Older EK Supremacy Jet Plates with 9900K - Overclock.net - An Overclocking Community
post #1 of 1 (permalink) Old 08-13-2019, 09:16 PM - Thread Starter
Watercooler
Socks keep you warm's Avatar
Rep: 145 (Unique: 124)
https://www.ekwb.com/shop/EK-IM/EK-IM-3830046990549.pdf
This is my waterblock before we start.
I woke up this morning and thought geez, i'm kind of sick of heat and the 9900K, i didn'y pay top dollar to be getting such crap results.
For years i was using the J2 Jet Plate and thought i was getting amazing results. I thought how about we try the wider jet plate with .7mm thickness and see how we do.\
TIM in use it Thermaltake TG-7.
As you can see up to almost 20c drop in temperature just by changing the Jet Plate and also ensuring in the link that the copper plate to the block was positioned according to EK.
EK states in a release in 2013( which who actually follows this sort of news?) here.
https://www.ekwb.com/news/ek-suprema...-for-lga-2011/
J2 was standard for 115x but i would high recommend using the fatter J3 as i was sure that core and imc layout had changed over years.
Happy overclocking.
Also want to note without temp results but with TIM usage i would also recommend going a little bit bigger than a pea size dot, this is just not enough for the 9900K.
Results obtained after running [email protected] for about 2 minutes on each setup.
4.8Ghz 1.235V LLC Turbo
Name:	Jet Plate Difference..png
I like to have fun.
https://stats.foldingathome.org/donor/110855
https://www.trueachievements.com/gamer/II+TH3PRO+II
16 Threads is Good
(10 items)
Intel Core I9 9900K 4.8Ghz
Gigabyte Aorus Elite
Aorus 2080Ti Xtreme Waterforce WB 11GB
Trident Z
Samsung 250 SSD
Cooler Master Silent Pro Hybrid
Watercooling Custom
900D
Operating System
Windows 10 x64
28" ACER 4K Monitor
Socks keep you warm is online now
