coolant temp vs ambient, whats your delta? - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 08-12-2019, 12:27 PM - Thread Starter
jimmyhackers's Avatar
Rep: 1 (Unique: 1)
ive been faffing with my watercooling recently.....and im wondering what everyone else is getting?
im only cooling my 3770k cpu (no GPU in loop), im using a 360mm XSPC rad, with a cheap pump/reservoir (300L/h apparently) and a corsair h100 cpu block with its internal pump removed.
the difference between my coolant and ambient air temp is about 1-2 degrees C at idle and about 3-5 at full cpu load on a normalish fan curve. Switching my rad fans to 100% I drop about 1 degree off of each previous max tempreture.
the delta between my in and out of my radaitor is 0.5C at idle and about 1c under load. these figures didnt really change under 100% rad fan
ive noticed about a 20c delta between my cpu and my coolant at idle and about 25-30c under load.
what is everyone else getting?
heres the pump. its not too bad. a lot better flow rate than the h100 internal one was.
https://www.ebay.co.uk/itm/DC-Ultra-...sAAOSwqo5bdZSh
jimmyhackers is offline
post #2 of 8 (permalink) Old 08-12-2019, 12:59 PM
Vermin Supreme 2020
skupples's Avatar
Rep: 737 (Unique: 388)
do you have a flow sensor?
those are just "ok" temps, based on my own experience with radiator overkill.
Add me on Steam, same name
skupples is offline
post #3 of 8 (permalink) Old 08-12-2019, 01:49 PM
SubZero is the Goal
HardheadedMurphy's Avatar
Rep: 73 (Unique: 63)
Right now my temps are not normalized. I have my 9600k at 4.8Ghz and my 1080 on the same loop with a single 360mm radiator, with a phobya dc12-400 pwm pushing the loop, add to it one of the hottest summers on record and folding ...
There is roughly a 3degree celsius differential from ambient temps, coolant flow being on the warmer side.
I'm at work at the moment, but will post temps when I get home from the foundry tonight.
Sent from my OnePlus 7 Pro using Tapatalk
"It is impossible to defeat an ignorant man in an argument" McAdoo
Peace begins when we care about someone other than ourselves.
"Hell is still Overburdened, I must stand and wait in line" Disturbed
The Beast
(23 items)
MiniFurnace
(10 items)
ThinClient
(5 items)
i5-9600k
ASRock Z390 Taichi
EVGA GeForce GTX 1080 FTW Hydro Copper GAMING, 08G-P4-6299-KR, 8GB GDDR5X, LED, DX12 OSD Support (PXOC)
EVGA GeForce GTX 970 04G-P4-2974-KR 4GB SC GAMING w/ACX 2.0, Silent Cooling Graphics Card
Corsair Vengence RGB Pro
Mushkin Enhanced Source M.2 2280
Toshiba
Optical Drive
LG Bluray RW
Rosewill Quark
Barrow RGB 115X CPU Block
EK-360 Radiator
Phobya 12v DC PWM Pump
Black Ice Nemisis 240mm stealth Rad
Alphacool 5.25 pump / resivoir combo DC-LT
Phobya Balancer 250mm Res - Black Nickle
Corsair Obsidian 900D
Operating System
Windows 7 Professional
LG 34" Ultrawide IPS 21:9
HP 27xw ips
HP 27xw IPS
Keyboard
Corsair Strafe RGB MX Silent
Mouse
Corsair M65 Pro RGB
Audio
Corsair Void Pro RGB
Xeon 5300
Xeon 5300
Dell 2950 v3 Server
ECC DDR2 RAM
Hitachi 1tb 7200rpm
Optical Drive
SLIM DVD-RW
redundant 750w
OEM
Operating System
Windows Server R2
Other
DRAC 6/i
Celeron N2930
G.Skill 8gb 204 pin
Seagate 500gb 2.5"
Zotac Zbox CI320 Nano
Operating System
Win 10 Pro
HardheadedMurphy is offline
post #4 of 8 (permalink) Old 08-12-2019, 02:38 PM
NewUser16's Avatar
Rep: 56 (Unique: 37)
6950X at 4.5 and 3 x Titan Black SC ambient 24C.
Dual loop each 2x 480 Nemesis Black Stealth Edition. Each loop is configure to run the same flow rate 102-105 l/h for silent's with Noctual NF-F12 PWM chromax running at lowest speed 5.2V.
Delta in both loops is 1-2C and if room temp goes higher say 25-26C , fans spin faster but system is still extremely silent, pumps are tweaked for MAX silents, delta stays the same 1-2C.
I should add, on load delta in each loop stays at 8-10C at MAX, fans will go up to 7-9V and water in each loop never goes higher then 31-34C
With the rads I have I can run pretty much passive cooling... I am all about silents
NewUser16 is offline
post #5 of 8 (permalink) Old 08-12-2019, 03:18 PM
professional curmudgeon
looniam's Avatar
Rep: 839 (Unique: 465)
i7-3770K and 980ti both OCed on a little ek CE280 (PE 280 kit w/vga supremacy)
idle
~12-15 minutes of full stressing aida64
though aida really hammers the cpu, my block is probably filthy. never cleaned it in ~4 years.
Remember the golden rule of statistics: A personal sample size of one is a sufficient basis upon which to draw universal conclusions.
If you need help: Upload the computer to Dropbox and provide a link to it so others may download it to examine and give advice for repairs.
loon 3.2
(18 items)
i7-3770K
Asus P8Z77-V Pro
EVGA 980TI SC+
16Gb PNY ddr3 1866
PNY 1311 240Gb
1 TB Seagate
3 TB WD Blue
Optical Drive
DVD DVDRW+/-
EVGA SuperNova 750 G2
EKWB P280 kit
EK-VGA supremacy
Stryker M [hammered and drilled]
Operating System
Win X
LG 24MC57HQ-P
Keyboard
Ducky Zero [blues]
Mouse
corsair M65
Audio
SB Recon3D
Audio
Klipsch ProMedia 2.1
looniam is offline
post #6 of 8 (permalink) Old 08-12-2019, 04:30 PM
NewUser16's Avatar
idle
Attachment 288592
Attachment 288594
Nice breakdown and good temps
post #7 of 8 (permalink) Old 08-12-2019, 04:59 PM
looniam's Avatar
thanks you.
i'm better when i keep things simple.
loon 3.2
(18 items)
i7-3770K
Asus P8Z77-V Pro
EVGA 980TI SC+
16Gb PNY ddr3 1866
PNY 1311 240Gb
1 TB Seagate
3 TB WD Blue
Optical Drive
DVD DVDRW+/-
EKWB P280 kit
EK-VGA supremacy
Operating System
Win X
LG 24MC57HQ-P
Keyboard
Ducky Zero [blues]
Mouse
corsair M65
Audio
SB Recon3D
Audio
looniam is offline
post #8 of 8 (permalink) Old 08-12-2019, 05:59 PM
Moose-Tech's Avatar
Rep: 9 (Unique: 9)
Sytem Specs below. These are the results from a recent stress test I ran.
TEMPS (15 min Avg) Pump 100%
Ambient - 22.76
Loop Delta_T - 13.5
Rad Delta_T - 1.0
Loop Temp - 36
Watts Removed - 320.7
Flow (l/h) - 268
Fan Speed % - 85%
CPU Max - 68.5
CPU Avg - 66.3
GPU HOTspot - 65.1
GPU Temp - 43.2
HWI CPU MAX Absolute Max - 69
HWI GPU Hot Spot Absolute Max - 68
VRAM / MOS Absolute Max - 80
Heat Stress test consists of these test utilities:
'Heavy Load' running on CPU only
FurMark' set on Full Screen 3840x2160 Stress Test (Anti-aliasing off)
All temps taken at 30 minute mark
Intel - Core i7-9700K 4.9 OC
AMD Radeon VII Video Card 1950mhz OC (HBM 1200mhz OC)
Build: Z390 ACE
Core i9-9900K OC 5 GHz, MSI Z390 ACE Mobo, AMD Radeon VII GPU OC 2K MHz
Corsair Vengeance RGB 32GB 3200 RAM, Phanteks Enthoo Pro M SE.
EKWB Z390 ACE Monoblock, Bykski Radeon VII GPU w/b, 2x EKWB 140 Revo D5 Pump & Res.
Aquacomputer Aquaero 6 LT USB Fan-Controller, Quadro, Vision Touch and 'High Flow' Sensor.
(2x) HWL Black Ice Nemesis 280 GTS XFLOW and (1x) Alphacool XT45 X-Flow 280 radiators.
Moose-Tech is offline
