will this cool amd 3900x good? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 16 (permalink) Old 08-21-2019, 05:16 PM
I can count to potato
Fluxmaven's Avatar
Rep: 15 (Unique: 8)
RIP that poor bastard that actually bought it from eBay at that at that price...
Fluxmaven is offline
post #12 of 16 (permalink) Old 08-21-2019, 05:21 PM - Thread Starter
ubbernewb's Avatar
Rep: 9 (Unique: 8)
i didnt i just used that link
ubbernewb is offline
post #13 of 16 (permalink) Old 08-29-2019, 02:30 PM - Thread Starter
ubbernewb's Avatar
Rep: 9 (Unique: 8)
so replaceing the 3 fans gives better temps? what fans to get that can plug in same way?
post #14 of 16 (permalink) Old 08-30-2019, 08:10 AM
Fluxmaven's Avatar
Rep: 15 (Unique: 8)
Did you buy one? If so, just try it out with the included fans and see how your temps are before you go off spending money to upgrade them.
As for fans that plug in the same way, they are just normal 4pin PWM fans. Any of the popular PWM fans will work. The only thing you lose by ditching the stock fans is IRIS RGB control. If you replace them with a fan that uses RGB, you would need either a separate controller or use your motherboard RGB headers.
post #15 of 16 (permalink) Old 08-31-2019, 02:30 PM - Thread Starter
ubbernewb's Avatar
Rep: 9 (Unique: 8)
ya i bought it, and no i wasnt going to buy new fans unless someone did it and could say there was a differnce to make it worth it
post #16 of 16 (permalink) Old 09-03-2019, 12:55 AM
Vlada011's Avatar
Rep: 38 (Unique: 28)
Swiftech is king for expandable AIO systems.
Vlada011 is offline
