So here is my 6+ year old CPU 380A block - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 08-13-2019, 04:58 PM - Thread Starter
Cobra26's Avatar
Rep: 8 (Unique: 6)
Hi all,
So it was time to tear down my secondary pc for cleaning...upon further inspection it wasn't really needed. The block came out clean no oxidation no gunking almost as if brand new! This is a 6+ year old cpu block that i opened up for cleaning around 3 years ago same deal spotless clean. It just boggles me when people have issues in just under 6 months when using distilled water + silver kill coil or other pre mix coolants. I am using only Koolance 702 coolant and it kept everything clean including my fittings and their threads.
There is some feedback against the usage of pre mix coolant well this is true for some of the pre mix coolants out there. But this one is just excellent no regrets the only downside it is pretty expensive for a 700ml bottle here in Europe a whopping 25 eur which translates to around 30 USA dollar a bottle! Here are some pics the photo's don't do it much justice but its the best i have i instantly took photos upon opening the nickel plated block (Koolance 380A):
Cobra26 is offline
post #2 of 6 (permalink) Old 08-13-2019, 06:50 PM
andrewmp6's Avatar
Rep: 15 (Unique: 14)
You used very high end coolant and a high end block for the time,The 702 you used is a great long term coolant but is a little pricey.I think a lot of problems people have are lack of cleaning the loop before use.Or used some junky coolant,Didn't do their homework and research on things before buying them.
andrewmp6 is offline
post #3 of 6 (permalink) Old 08-13-2019, 08:02 PM - Thread Starter
Cobra26's Avatar
Rep: 8 (Unique: 6)
I agree with you!
I did my research obviously cleaned flush all my parts before use including my tubing that i flushed as well.
Ive seen nickel plated blocks start to oxidize within 6 months or less then i read what they were using as coolant....or no flush or both...
Then we have people who advise against pre mix coolants (depending on what type of pre mix coolant). But to me this long term 702 from Koolance is working like a charm and keeps nickel plated blocks clean even after years of non stop usage. Better KNOCK on wood!
People do your self a favor ditch the colored coolant which may gung your blocks or worse oxidize it at a fast rate.
Cobra26 is offline
post #4 of 6 (permalink) Old 08-13-2019, 08:17 PM
cssorkinman's Avatar
Rep: 499 (Unique: 279)
I had the same block - used 8 dollars worth of 50/50 antifreeze for over 5 years , the only thing I found in the fins were tiny bits of the black coating the radiator had on it.
Ryzen Shine!
(15 items)
Ryzen 1800X @ 4125mhz 1.432 Volts
MSI X370 Titanium
Fury
Sapphire Nitro + 5700XT
G.SKILL TridentZ Series 32GB (4 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Desktop Memory Model F4-3200C14Q-32GTZ
Samsung 850 pro
Optical Drive
Hp 1260 I
PC power and cooling 910 watt silencer
liquid unobtanium Koolance 480mm radiator, 390 block - 3/4 OD tubing
Thermaltake P5
Operating System
Win 7 HP/Winspy 10 64bit
24" hp @ 1900x1200
Keyboard
Logitech G19
Mouse
Logitech MX 518
Mouse
fUnc industries
cssorkinman is offline
post #5 of 6 (permalink) Old 08-13-2019, 08:48 PM - Thread Starter
Cobra26's Avatar
Rep: 8 (Unique: 6)
Heard great things with anti freeze if used properly i was to worry some to mess things up so i opted for lazy ie pre mix.
Cobra26 is offline
post #6 of 6 (permalink) Old 08-13-2019, 10:39 PM
Watercooler
Socks keep you warm's Avatar
Rep: 145 (Unique: 124)
Secondary PC with i take not much load on it. The hotter the water the faster bacteria grows. Also using a high end coolant works wonders. In my loop with a GPU aswell i had a gunk buildup with distilled water and kill coil after 1.5 years.
I like to have fun.
https://stats.foldingathome.org/donor/110855
https://www.trueachievements.com/gamer/II+TH3PRO+II
16 Threads is Good
(10 items)
Intel Core I9 9900K 4.8Ghz
Gigabyte Aorus Elite
Aorus 2080Ti Xtreme Waterforce WB 11GB
Trident Z
Samsung 250 SSD
Cooler Master Silent Pro Hybrid
Watercooling Custom
900D
Operating System
Windows 10 x64
28" ACER 4K Monitor
Socks keep you warm is offline
