Questions Re direct die setup - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 08-25-2019, 09:33 AM - Thread Starter
Cinderblocks's Avatar
Rep: 6 (Unique: 4)
1. Does a direct die frame like Rockit's eliminate the danger of liquid metal running onto the CPU PCB or mainboard?
2. In the context of direct die cooling, what's the temperature difference between liquid metal, paste, and liquid metal pads?
Thanks
I don't know. Some guy.
Cinderblocks is offline
post #2 of 4 (permalink) Old 08-25-2019, 09:42 AM
jonkrmr's Avatar
Rep: 2 (Unique: 2)
1. No
2. At most just a few degrees C
jonkrmr is offline
post #3 of 4 (permalink) Old 08-25-2019, 11:37 AM - Thread Starter
Rep: 6 (Unique: 4)
Thanks, might a good way to protect against from runaway LM, aside from nail polish/ liquid tape, be electrical-taping the PCB to the frame and frame to the waterblock?
I'm trying to think what options might be available with a frame.
post #4 of 4 (permalink) Old 08-25-2019, 11:50 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 403 (Unique: 271)
The best way is simply not to use LM. Not worth the risk for the small difference I a direct die setup.
ciarlatano is offline
