will this cool amd 3900x good? - Overclock.net - An Overclocking Community
post #1 of 16 (permalink) Old 08-21-2019, 03:00 PM - Thread Starter
ubbernewb's Avatar
Rep: 9 (Unique: 8)
will this cool amd 3900x good? i know should go custom but if this https://www.ebay.com/itm/Swiftech-Dr...2984%7Ciid%3A1 will cool it good its for cpu only
ubbernewb is offline
post #2 of 16 (permalink) Old 08-21-2019, 03:06 PM
Shooting down fallacies
ciarlatano's Avatar
Rep: 403 (Unique: 271)
It will cool it very well. Plenty of info and user experiences here - https://www.overclock.net/forum/61-w...ners-club.html
And..... It is $100 less if you buy it direct from Swiftech.com.
ciarlatano is offline
post #3 of 16 (permalink) Old 08-21-2019, 03:35 PM
⤷ αC
AlphaC's Avatar
Rep: 904 (Unique: 590)
^ That's highway robbery by the Ebay seller. If you buy direct from swiftech you also will probably have better warranty support.
For all the AIO CPU blocks I think the Drive x3 is the best as far as for 3rd gen Ryzen because of the 125 micron fins.
http://www.swiftech.com/drive-x3-aio.aspx
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: Asteroi[email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #4 of 16 (permalink) Old 08-21-2019, 03:54 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1067 (Unique: 629)
are the fans included any good? considering grabbing one but the fans remind me a lot of the trash-tier "Aigo" Ring LED fans that maybe are good for 30 CFM on a good day at 30 dBa.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #5 of 16 (permalink) Old 08-21-2019, 04:16 PM
Tech Enthusiast
oreonutz's Avatar
Rep: 38 (Unique: 21)
I have absolutely NO EXPERIENCE with this Cooler. And @AlphaC says its the Best Block in an AIO on the Market, So I would DEFINITELY take his word for it, I have found he has a wealth of great information to share.
That being said, I can share my experience with EKWB's take on this type of cooler. Its 360MM Rad as well, its called the Phoenix 360mm MLC. It uses slightly modified EKWB Parts, and uses Quick Disconnects so you can expand the loop easily later if you want. I am about to expand it with Custom Water loop parts to try to get my 3900x under control with Heavy Loads, but as of right now its only had the 1 360mm Rad and CPU block in the Loop.
This thing cooled Both my 2700x and my 8700k Build Admirably. However, when it comes to my 3900x, it is no where near as good as I expected it. I am pretty sure it comes down to the Block Design not being optimal for the Chiplet Layout, but I was incredibly disappointed with this cooler on my 3900x. During normal Blender Renders, My CPU would reach a Max of 91c in a Room Ambient Temp of 29c. My ambient is obviously higher than most people, so having a more normal 25c Ambient would obviously drop temps by 4 to 5c on what I am getting, but still that Delta was not encouraging. And under the same 29c Ambient with a Workload like Prime 95 Small FFTs or Aida64's FP64 Ray Trace Test, my Temps will instantly spike to 108c as soon as the test starts, and Thermal Reboot at 110c in less than 4 Seconds. (In the Asus Crosshair VII Hero there is no Thermal Throttling at all, instead you get a Instant Reboot once your Tdie temp reaches 110c).
So again, don't take this as a review of the Swifttech Cooler you are looking at, because this is obviously a different product, and appears to have awesome reviews. I would just check to see if someone has used it on the 3900x yet, because some blocks seem to be more optimal for the Chiplet Design than others.
Also, that seller on Ebay is trying to pull a fast one, as others have mentioned, go direct to Swifttech, you will get a better warranty (or warranty at all actually) and it will cost you MUCH less.
Good Luck!
-MattTheTech
Offical Ryzen 9 3900x Owner!
DodekaZen3000
(28 items)
Ryzen 9 3900x
ASUS Crosshair VII Hero
EVGA 1080ti FTW3 Hybrid
G.SKILL Flare X Series 32GB (4 x 8GB) 3200Mhz (PC4 25600) - F4-3200C14D-16GFX (x2 Kits)
Samsung 970 Pro 512GB
Samsung 970 Evo 1TB
Samsung 850/860 Evo (x3 Raid 0 Game Drive)
WD Black 4TB (x2 Raid 0 Storage Drive)
860 Evo
Optical Drive
LG Blu-Ray Burner (Model BH16NS40)
Optical Drive
5.25" to One 3.5" and One 2.25" Bay (Model Syba SY-MRA55006)
Corsair RM1000i
EKWB Phoenix 360mm Modular Cooler
Old Jonesbo Case
Operating System
Windows 10 Enterprise
Samsung NU8000 55Inch TV (Its a 4k TV But I run in it 1440p 120hz)
LG 1080p 34 Inch Diplay
Keyboard
Corsair k70 RGB Lux Mk2
Mouse
Logitech G700s
Mousepad
Razer Vespula V2
Audio
Custom Built 7.1 Surround System
Audio
HT-Omega eClaro 7.1 Sound Card
Audio
Focusrite Scarlett 18i20
Other
Aquantia 10Gb NIC
Other
LSI 9211-8i
Other
Oculus Rift HMD
Other
10 ML120 + 2 ML140 Corsair Maglev Fans
Other
Phanteks Halo aRGB LUX x5
oreonutz is offline
post #6 of 16 (permalink) Old 08-21-2019, 04:21 PM - Thread Starter
ubbernewb's Avatar
Rep: 9 (Unique: 8)
is the mounting for am4 easy with that kit? also not quick but FULL install pdf i found the quick one but cant find the full version
post #7 of 16 (permalink) Old 08-21-2019, 04:51 PM - Thread Starter
ubbernewb's Avatar
Rep: 9 (Unique: 8)
does it come with tubes allready mounted or you have to cut em? if i have to its fine just wondering
post #8 of 16 (permalink) Old 08-21-2019, 04:56 PM
ciarlatano's Avatar
It is fully assembled.
post #9 of 16 (permalink) Old 08-21-2019, 04:58 PM
ciarlatano's Avatar
They are middling. Definitely the weak link in the package. A fan change gives the X3s a nice performance boost in the low and mid rpm ranges.
post #10 of 16 (permalink) Old 08-21-2019, 05:08 PM - Thread Starter
ubbernewb's Avatar
Rep: 9 (Unique: 8)
anyone have full install pdf? i found quick but not full
