Need help selecting parts - Page 2 - Overclock.net - An Overclocking Community
post #11 of 41 (permalink) Old 09-02-2019, 06:33 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 403 (Unique: 271)
Quote: Originally Posted by ThrashZone View Post
Hi,
Wild looking case you'll have fun
360mm on top and 240mm rad on front about all she wrote on it
Hardware labs GTS rads performance pc
http://www.performance-pcs.com/
Which PPC you can get all of your fittings Bitspower seem to be the best.
Mayhems soft hose and biocide and Inhibitor with distilled water add color of choice later
Heatkiller IV Pro all copper cpu block you already have the copper gpu block probably have to order it through watercool though supplies are gone at performance pc have seen some plexi/ nickle on amazon for decent price.
https://www.amazon.com/Watercool-HEA...01IAN04XG?th=1
Ideally watercool D5 Vario pump and reservoir combo not many options on these though I got one through alphacool I believe long ago think it's too tall though
http://shop.watercool.de/epages/Wate...pen/Pumpensets
Corsair has a new one that might fit that wild case D5 pump and looks okay might not leak sitting in an angle yeah don't even think about the kit just the pump combo
http://www.performance-pcs.com/corsa...oir-combo.html
Normally I would agree on all of this....with the exception of buying any Corsair open loop part, but....that "case"......I have zero confidence that the width of HWL rads would fit.
I would be more inclined to do something like this, add in some Mayhems tubing and build a 50mm Monsoon MMRS (D5 caps OOS at PPC at the moment):
Name:	Annotation 2019-09-02 093201.jpg
ciarlatano is offline
post #12 of 41 (permalink) Old 09-02-2019, 07:06 AM
Overclocker in training
ThrashZone's Avatar
Rep: 64 (Unique: 50)
Hi,
Yeah I do like those X flow rads I believe they have ports on each end if so going rad to rad would be a lot easier piping not to mention draining too
You didn't select a base for the pump and reservoir though it's a challenge corsairs seemed the better than plopping down a ek pwm D5 pump/ res combo
As far as the block op can always go to watercool and just get the IV pro copper base plate and upgrade the basic base plate later on it is a lot better for cpu upgrades later on.
i9-9940x With Heatkiller IV Pro Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #13 of 41 (permalink) Old 09-02-2019, 08:47 AM
ciarlatano's Avatar
No, I had posted to go with a 50mm Monsoon MMRS. I couldn't put it in the cart as the D5 bottom is currently out of stock at PPC.
Or....he can simply decide which CPU he is going to use and buy the appropriate one. But, a change is pretty cheap just buying a new mounting kit.
post #14 of 41 (permalink) Old 09-02-2019, 11:00 AM - Thread Starter
Shafiurr3's Avatar
Rep: 0
Quote: Originally Posted by ciarlatano View Post
Are you building a loop for cooling or for argeebee?
well I am a fan of lights and color. also argeebee also sounds cool >.>
Shafiurr3 is offline
post #15 of 41 (permalink) Old 09-02-2019, 11:10 AM
ciarlatano's Avatar
The Swiftech Boreas kits might be of interest, and add an additional 240mm - http://site.swiftech.com/boreas/
post #16 of 41 (permalink) Old 09-02-2019, 11:29 AM
ThrashZone's Avatar
Hi,
Amazon has the alpha D5 base/ reservoir combo all you'd need is a D5 pump to install on it plexi base also
https://www.amazon.com/Alphacool-Eis...56&s=pc&sr=1-1
https://www.amazon.com/gp/offer-list...&condition=all
D5 vario pump
https://www.performance-pcs.com/xspc...out-cover.html
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #17 of 41 (permalink) Old 09-02-2019, 04:34 PM - Thread Starter
Shafiurr3's Avatar
Rep: 0
I have decided on the ryzen 3700x and this is what I am going for
Pump:XSPC D5 Vario SATA Pump
Resivor:Alphacool 15199 Eisbecher D5 150mm Acetal Reservoir
Radiator:XSPC TX360 Crossflow Ultrathin Radiator and XSPC TX240 Crossflow Ultrathin Radiator
Cpu block:HEATKILLER® IV BASIC (AMD, AM4 ready) ACRYL CLEAN
I have few questions about the fittings, coolant and tubing. like how much tubing should I order and the fittings, like what company and how many do I need? links might help and the coolant is there anything that doesn't need any mixing afterwards?
post #18 of 41 (permalink) Old 09-02-2019, 07:15 PM
ThrashZone's Avatar
Hi,
Maybe alphacool fittings couple 4 packs maybe really depends on how it's piped
https://www.performance-pcs.com/alph...Specifications
90's have to draw it out to figure how many I'd say about 6 maybe 8
https://www.performance-pcs.com/alph...eep-black.html
Didn't know PPC had tygon tubing
http://www.performance-pcs.com/tygon...ar-tubing.html
But clear mayhems 3/8-5/8 here
https://www.amazon.com/gp/offer-list...&condition=new
If you do get the alphacool reservoir it has a cool fountain pipe which shows flow pressure also causes a little bubble action but that settles down after a while
Temp sensor and flow meter have to look around for them.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #19 of 41 (permalink) Old 09-02-2019, 07:31 PM - Thread Starter
Shafiurr3's Avatar
Rep: 0
Hi,
so 2 packs of alphacool fittings and 6 of the 90's with mayhems tube? and what about the coolant? cause I heard if you dont mix stuff correctly it has high possibility of corrosion. and whats the temp and flow sensor for?
post #20 of 41 (permalink) Old 09-02-2019, 07:34 PM
ThrashZone's Avatar
Hi,
Water temp sensor I have one of these on each of my builds I believe amazon has them
http://www.xs-pc.com/temperature-sen...-inline-sensor
Square flow meter
https://www.performance-pcs.com/alph...are-plexi.html
Round or really round top which ever you like best
https://www.performance-pcs.com/alph...und-plexi.html
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
