Anyone seen this happen? Unusual nickel plate wear in EK 390x block - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 08-24-2019, 05:24 PM - Thread Starter
PhillyB's Avatar
Rep: 26 (Unique: 25)
Note before reading: I am not blaming the manufacturer of the product for this. There was nothing wrong with the product as far as I can tell. Just 3+ years of 24/7 use. I even replaced the block with another from EK.
Just thought I would throw this image out for your viewing pleasure. I pulled my 390x out of service because the waterblock started doing this:
It began with edges in the raised area of the block that butt up with the plexi cover. It worked its way across the surface, but not the main flow channels of the block.
Two months back, I pulled my system apart and cleaned everything out. This removed the tarnish that built up on the copper and also on the cooling fins. The video card was oriented with the vid cables on top (90deg board rotation case). So, the worn fins were the lower most fins.
After cleaning with a very mild vinegar solution (about 1 cap to 1/2 gallon of water), soap with hot water and a toothbrush, then flushed with hot water, then distilled, everything was put back together. Over the next month or two, the copper seems to have oxidized rather oddly. I would have expected it to turn green, but I'm not a metallurgist, so I know nothing. instead it seems to have shed copper into the distilled water.
My best guesses: there was no corrosion inhibitor in the distilled water. Perhaps some corrosion built up, shed off other parts like the rads and worked its way into the gpu block. Then corrosion and scratching from those flakes wore away the nickel plating. On a closer look, there is significant thinning in the nickel near the fins along the exit path through the block.
I just find it extremely odd that the primary nickel loss is between the block and plexi cover. There shouldnt be water flow through these areas, but clearly there is. I'm guessing the initial wear widened the path and made it a high pressure flow path which accelerated the process. 5 months ago, there was no noticeable copper areas.
Result was I pulled the card and block, replacing with a 5700xt and new EK block. (added corrosion inhibitor as well) I was worried that copper was leaching into the water and may cause similar wear on other blocks and pump. There was a very slight copper color to the water after 2 months, but that may have been the old tubing and brownish color of the lighting.
So...anyone else have a block do that?
Edit: I probably should also note that I had the water flowing through the jet plate in the wrong direction for 3 years and didn't notice.
PhillyB is offline
post #2 of 11 (permalink) Old 08-24-2019, 06:23 PM
Rep: 0
block wear is normal over time. corrosion is not unless your coolant sucks.
BTW it might help if you posted the picture you mentioned you were going to post
quiet gaming
(17 items)
Not so quiet heater
(19 items)
Core i9-9900KF
ASUS ROG Maximus XI Hero (wi-fi)
RTX 2080 TI Founders Edition
G.Skill Trident Z Royal (Silver)
Samsung 970 EVO Plus
EVGA Supernova 1000G+
EK Vector RTX RE Ti RGB - Nickel + Plexi
EK-Momentum ROG Maximus XI Hero D-RGB - Plexi
XSPC D5 Photon 270 Reservoir/Pump Combo V2
Black Ice Nemesis L-Series 480 Xtreme Radiator
Black Ice Nemesis L-Series 360 Xtreme Radiator
Lian Li PC-V3000
Operating System
Windows 10 Pro
LG 34UC89G
Keyboard
Logitech G15
Mouse
Logitech G9x
Audio
Logitech G35
1950x Ryzen ThreadRipper
ASRock x399 Taichi
GTX 1080 Founders Edition
G.Skill RipJaws V series
Samsung 960 EVO
Intel 900p Optane U.2
Seagate Barracuda
Crucial SSD SATA
WD VelociRaptor 10,000RPM
Optical Drive
LG BDRE
Silverstone Strider Plus
Koolance TR4 CPU block
Koolance GTX 1080 full coverage block
Koolance 280 radiator
Koolance 240 radiator
Koolance RP-401X2 Reservoir
Koolance pmp400 (DDC) x2
Corsair Vengeance series C70 Military Green
Operating System
Windows 10 Pro
Mektor is offline
post #3 of 11 (permalink) Old 08-24-2019, 06:27 PM - Thread Starter
PhillyB's Avatar
odd. It shows up on my computer...
here you go.
PhillyB is offline
post #4 of 11 (permalink) Old 08-24-2019, 06:38 PM
Rep: 0
That looks like residue from somewhere else in your system either that or the PH is off in your coolant and a bit corrosive or possibly contaminated with tiny particles like sand and abrasive blasting your blocks.
Might try this to see if you can restore it back to its former glory.
wont hurt to have exposed copper. good coolant like koolance 702 will help prevent corrosion as long as you aren't mixing aluminum radiators with copper waterblocks.
quiet gaming
(17 items)
Not so quiet heater
(19 items)
Core i9-9900KF
Lian Li PC-V3000
Operating System
Windows 10 Pro
LG 34UC89G
Keyboard
Logitech G15
Mouse
Logitech G9x
Audio
Logitech G35
ASRock x399 Taichi
Samsung 960 EVO
Seagate Barracuda
Crucial SSD SATA
Optical Drive
LG BDRE
Operating System
Windows 10 Pro
Mektor is offline
post #5 of 11 (permalink) Old 08-24-2019, 07:00 PM - Thread Starter
PhillyB's Avatar
Can't restore glory that has been blasted away.
Yea, not really sure what happened. I may have used an old batch of distilled that had something in it along the way. Can't remember...I'm old now.
I wasn't worried about it, until i saw the water tinting slightly to copper. I avoid all premixed coolants.
Too many companies selling garbage that clogs, falls out, etc and ends up fouling all the parts. My first loop had distilled/kill coil for over a year, everything was perfect when it got pulled apart. Water also has better heat transfer than non-water options (oils, glycol, etc). Also, its cheap and can be bought at the local grocery store for under $2 a gallon. I'm not saying the one you mentioned is bad, never read up on that one specifically. But, too many others have too many problems and sometimes its the combination of parts, metals, in specific quantities that are unique to one loop that makes it go wrong and others have no problem.
note: my first ever loop was on a used Pentium 4 and I was stupid. so I used tap water and a touch of bleach...rusted all the springs in the tubes which prevented tube collapse...not corrosion...rust. Damn...that was a long time ago...tiny single 80mm radiator and fan, 1/4" tubing...
Now I refuse to risk anything as I spent more on cooling than most people are willing to spend on a whole computer...Even had to make a custom case just to meet my needs.
PhillyB is offline
post #6 of 11 (permalink) Old 08-26-2019, 05:38 AM
News Fiend
ryan92084's Avatar
Standard stagnant area issues. Particularly common to EK blocks but nickel blocks in general will have it eventually without a good corrosion inhibitor. Copper oxidizes black not green. Verdigris (green copper) requires other chemicals.
Also don't use vinegar on nickel blocks. It hastens the plating's demise.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #7 of 11 (permalink) Old 08-26-2019, 06:07 AM
skupples's Avatar
Rep: 553 (Unique: 313)
looks like run away Ph and/or your radiators weren't clean enough, etc etc.
skip coolance, go mayhems biocide+ and inhibitor+, follow directions, have stuff coming out looking like new, years later, every time.
if it isn't mayhems, it's rebranded mayhems, or garbage. there's a reason this has happened over the last few years.
skupples is offline
post #8 of 11 (permalink) Old 08-26-2019, 07:46 AM
Black Sun Empire
Wuest3nFuchs's Avatar
Rep: 37 (Unique: 30)
So how would you clean nickel Blocks?
Gesendet von meinem SM-G950F mit Tapatalk
Watercoolingbox
https://www.overclock.net/t/1352993/...oolingbox/0_20
V3g4n0
(18 items)
2700X
Asus ROG Crosshair Hero VII
Sapphire RX Vega56 Pulse
GSkill F4-3200C14D-16GFX
Crucial MX 500
Crucial MX 500
Optical Drive
Pioneer BDR S09 XLT
BeQuiet Straight Power
BeQuiet Silent Loop 240mm
BeQuiet DARK BASE PRO 900 Silver rev. 2
Operating System
Win 10 1803
AOC Agon AG241QX, 23.8"
Keyboard
Steelseries M750
Mouse
Steelseries Sensei 310
Mousepad
Steelseries DEX
Audio
Steelseries Arctis 5
Audio
Sound Blaster X-Fi titanium HD
Other
Tobii Eyetracer 4c
Ryzen 5 2400G
Asus TUF X470 PLUS GAMING
Crucial Ballistix Sport AT DIMM Kit 16GB Single Ranked BLS2K8G4D30CESTK
Samsung SM843 MZ7TD240HAFV-000DA
Crucial M4
be quiet! Straight Power 11 550W ATX 2.4 (BN281)
Ryzen 7 Wraith RGB
Fractal Design Define R6 Black
Operating System
Win 10 1803 / Server 2016 Standard
Samsung SyncMaster XL2370 LED, 23" (LS23EFPKFVEN)
Wuest3nFuchs is offline
post #9 of 11 (permalink) Old 08-26-2019, 07:56 AM
Meep
Gilles3000's Avatar
Rep: 299 (Unique: 220)
https://www.youtube.com/watch?v=KNaCbMuaOV8
Please stop linking that stupid video, it makes 0 sense.
First of all you don't want vinegar anywhere near nickle plating, that's for cleaning copper. What makes even less sense is that he recommends mixing vinegar with dishwasher fluid, which neutralize each other, so depending on the ratio you're either going to end up with barely acidic vinegar or really poor soap.
Only thing he did was scrub some deposits off the surface with the toothbrush, there wasn't any corrosion on that block to start with.
Gilles3000 is offline
post #10 of 11 (permalink) Old 08-26-2019, 09:11 AM
News Fiend
ryan92084's Avatar
Very gently since the plating is so thin and once it starts going it'll grow. People have recommended dedicated nickel cleaners but I don't have any experience with them.
Meh '12
Ryzen 2600x
XFX Fury X
EKWB Fury X
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
Optical Drive
Some old thing
Custom water
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
