What CPU water blocks would fit a Radeon 5700? - Overclock.net - An Overclocking Community
post #1 of 10 (permalink) Old 08-13-2019, 06:10 PM - Thread Starter
treetops422's Avatar
Rep: 24 (Unique: 18)
Yes I know price v performance etc, I enjoy tinkering more then gaming atm. No I don't want an all in one.
I plan to do a Kraken g12 type setup with an open loop. Waterblock+120mm pci fan for the vrm or an old cpu fan. But what cpu water blocks would fit out of the box? AM4? I'll fight with it if I have to, but I would rather not. I just need the holes to lineup and I'll handle the rest.
treetops422 is offline
post #2 of 10 (permalink) Old 08-13-2019, 07:23 PM
Heuchler's Avatar
Rep: 274 (Unique: 193)
Getting the Vapor Camper off using an oven and using the stock plate and shroud + universal GPU block.
I don't think CPU blocks have the correct spacing. Navi 10 should be 54mm x 54mm
R9-290X DCII with copper shims might work for a reference card.
Name:	R9-290X DCII - Acetal+Nickel.jpg
Overclocking History (Click to show)
Intel 386DX/16 @ 20 MHz
CX486SLC/50 @ 50 MHz
AM486DX2/80 @ 100 MHz
AM486 DX4-100 @ 120 MHz
AK5x86-P75 [email protected] 160 MHz
Pentium 90 @ 120 Mhz
IBM 6x86L P166+ [email protected] 160 MHz
Celeron 300a @ 454 MHz
Pentium 3 700 @ 933 MHz
Athlon XP 1400+ @ 1600 MHz
Athlon XP 1800+ @ 2088 MHz
Athlon XP 2500+ @ 2200 MHz
Athlon 64 3000+ @ 2603 MHz
Athlon X2 BE2300 @ 1900 MHz
Athlon X2 4200+ @ 2210 MHz
Athlon X2 5000+ @ 2600 MHz
Core 2 Duo E4300 @ 3000 MHz
Core 2 Duo E6750 @ 3600 MHz
Core 2 Duo E8400 @ 4000 MHz
Xeon C2Q L5408 @ 3200 MHz
Xeon C2Q X5450 @ 3300 MHz
Xeon C2Q E5440 @ 3400 MHz
Xeon C2Q E5450 @ 3600 MHz
Phenom2 X4 B50 @ 3700 MHz
Phenom2 X6 1045T @ 4050 MHz
Core i5-2500K Sandy @ 4500 MHz
X5650 6-Core Westmere @ 3982 MHz
AMD FX 8320E Black Edition
FX-8320E @4.5GHz, X5650 @ 4.0GHz, X6 1045T @4.0GHz, i7 [email protected]
Thinkpad T420p with i7-2720QM overclocked because this is OCN
Heuchler is offline
post #3 of 10 (permalink) Old 08-13-2019, 08:00 PM
microchidism's Avatar
Rep: 6 (Unique: 6)
What about one of those universal heatkiller gpu blocks?
GPU History - 6 Nvidia, 3 AMD <--- need to get this number up
microchidism is offline
post #4 of 10 (permalink) Old 08-14-2019, 05:49 AM
zGunBLADEz's Avatar
Rep: 105 (Unique: 76)
the koolance 220 will be the best block and it will fit problem is is disco and hard to find.
if you find one grab it and keep it. that little block is a damn beast.
https://www.frozencpu.com/products/1...8aAkZrEALw_wcB
only 1 left in stock lol
zGunBLADEz is offline
post #5 of 10 (permalink) Old 08-14-2019, 10:12 PM - Thread Starter
It looks like you can get most any cpu water block to fit on the stock plate. I'm going to leave the sock heatsink\vapor chamber to the side. Put some little heatsinks on the stock plate ram spots and use the blower if possible. Then again they have CPU water blocks with extended plating that might just be enough to cool most of the vram without any heat sinks on top of the stock plate. They have little packs of copper heat sinks you can get for like 10$. If I could take the stock heat sink off the vapor chamber, cut it in half and use it in the front and the back of the card, that would work too. If the vapor chamber wasn't so dang thick I'd use it with the stock fins.
Worst case scenario, cpu block with a 120mm fan. I could buy a expensive water block but that doesn't seem as fun or easy to come by. I also like to reuse my parts at a later time. I won't rule out a regular water block though.
Similar CPU block $20, heat sinks $10-15. Or universal GPU block, pretty much the same thing. Looking into the R9-290X DCII. Ignore my little green square lol
post #6 of 10 (permalink) Old 08-14-2019, 10:39 PM
Heuchler's Avatar
I was thinking putting the stock cooler (without fan and other electronics) into an oven to re-flow the solder. Hopefully the whole vapor chamber with heatsink can be cleanly be removed
leaving you with the stock cooler plate to play with. Stock fan and the plate should be plenty to cool just the memory and VRM. Also, gives you a chance to go for a stock water cooled look.
Maybe a small brick under the vapor chamber and let the oven and gravity do the work for you.
Name:	RX 5700 XT 8GB GDDR6.jpg
Heuchler is offline
post #7 of 10 (permalink) Old 08-15-2019, 04:25 PM - Thread Starter
Edit, yeah it does look like solder, GN used a screw driver to get it off. I'll look into the oven method. Clean is the keyword . But meh the oven might be a big pain in the u know what.
post #8 of 10 (permalink) Old 08-30-2019, 07:53 PM - Thread Starter
How hot should you heat the oven and for how long to get the heat fins off the vapor chamber? Any idea? EDIT nvm you were talking about taking the vapor chamber off the gpu plate.
Sapphire Radeon RX 5700 Non XT Boost Core 2060 v1.25? Gaming Ram 950 with a 20$ Chinese water block on the, Ryzen 3700x just PBO atm, 15$ Chinese waterblock, 3200 ddr4 cl16 Team T-FORCE VULCAN TUF B450m Asrock Pro 4 Mobo, 700 Watt OCZ PSU. 6 gallon res passively cooled. ocz700sxs PSU 9 years old or so. nuts. 2nd household rig CPU 3600 Nvidia 2060 stock atm 3000 ddr4 xmp.
post #9 of 10 (permalink) Old 08-30-2019, 09:11 PM
Heuchler's Avatar
I would guess 220 - 220°C would be need (400 - 428°F). I would use an old toaster oven outside.
Would the block you are considering using clearing the hole the vapor chamber would leave behind.
Maybe look for a somebody selling their stock cooler and mod that one.
Heuchler is offline
post #10 of 10 (permalink) Old 09-02-2019, 12:40 AM - Thread Starter
It does not clear the hole, I plan on filing the hole down. Since I already bought it ^^
