Serious talk: Building an AM4 system - Hear my thoughts and tell me your recommendations - Page 2 - Overclock.net - An Overclocking Community
post #11 of 14 (permalink) Old 08-13-2019, 12:48 PM
Shooting down fallacies
ciarlatano's Avatar
Rep: 452 (Unique: 299)
Quote: Originally Posted by AlphaC View Post
If the working fluid lubricates the system it means you're not lubricating a motor yourself...
How many actual D5 failures have you been reading about versus aftermarket D5 PWM modded pumps , Swiftech MCP series other than the 655, Alphacool VPP755, or SPC-60 MX pumps?
There's a reason the Laing/Xylem/Lowara D5 pump is the standard for open watercooling loops.
There are also many reasons it is widely used in critical applications in a large number of fields from medical, to solar panels to commercial HVAC and jockey pumps. One of the major points is the reliability and longevity of the D5 design.
ciarlatano is offline
post #12 of 14 (permalink) Old 08-13-2019, 12:49 PM
Newb to Overclock.net
mouacyk's Avatar
Rep: 173 (Unique: 128)
Op is overthinking it. Due to the packaging decision of current CPUs with their shrinking die size resulting in immense heat density, there isn't much one can do with ambient cooling to counter it. The heat transfer itself now is the bottleneck, and will need dramatically different packaging designs to alleviate it, such as the JetCool method: https://www.jetcool.com/technology
Engineer all you want, but the precision required now to achieve any kind of meaningful impact requires a lab, with lots of money, and maybe some new magical materials too.
CPU: Q6600 X5470 2100T 1680V2 9900K
GPU: 8800GT 9800GTX+ 750Ti 1080Ti
RAM: 2x8GBTZ
Gentoo64 in Water
(14 items)
LGA775 X5470
(6 items)
9900K 5GHz 1.224v
EVGA Z370 Micro
MSI 1080TI GXEK 2100.5/12627
16GB Trident Z 4000C16
970 EVO 500GB
Seasonic X850 Gold
480mm Radiator Custom
Silverstone FT03
Operating System
Windows 7 Ultimate 64-bit
Operating System
Gentoo Linux 64 Multi-Lib
Acer Predator XB271UH 165Hz
Keyboard
Logitech G710+
Mouse
Logitech G502
Audio
Sound Blaster Z
X5470 4GHz (stock v)
GA-EP45-UD3P
EVGA 9800 GTX+ 512MB
8GB 4x2GB GSkill 1066MHz DDR2
XSPC Rasa, D5 + Res, 240mm Rad
Lian-Li PC7-HX
mouacyk is online now
post #13 of 14 (permalink) Old 08-15-2019, 10:27 AM - Thread Starter
Rep: 0
Thanks again for the replies. Good links to get to research more. From a couple of benchmarks i've seen Aqua Computer makes good products as well right?
St0RM53 is online now
post #14 of 14 (permalink) Old 08-15-2019, 10:42 AM
Rep: 2 (Unique: 2)
Quote: Originally Posted by andrewmp6 View Post
The best cpu block on the market for cooling is heatkiller with some like xspc coming close 2nd.
+1 for Heatkiller. They are beefy and well made. Holding one will really make you appreciate the craftmanship. The benchmarks dont lie either, good stuff.
appylol is offline
