Water Cooling Shopping List - What about 5700 XT? - Overclock.net - An Overclocking Community
post #1 of 16 (permalink) Old 08-14-2019, 06:23 PM - Thread Starter
Why is it smoking?
Mr. Mojo's Avatar
Rep: 356 (Unique: 293)
I'm going to build my first real WC rig soon. I've been shopping around, reading threads here and reviews and recommendations everywhere, and I think I have a pretty good idea of what I want.
CPU: 3800x
MB: Either a Gigabyte x570 Aorus Pro WIFI or save a few $ with an ASRock x470 Taichi
RAM: depending on what's in stock when I order, it will be a 3600Mhz "B" die 16GB kit
GPU: I just bought a reference 5700 XT
Case: Lian Li PC-O11 Dynamic White
Lighting is still undecided. I want lights in it but not the crazy swirly rainbow strobe stuff. If I buy parts with RGB, I will probably set it to the closest to white I can get out of it and have it constant.
For the CPU, I'm looking at Heatkiller IV but they're pretty scarce right now. I kinda like the look of the Swiftech Apogee SKF Prestige, but I don't know how it stacks up to the Heatkiller.
For the GPU, I need recommendations. I know that EK and Bykski both have FC blocks for the 5700 series. The EK is hella expensive and the Bykski is a little too flamboyant for my design. Is anyone else developing a FC block for these cards? If so, do we have an ETA?
I plan on running a HWL 360 radiator mounted in the front/side of the O11 case. Would a GTS XFlow be enough to cool these components, or would I need to go for a GTX?
I will get a pump/res combo with a D5 PWM, but I still haven't decided on the size or manufacturer.
Fans...maybe Varders? I want something that will be on the quieter side but still keep temps down. I'd also like to have either white (or as close as I can get) LEDs on the fans.
I also considered just getting a Swiftech Boreas 360 kit. It wouldn't save any money but it would be convenient to get that and then add a GPU block to the loop later.
So help me out. Give me your opinions and recommendations.
Monochrome
(22 items)
AMD Ryzen 7 3700x
Gigabyte x570 Aorus Pro Wifi
Sapphire Radeon RX 5700 XT
Crucial Ballistix Elite DDR4
Sabrent Rocket Nvme PCIe 4.0 M.2 2280
Sabrent Rocket NVMe PCIe M.2 2280
Seasonic FOCUS Plus Series
EK-KIT Classic RGB P360
EK-Vector Radeon RX 5700 +XT RGB - Nickel + Plexi
Arctic P12 PWM PST Value Pack
DEEPCOOL RF120M 5IN1
XSPC G1/4" Inline 10k Sensor, Chrome
EK-CryoFuel Solid Cloud White (Premix 1000mL)
Lian-Li PC O11 Dynamic (white)
Operating System
Windows 10 Pro
Viotek GFT27DB
BenQ GL2760H
Keyboard
Logitech G213
Mouse
Logitech G502 Hero
Mousepad
Enhance GX-MP6
Audio
Audio Technica ATH-M50x
Audio
Logitech Z333
Mr. Mojo is offline
post #2 of 16 (permalink) Old 08-14-2019, 06:50 PM
⤷ αC
AlphaC's Avatar
Rep: 904 (Unique: 590)
Swiftech Boreas kit is decent but you'd probably get better value buying radiator from HWLabs or XSPC TX series (for slimmer 20mm thickness). I haven't seen any reviews on Hydrae GT radiator (27mm thickness).
In addition, the Apogee SKF LT is a $50 CPU block from them so either the fin count was cut (as they still advertise the same 125 micron fin/channel thickness) or the materials are cheaper than the Apogee SKF because there's no other ways to cut $20 off a $70-90 CPU block.
There's been no in depth reviews of the CPU blocks on Ryzen chips but the fin thickness is smaller (i.e. more fins per inch) on the apogee SKF as well as an increased fin height. Whether it translates into a temperature advantage worth noting is the real question , especially considering the flow restriction.
For the CPU just realize you're only going to get another 100MHz or so out of a 3800X over 3700X.
A single 360mm GTS xflow is capable of dissipating around 300-350W of heat per 10°C coolant rise https://www.xtremerigs.net/2015/09/1...ator-review/4/
For fans you can probably opt for Arctic P12 PWM.
There's RX 5700XT waterblocks in the works from EKWB and Alphacool.
https://www.igorslab.media/amd-radeo...er-sei-dank/3/
https://www.igorslab.media/zurueck-a...n-rx-5700xt/2/
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #3 of 16 (permalink) Old 08-14-2019, 08:52 PM
Ironsmack's Avatar
Rep: 53 (Unique: 49)
GPU Blocks from Heatkiller as well. AFAIK, there's no ETA yet for the 5700 blocks.
Gaming Rig: (2) Swiffy MCP35x, UT60 + GTX 480 rad, (1) 360 HWL GTX, (1) 240 HWL GTS, HK IV, 2920X @ 4.2 GHz, AsRock X399 Fatality, (2) NVidia 1080 w/ HK IV blocks, Gammix S11 Pro 1TB, Crucial MX500 1TB, 2TB Samsung F4, (4) 3 TB & (2) 5 TB Toshiba HD, CL STH10, EVGA 1300 PSU, Win 10 Pro
HTPC Rig: 2600 @ 4.1Ghz, Asus Strix B450, D5 vario w/ EK top, 480 UT60, 240 HWL GTX, Asus 290 w/ XSPC WB 1000/1300, Crucial P1 500 GB, 12TB Ironwolf, 6TB & 8TB HGST, Enthoo Primo, EVGA G2 750, Win 10 Pro
Ironsmack is offline
post #4 of 16 (permalink) Old 08-15-2019, 02:35 AM
SubZero is the Goal
HardheadedMurphy's Avatar
Rep: 73 (Unique: 63)
I have the ASRock z390 taichi, I'm kicking myself for not going with the ASUS counterpart. The polychrome lighting software does not work in windows 10 build 1809 or later, any changes to lighting on the board need to be done in bios, and lighting effects reset when you load oc profiles
Sent from my OnePlus 7 Pro using Tapatalk
"It is impossible to defeat an ignorant man in an argument" McAdoo
Peace begins when we care about someone other than ourselves.
"Hell is still Overburdened, I must stand and wait in line" Disturbed
The Beast
(23 items)
MiniFurnace
(10 items)
ThinClient
(5 items)
i5-9600k
ASRock Z390 Taichi
EVGA GeForce GTX 1080 FTW Hydro Copper GAMING, 08G-P4-6299-KR, 8GB GDDR5X, LED, DX12 OSD Support (PXOC)
EVGA GeForce GTX 970 04G-P4-2974-KR 4GB SC GAMING w/ACX 2.0, Silent Cooling Graphics Card
Corsair Vengence RGB Pro
Mushkin Enhanced Source M.2 2280
Toshiba
Optical Drive
LG Bluray RW
Rosewill Quark
Barrow RGB 115X CPU Block
EK-360 Radiator
Phobya 12v DC PWM Pump
Black Ice Nemisis 240mm stealth Rad
Alphacool 5.25 pump / resivoir combo DC-LT
Phobya Balancer 250mm Res - Black Nickle
Corsair Obsidian 900D
Operating System
Windows 7 Professional
LG 34" Ultrawide IPS 21:9
HP 27xw ips
HP 27xw IPS
Keyboard
Corsair Strafe RGB MX Silent
Mouse
Corsair M65 Pro RGB
Audio
Corsair Void Pro RGB
Xeon 5300
Xeon 5300
Dell 2950 v3 Server
ECC DDR2 RAM
Hitachi 1tb 7200rpm
Optical Drive
SLIM DVD-RW
redundant 750w
OEM
Operating System
Windows Server R2
Other
DRAC 6/i
Celeron N2930
G.Skill 8gb 204 pin
Seagate 500gb 2.5"
Zotac Zbox CI320 Nano
Operating System
Win 10 Pro
HardheadedMurphy is offline
post #5 of 16 (permalink) Old 08-15-2019, 04:02 AM
Shawnb99's Avatar
Rep: 23 (Unique: 15)
Add a flow meter and water temp sensor.
If going soft tubing go with Mayhems, also use them for the fluid, and get their Blitz kit to clean your rads and system.
As for fans Noctua’s are the best but are an ugly brown and expensive. Vader’s are nice but can be loud.
Other options then a D5 is the Mcp35x2.
My Baby
(24 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Watercool HEATKILLER IV PRO
2x Swiftech MCP35X2 with MCP35X2 Heat Sink
2x Hardware Labs Black Ice Nemesis 360GTR
2x Hardware Labs Black Ice Nemesis 360GTS
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
2x Noctua NA-A15 PWM
24x EK Vadar F4120ER
Case Labs Magnum M8 with Pedestal
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Mr. Speakers Aeon Closed
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #6 of 16 (permalink) Old 08-15-2019, 05:00 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 404 (Unique: 271)
If going soft tubing go with Mayhems, also use them for the fluid, and get their Blitz kit to clean your rads and system..
Strongly agree on all of this. Don't cheap out on the little things that make a huge difference, o r get sucked into bad fluid or tubing. Makes a big mess down the road.
Really can't agree regarding the Noctuas, excepting the NF-A12x25. That is a phenomenal fan, the rest are mediocre for rad usage. There are much better fans out there for the application. And, yes, Vardars are simply nasty sounding.
ciarlatano is offline
post #7 of 16 (permalink) Old 08-15-2019, 01:31 PM
Tetrapyloctomist
Aenra's Avatar
Rep: 21 (Unique: 20)
Additionally, Vardars don't like heat, at all. Which is also very ironic, as they do tend to overheat..
And when they work overheated? Soon enough their sound signature changes; if you thought they were noisy in the beginning? Boy you're in for a surprise ^^
As to Noctua fans... if it's not an IPPC, i don't even consider it. They are the exception (and for reasons that have nothing to do with performance btw) to this rule; i use them for everything, be it water, air, intake or out. For every other noctua fan? There are better performing, quieter, or cheaper ones out there. Yes, that includes the new Sterox one -at the kind of range it's thought to be 'perfect'? Might as well use a BeQuiet fan; they're even quieter. Won't even mention performance-, not worth its premium.
Pride, honour and purity.
Aenra is offline
post #8 of 16 (permalink) Old 08-15-2019, 06:18 PM - Thread Starter
Why is it smoking?
Mr. Mojo's Avatar
Thanks for the info everyone
Looks like Varders are out, so maybe Arctics or Noctuas are in. I will also probably be getting a GTX instead of a GTS, since the GTS is probably going to struggle to cool both my CPU and GPU. I'm sure it's capable, but the GTX can do it at lower fan speed/noise.
I had written more in my original post but between my spazzy computer and my ambien fog, I didn't post it all. I do plan on using Mayhems flush kit, soft tubing, and fluid. I like the look of the Mayhems pastel (white, grey, or black) but I see it has mixed reviews so I'm not totally set on the idea yet. I will probably use Barrow fittings and I will add a flow meter/temp sensor as well as a drain port.
In case you can't tell, I'm going for a black and white/monochrome theme. The case has some of both, but the interior is mostly white. I will either use black chrome or plain chrome for the fittings, depending on what CPU block I end up buying. I'll leave the radiator black. As far as looks vs performance, I'd say this build is going to be right in the middle. My computer sits in a very prominent location in my house, and I don't want a big blinky noisy eyesore (which is why I plan on setting the RGB lights to white and leaving them alone). I do play games, but I'm not competitive. I stick to RPGs and an occasional non-multiplayer FPS. I don't have to have 200+ FPS, but I do want 100 or so consistently. I have a 1440p, 144Hz 27" freesync display, so as long as I can keep it fed with pixels, I'll be happy.
Monochrome
(22 items)
AMD Ryzen 7 3700x
Operating System
Windows 10 Pro
Viotek GFT27DB
BenQ GL2760H
Keyboard
Logitech G213
Mouse
Logitech G502 Hero
Mousepad
Enhance GX-MP6
Audio
Audio
Logitech Z333
Mr. Mojo is offline
post #9 of 16 (permalink) Old 08-16-2019, 05:58 AM
ciarlatano's Avatar
If you can fit them in the budget, which I assume you can since you are looking at Noctuas, the be quiet! Silent Wings 3 is a better and quieter performer than either of those - http://thermalbench.com/2016/10/21/b...h-speed-fan/3/
Also, you have the GTX and GTS backwards. The GTS and SR2 outperform the GTX and GTR at lower fan speeds - https://www.xtremerigs.net/2015/02/1...-round-2015/5/
post #10 of 16 (permalink) Old 08-16-2019, 06:26 AM
Shawnb99's Avatar
With the PWM Issues on the Be Quite’s I wouldn’t consider them better. Since they don’t work well with the AQ6 without modding I wouldn’t recommend them over Noctua’s.
Now if you don’t want PWM control then maybe they are better.
My Baby
(24 items)
Asus Hyper M.2 card
2 x Intel 660P 2TB
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Audio
Audio
Other
Shawnb99 is offline
