it at this point. Only way to get that out would be by breaking it down & hand cleaning.
skupples is offline
post #17 of 23 (permalink) Old 08-16-2019, 08:57 AM - Thread Starter
merlin__36's Avatar
Rep: 0
Day 2 of the Mayhems cleaning 5 hrs left until the 24hr max run time for the cleaner.
I made all new water lines for the system while cleaning the reserviors.
The gpu block is cleaning up some but i don't think it's going to disolve it all.
2600k 5.3Ghz
8700k 5.2Ghz
The New New
(8 items)
Half X
(9 items)
I9-9900k
RTX 2080 TI
XSPC EX360 Radiator
XSPC EX240 Radiator
I7-2600K
Titan X Pascal
Silent Gold Power
Corasir h100
post #18 of 23 (permalink) Old 08-16-2019, 09:23 AM
Shawnb99's Avatar
Rep: 66 (Unique: 47)
Hi,
Can't disappoint
That’s a good pic. I like mine as well. This is 6 months of the clear premix. That’s what I get for not checking on it.
No idea what that is. Was all EK gear. I did do a poor job cleaning the radiators but still.
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is online now
post #19 of 23 (permalink) Old 08-19-2019, 05:38 AM
Ashcroft's Avatar
Rep: 92 (Unique: 72)
You can't mix chemicals willy nilly unfortunately. Just like mixing two different types of automotive coolant fluid can react and cause severe gunking of a cars cooling system.
Don't bother with more mystery chemical flushing systems. Just do it right, dismantle the loop and blocks for a thorough hand cleaning. flush out the rads and start again.
I have used both Liquid Utopia for many years with great success and more recently the EK clear coolant with no problems but when changing from one coolant to another you should always flush the system thoroughly or even better dismantle and manually clean everything.
Ashcroft is offline
post #20 of 23 (permalink) Old 08-20-2019, 07:38 PM - Thread Starter
merlin__36's Avatar
Rep: 0
Up and running again! Thank you for the help.
Mayhem UV Blue.
2600k 5.3Ghz
8700k 5.2Ghz
The New New
(8 items)
Half X
(9 items)
I9-9900k
RTX 2080 TI
XSPC EX360 Radiator
XSPC EX240 Radiator
I7-2600K
Titan X Pascal
Silent Gold Power
Corasir h100
