cpu block horror pics :) also need cleaning advice - Page 2 - Overclock.net - An Overclocking Community
post #11 of 18 (permalink) Old 08-12-2019, 05:59 AM
Watercooler
Socks keep you warm's Avatar
Rep: 145 (Unique: 124)
Get a toothbrush out and some vinegar. It may well stay visually disgusting but it will work.
I had a 290X block with the nickel eaten away yet still performed amazingly. Most water cooling crap is just visual. By the time it actually degrades performance it will be in the bin and beyond its service life anyway.
I like to have fun.
https://stats.foldingathome.org/donor/110855
https://www.trueachievements.com/gamer/II+TH3PRO+II
16 Threads is Good
(10 items)
Intel Core I9 9900K 4.8Ghz
Gigabyte Aorus Elite
Aorus 2080Ti Xtreme Waterforce WB 11GB
Trident Z
Samsung 250 SSD
Cooler Master Silent Pro Hybrid
Watercooling Custom
900D
Operating System
Windows 10 x64
28" ACER 4K Monitor
Socks keep you warm is offline
post #12 of 18 (permalink) Old 08-12-2019, 07:32 AM
zGunBLADEz's Avatar
Rep: 105 (Unique: 76)
Boiling the cooper on hot water will get all that junk out then you can polish it with mothers so it dont look bad. Trust me thats what i do with cooper/brass when im going to do plating on them.. it will take out all that crap but you have to let it boil and scrub rinse and repeat. 30min 1hr just let it boil. It would not damage it.
Mother cream will take care of the leftovers.
zGunBLADEz is offline
post #13 of 18 (permalink) Old 08-12-2019, 10:28 AM - Thread Starter
jamsomito's Avatar
Rep: 1 (Unique: 1)
Thanks everyone.
But what do you think about that scratch I made on the copper under where the o-ring sits between the plate and the top? I'm still thinking about hitting the whole face with some sandpaper and working up through the grits to get rid of it. Just don't want any leaks.
jamsomito is offline
post #14 of 18 (permalink) Old 08-12-2019, 10:52 AM
Otherworlder
epic1337's Avatar
Rep: 227 (Unique: 131)
sanding it will only make it worse.
just do a pressure test later.
trolling an adult is very dangerous, don't try it at home nor at work. you don't want to play tag with a rabid man.
epic1337 is offline
post #15 of 18 (permalink) Old 08-13-2019, 06:17 PM
MrGrievous's Avatar
Rep: 10 (Unique: 8)
Isn't Pastel max coolant life 2-3 years? I have been using Mayhems X1 coolant since I started watercooling in 2013 with annual coolant flushing as the stuff lasts 1 year. But when I flush my loop and inspect the water channels and fins its all in pristine condition with no buildup at all.
MrGrievous is offline
post #16 of 18 (permalink) Old 08-13-2019, 07:12 PM
Vermin Supreme 2020
skupples's Avatar
Rep: 737 (Unique: 388)
Quote: Originally Posted by jamsomito View Post
Thanks everyone.
i'd guess its fine.
Add me on Steam, same name
skupples is offline
post #17 of 18 (permalink) Old 08-14-2019, 02:21 AM
Moderately Ancient
Andrew LB's Avatar
Rep: 27 (Unique: 22)
I'd soak it in a solution of citric acid (only with unplated blocks) or Mayhem's Blitz part 1, which is phosphoric acid + surfactant, etc. If you use the latter, heed Mayhem's warning. Also, if you let it soak too long you'll begin to turn the liquid blue. This is copper acetate and when disposed of, dilute with plenty of water.
Intel i7-10700K @ 5.2 - Asus Prime z490-A - EVGA GTX 1080 - 32gb Corsair DDR4 3600mhz - Creative X-Fi Titanium HD - Adata 1tb M.2 - Samsung 512gb 860 Evo + 512gb 850 Evo - Phanteks Enthoo Pro M - Watercool DualDDC Top - 2x DDC1-T PWM 10w Pumps - XSPC Raystorm V3 CPU block - AquaComputer Pascal block - Barrow Tube Res - XSPC ex360 Rad w/3x Fractal Venturi 120mm fans - XSPC ex280 Rad w/2x 140mm Phanteks 140mm fans - Aquaero 5LT + Flow Meter - 14mm Barrow Fittings - Crystal-Link Acrylic Tubing
Andrew LB is offline
post #18 of 18 (permalink) Old 08-19-2019, 05:49 AM
Ashcroft's Avatar
Rep: 92 (Unique: 72)
Thanks everyone.
A scratch under the oring will be fine. It would have to be a severe gouge before the compressed oring couldn't seal it.
Ashcroft is offline
