Need help for setting drain port in my pump/res combo - Overclock.net - An Overclocking Community
post #1 of 21 (permalink) Old 08-09-2019, 07:25 PM - Thread Starter
ViTosS's Avatar
Rep: 8 (Unique: 6)
Hello guys, this is the first time I will water cool CPU and GPU, and I'm gonna be using the EK D5 pump and res combo unit, I see that there are only 2 ports (IN and OUT), so I need to connect a T splitter and a ball valve in the OUT port of the pump? I will show in the imagem below:
I need to connect the whole T splitter pluged with the ball valve in the OUT section of the pump like in the image bellow? And last question, how many fittings will I need for that? There are 3 fittings in the image that I can see (?), each one for each side of the T splitter?
My gaming rig
(12 items)
i7 [email protected] 1.305v full load delid
Asus Maximus XI Apex Z390
MSI GTX 1080Ti Gaming X
2x8GB G.Skill TridentZ RGB [email protected] 1.35v XMP
Samsung 1TB EVO Plus NVMe M2
Corsair AX860
Corsair H150i Pro
Corsair 275R
Acer XB271HU 1440p 165hz IPS G-Sync
Keyboard
HyperX Alloy FPS Pro
Mouse
Glorious Model O-
Mousepad
Zowie GS-R
ViTosS is offline
post #2 of 21 (permalink) Old 08-09-2019, 07:33 PM
KCDC's Avatar
Rep: 28 (Unique: 23)
Either will work, but I believe you will have better system drain if you have your drain port on your inlet. I've had mine on my outlet, and once the res drains, it takes more work to get the rest of the system to drain. For your t-fitting, you'll need a male-to-male spacer/extender between the fitting and the inlet/outlet on your pump/res combo, the other side will use the fitting's thread. If you have a little extra cash, a dataVac blower really helps when it comes to draining your system. Otherwise, you'll be blowing air yourself and that's faint-inducing.
EDIT: When draining and you start to blow, or use a blower, don't make the mistake I made (and probably half the peeps here) and leave one of my other ports open, like on the top of the res. It will shoot out like a geyser.
ZMT watercool setup -- Phanteks Enthoo Elite -- hwlabs gtr 420 x 2 -- -- xspc tx360 crossflow -- noctua A14 PWM x9 -- 10940x -- Rampage VI Extreme Encore
Optimus Signature V2 -- 64gb 3200 tridentZ Royal CL14 @3600 CL16 -- AX1500i -- 2x 7600p nvme -- EK ZMT Tubing -- Ek Fittings -- dual Aorus Waterforce xtreme 2080ti -- asus PG279UZ monitors x3 7680x1440 surround
Bertha5.5
(22 items)
9900x
X2399 TUF Mk1
Aorus 2080ti Waterforce Xtreme
TridentZ Royal 3200 CL14
VROC 7600P x2
Ax1500i
HWL GTR 420 x2
XSPC TX360 Crossflow
EK ZMT 10/16
Corsair XC9
Corsair XD5
EK 10/16 Fittings
Noctua A14 PWM x9
Noctua NF-P12 PWM redux x3
Corsair Commander Pro
Enthoo Elite
Operating System
Win 10 Pro 64
Asus PG279QZ x3
Keyboard
Corsair K95 RGB Platinum
Mouse
Corsair Nightsword
Mousepad
Corsair MM800
KCDC is offline
post #3 of 21 (permalink) Old 08-09-2019, 07:47 PM
Vermin Supreme 2020
skupples's Avatar
Rep: 737 (Unique: 388)
omg, why have I never thought of using my datavac...
Add me on Steam, same name
skupples is offline
post #4 of 21 (permalink) Old 08-09-2019, 07:57 PM
KCDC's Avatar
Haha! When I put two and two together, I stopped dreading the drain process. I got the extra fittings package just to get the one that fits almost perfect.
Bertha5.5
(22 items)
9900x
X2399 TUF Mk1
VROC 7600P x2
Ax1500i
HWL GTR 420 x2
EK ZMT 10/16
Corsair XC9
Corsair XD5
EK 10/16 Fittings
Noctua A14 PWM x9
Enthoo Elite
Operating System
Win 10 Pro 64
Asus PG279QZ x3
Keyboard
Mouse
Corsair Nightsword
Mousepad
Corsair MM800
KCDC is offline
post #5 of 21 (permalink) Old 08-09-2019, 08:03 PM
Vermin Supreme 2020
skupples's Avatar
=\ i've gotta install a new board this weekend, n my datavac is off in storage somewhere... Maybe i'll just use the shopvac to suck it out instead.
skupples is offline
post #6 of 21 (permalink) Old 08-09-2019, 08:19 PM
KCDC's Avatar
FYI, I didn't use it to suck it out, but to blow it out. Your shop vac should be fine with the liquid, but a DataVac would probably fail if it's sucking the fluid out through the vacuum. Also, since a shopvac is way more powerful, I;d be wary of the pressure, but that's just speculation.
Bertha5.5
(22 items)
9900x
X2399 TUF Mk1
VROC 7600P x2
Ax1500i
HWL GTR 420 x2
EK ZMT 10/16
Corsair XC9
Corsair XD5
EK 10/16 Fittings
Noctua A14 PWM x9
Enthoo Elite
Operating System
Win 10 Pro 64
Asus PG279QZ x3
Keyboard
Mouse
Corsair Nightsword
Mousepad
Corsair MM800
KCDC is offline
post #7 of 21 (permalink) Old 08-09-2019, 08:24 PM - Thread Starter
ViTosS's Avatar
Rep: 8 (Unique: 6)
And I don't need any fitting to plug the ball valve into the T splitter? Also where would I need to blow, sorry if I didn't understand correctly but I blow in a flex tube connected to where?
Thanks.
Edit.: When you mean blow is ''sucking'' the rest of the fluid with my mouth throught the ball valve?
My gaming rig
(12 items)
Corsair AX860
Corsair H150i Pro
Corsair 275R
Keyboard
Mouse
Glorious Model O-
Mousepad
Zowie GS-R
ViTosS is offline
post #8 of 21 (permalink) Old 08-09-2019, 08:40 PM
KCDC's Avatar
Thanks.
You are correct, you'll need two male-to-male extenders, one to your res and one to the drain port. My mistake.
When draining the system, with a tube length attached to the drain port to a tub or something, open the top of the res to alleviate the pressure, then open the drain and let physics do its thing. It will eventually lock up, so once one section seems empty, you can open a port, for me this is one of the unused top ports on my gpu block, attach a hose with fitting to that port (this is where you would either blow in or attach a blower), make sure all other ports are closed except for the drain port and begin the blowing process. Scary at first, but as long as you only have the two open (port that you're blowing to and drain that your coming out), you won't have water going all over your system. I still cover every area with paper towels to be safe. Save them for other crap if they don't get soiled. The pressure will release out the tube length into whatever you're using to collect the fluid, so best to keep it away from your computer, and lower for gravity to help. It takes time and depending on your tubing, rads and blocks can be a bit frustrating.
Bertha5.5
(22 items)
9900x
X2399 TUF Mk1
VROC 7600P x2
Ax1500i
HWL GTR 420 x2
EK ZMT 10/16
Corsair XC9
Corsair XD5
EK 10/16 Fittings
Noctua A14 PWM x9
Enthoo Elite
Operating System
Win 10 Pro 64
Asus PG279QZ x3
Keyboard
Mouse
Corsair Nightsword
Mousepad
Corsair MM800
KCDC is offline
post #9 of 21 (permalink) Old 08-09-2019, 08:48 PM - Thread Starter
ViTosS's Avatar
Rep: 8 (Unique: 6)
I think I understood now, after I drain the most I can without blowing (not sucking) throught the ball vale port, I detach the GPU fitting and plug a flex tube there (only when I see there is no more fluid in that tube and also on the block of the GPU, right?) and start to blowing? In my case I pretend to make my loop exact like this guy has done his, the only difference is that I'm gonna mount my GPU normally (not vertically), so I would detach one of that fittings (need to be the IN our OUT of the GPU block or it doesn't matter?) and plug the tube and blow?
Thanks for your help.
My gaming rig
(12 items)
Corsair AX860
Corsair H150i Pro
Corsair 275R
Keyboard
Mouse
Glorious Model O-
Mousepad
Zowie GS-R
ViTosS is offline
post #10 of 21 (permalink) Old 08-09-2019, 09:02 PM
KCDC's Avatar
Correct, keep the tubes connected to the gpu, but on the opposite side, open one of those ports, keeping in mind there could still be fluid coming out, every system is different and I haven't done a vertical mount before. It's section by section. Once the gpu area is drained enough, you can disconnect it from the rad or cpu, then do the same from that section.
Bertha5.5
(22 items)
9900x
X2399 TUF Mk1
VROC 7600P x2
Ax1500i
HWL GTR 420 x2
EK ZMT 10/16
Corsair XC9
Corsair XD5
EK 10/16 Fittings
Noctua A14 PWM x9
Enthoo Elite
Operating System
Win 10 Pro 64
Asus PG279QZ x3
Keyboard
Mouse
Corsair Nightsword
Mousepad
Corsair MM800
KCDC is offline
