Soft Tubing Lifespan - Overclock.net - An Overclocking Community
post #1 of 15 (permalink) Old 08-27-2019, 02:17 PM - Thread Starter
Forceman's Avatar
Rep: 794 (Unique: 514)
I've been trying to locate a small leak in my loop (with no luck) and noticed when I was checking a few fittings that the tubing is now pretty loose on the compression fitting (with the nut off). How long does soft tubing normally last? I assume it has softened over time and that's why it is a little loose, and probably contributing to evaporation if not outright leaks, but I have no idea if that is normal. I replaced one of the lines and it was hard to put the new one over the fitting, while the old one was easy to remove (and leaked a bit when it was moved without the compression nut on it). Thinking I'll just end up replacing all the lines since I just can't seem to find the leak, but thought it worth asking before I go that route.
Forceman's Law: Any AMD/Nvidia GPU thread, no matter what the topic, will eventually include a post referencing the GTX 970.
Forceman is offline
post #2 of 15 (permalink) Old 08-27-2019, 07:01 PM
News Fiend
ryan92084's Avatar
Can't say I've ever had age cause my tubing to loosen, quite the contrary actually. Heat on the other hand loosens them right up.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #3 of 15 (permalink) Old 08-27-2019, 07:02 PM
skupples's Avatar
Rep: 544 (Unique: 309)
it takes quite some time, but I've noticed that evap goes up with age. Your small leak may actually be evap.
I've found loose compression fittings months & months later, but was never sure if it was from the tube wiggling its way out over time, or me overlooking it.
I actually have the exact same problem right now. My system is evaporating more water than ever, to the point where I thought it was a leak but its just NOT happening anywhere in the physical plane.
I'm not sure, but I think different colors of ADV LRT evap faster
skupples is online now
post #4 of 15 (permalink) Old 08-28-2019, 02:47 PM - Thread Starter
Forceman's Avatar
Yeah, I did fine one bad fitting (a rotating 90 degree) and replaced it, but it hasn't really changed the drop rate in the reservoir. I'm debating just replacing all the tubing anyway, I got a good deal on some at Microcenter so it's really just the hassle factor.
Forceman is offline
post #5 of 15 (permalink) Old 09-05-2019, 10:23 AM
WaterCooler
Sir Beregond's Avatar
Rep: 72 (Unique: 65)
Keep in mind over time the tubing is compressed which contributes to that sidewall maybe becoming thinner over time (at least where it connects to the fitting). Hence why I've always gone back in the case periodically (maybe every 6 or 12 months) and giving the compression rings a turn to re-tighten.
I've also noticed that for every 12 months, my reservoir will need to be refilled. It's a small reservoir, but after 12 months, it will be down to about 1/4 full. Not sure if that's related to loose tubing or not. Not sure where the evaporation takes place. There are no leaks.
As for the tubing lifespan itself, depends on how bad it leaches plasticizer. With regards to the looseness, if it reaches a point where the compression is all the way tightened but the tubing is still loose, then yeah, I'd replace it.
I've ran my current tubing for nearly 5 years now and it is still in great shape. I've had other batches though that leeched horribly and needed replacing after a couple years.
Deus Ex (2015-)
(21 items)
[Intel] Core i7-4790k
[ASUS] Z97-DELUXE
[ASUS] GTX 980 Strix
[Corsair] Vengance Pro Series 16GB DDR3-2400
[Crucial] M550 512GB
[WD] Black 3TB x 2
[Corsair] AX750
[EK] Supremacy EVO - Gold
[EK] GTX 980 Strix - Fullcover w/ Backplate
[EK] D5 X-RES Top 100 w/ D5 Vario
[Monsoon] 3/8" ID 5/8" OD Compressions - Gold
[XSPC] EX240 x 2
[Corsair] SP120 x 5 / AF120 x 1
[Corsair] Carbide Air 540
Operating System
[Windows] 8.1 Pro 64-bit
[LG] 32GK650F-B
Keyboard
[Corsair] K70 - Red switches
Mouse
[Razer] Naga Epic
Audio
[Audio Technica] ATH-A700
Audio
[Antlion] ModMic
Other
[Lamptron] FC5-V2
[Intel] Core i7-960
[ASUS] Rampage III Formula
[EVGA] GTX 670 FTW 2GB
[Corsair] Dominator-GT 6GB DDR3-1866
[Crucial] M4 128GB
[Samsung] Spinpoint F3 1TB x2
[WD] Caviar Black 750GB
[Corsair] AX850
[XSPC] Raystorm
[XSPC] EX360 and EX240
[Scythe] Gentle Typhoon AP-15 x 5
[EVGA] GTX 680 Hydro Copper w/ Backplate
[XSPC] Dual-bay Res w/ [Swiftech] MCP655
[Bitfenix] Spectre Pro Red LED - 140mm x 4
[NZXT] Switch 810 Matte Black
Operating System
[Windows] 7 Ultimate 64-Bit
[BenQ] XL2420TX
Keyboard
[Saitek] Cyborg V.5 Red LED
Mouse
[Razer] Naga Epic Red LED
Audio
Audio
[ASUS] Xonar Essence STX
Other
[Lamptron] FC5-V2
[Intel] Core M-5Y10
[Intel] HD Graphics 5300
[Generic?] 8 GB DDR3
[Generic?] 256GB SSD
Operating System
[Microsoft] Windows 10
1920 x 1080
Sir Beregond is offline
post #6 of 15 (permalink) Old 09-05-2019, 11:39 AM
skupples's Avatar
I ended up actually finding a micro leak! Turns out the threads were damaged on the last 1080ti I picked up. (before you ask... I always replace o-rings before using a fitting a second time, since I run things for years at a time)
It was too small to actually leak for the longest time but I'd hear it sucking air in upon boot. (at least, this is now what I'm confident the sound was)
fast forward, I wake up to THE SOUND...
i'm now down to one 1080ti, but I was going to pull one anyways during the install of a new board.
post #7 of 15 (permalink) Old 09-05-2019, 02:05 PM
WaterCooler
Yikes, glad you were able to find it.
Deus Ex (2015-)
(21 items)
[ASUS] Z97-DELUXE
[WD] Black 3TB x 2
[Corsair] AX750
[XSPC] EX240 x 2
Operating System
[LG] 32GK650F-B
Keyboard
Mouse
[Razer] Naga Epic
Audio
Audio
[Antlion] ModMic
Other
[Lamptron] FC5-V2
[Intel] Core i7-960
[Crucial] M4 128GB
[Corsair] AX850
[XSPC] Raystorm
Operating System
[BenQ] XL2420TX
Keyboard
Mouse
Audio
Audio
Other
[Lamptron] FC5-V2
[Intel] Core M-5Y10
Operating System
1920 x 1080
post #8 of 15 (permalink) Old 09-05-2019, 03:19 PM
Overclocker in training
ThrashZone's Avatar
Rep: 64 (Unique: 50)
Hi,
Yeah closed loop
Pump on and off creates vacuum and push pressure which the later will leak turning on and off computer
I added pressure release to get rid of both issues in the reservoir where most air will accumulate and where my leak was coming from pump base reservoir combo connection.
To see how much shut down and see where the water level is
Startup and see how much the water level drops.
Usually about 1/4" doesn't seem like much but that is enough to find weak o-rings and or connections in general.
i9-9940x With Heatkiller IV Pro Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #9 of 15 (permalink) Old 09-05-2019, 03:29 PM
skupples's Avatar
it kept leaking even with the reservoir open. An incredibly slow, small pool of water, right @ the EK-FC Terminal, both top ports. Turns out the threads were heavily over torqued... Looks like someone could have even hit the lip with sand paper. I should have noticed this damage immediately upon receiving the card, but I made the huge mistake of upgrading during a busy time in life.
In theory, this means there was (at the least) water pooling between the block & card, near a memory chip. Further proof of this were the weird random vertical artifacts in 3d, and random partial frames in 2d, and the eventual 2d crashing upon even setting an OC to the card.
Good news is the card is working fine after a couple days in the window. So it'll just be relegated to backup duty, or maybe I'll gift it to someone i know... IDK.
post #10 of 15 (permalink) Old 09-05-2019, 06:10 PM
D-EJ915's Avatar
Rep: 3 (Unique: 3)
You should be able to replace the G1/4 terminal or do you mean that threads that piece is mounted into the actual block itself? https://www.ekwb.com/shop/ek-fc-terminal-acetal
Kanna
Dark X299
(7 items)
Mitty
(11 items)
Intel i7-7820X
Asrock X299 OC Formula
Asus Strix 1080 Ti
G.Skill DDR C14 3200MHz XMP 4x8GB
Intel P3520 NVMe PCIE AIC 1.2TB
Seasonic X-1250 1250 Watt PSU
NZXT Kraken 62
NZXT S340
Operating System
Windows 10 x64
Asus PA329Q 32" 4k 60Hz
Keyboard
Corsair K70 RGB Lux
Mouse
Logitech G600
Audio
HDMI to my Yamaha CX-A5000 preamplifier and studio monitors.
Intel i9-9900X
EVGA X299 Dark
EVGA Geforce GTX 1080 Ti
G.Skill 4x8GB C14 3200MHz
Samsung Pro 840 250 GB
EVGA Supernova G3 1300
Phanteks PH-TC14PE
Intel i7-3930k
Asrock Fatal1ty X79 Champion
EVGA GTX 780 Ti
Mushkin Redline
WD Velociraptor
Optical Drive
Asus DVD±RW
Seasonic X-1250
Corsair H100i V2
Fractal ARC MIDI
Operating System
Windows 7 Pro x64
Audio
Asus Xonar DX
D-EJ915 is offline
