Soft Tubing Lifespan - Page 2 - Overclock.net - An Overclocking Community
post #11 of 15 (permalink) Old 09-09-2019, 01:44 PM - Thread Starter
Forceman's Avatar
Rep: 794 (Unique: 514)
Just to close this off, I replaced a couple of suspicious looking fittings and seem to have stopped the leak, so it appears it was probably one of those and not the tubing itself (although it is still definitely looser on the fittings than new tubing).
Forceman's Law: Any AMD/Nvidia GPU thread, no matter what the topic, will eventually include a post referencing the GTX 970.
Forceman is offline
post #12 of 15 (permalink) Old 09-09-2019, 03:27 PM
Rep: 0
About 10 years using 8/10 garden tubes and no problems....
They did get tuff and lost transparency with years, however.
Mordorr is offline
post #13 of 15 (permalink) Old 09-09-2019, 03:53 PM
skupples's Avatar
Rep: 544 (Unique: 309)
Quote: Originally Posted by D-EJ915 View Post
You should be able to replace the G1/4 terminal or do you mean that threads that piece is mounted into the actual block itself? https://www.ekwb.com/shop/ek-fc-terminal-acetal
just the terminal ports... I'm sure i've got another one somewhere.
I won't be slotting that second card again though, i'm lucky it didn't fry.
I'll either sell it cheap to someone around here, or frame it.
skupples is offline
post #14 of 15 (permalink) Old 09-09-2019, 03:55 PM
Overclocker in training
ThrashZone's Avatar
Rep: 64 (Unique: 50)
Hi,
Yeah I usually leave slack so I can trim off some if I have to disassembled later and it's not too short.
i9-9940x With Heatkiller IV Pro Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #15 of 15 (permalink) Old 09-09-2019, 03:56 PM
skupples's Avatar
me too! just enough so that I can trim @ the crimp a couple times.
skupples is offline
