Need help selecting parts - Page 3 - Overclock.net - An Overclocking Community
post #21 of 41 (permalink) Old 09-02-2019, 07:44 PM
Overclocker in training
ThrashZone's Avatar
Rep: 64 (Unique: 50)
Quote: Originally Posted by Shafiurr3 View Post
so 2 packs of alphacool fittings and 6 of the 90's with mayhems tube? and what about the coolant? cause I heard if you dont mix stuff correctly it has high possibility of corrosion. and whats the temp and flow sensor for?
Hi,
You can get a couple mayhem X1 clear 1000ml bottles of premix about 20.us a piece though out of stock though also out of concentrate :/
http://www.performance-pcs.com/featu...ter-clear.html
I'd just use mayhems biocide and Inhibitor use local bought distiller water
http://www.performance-pcs.com/water...itor-15ml.html
Out of biocide of course think I saw some on amazon though either way you get a lot more product with these two than the premix
http://www.performance-pcs.com/water...cide-15ml.html
i9-9940x With Heatkiller IV Pro Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #22 of 41 (permalink) Old 09-02-2019, 08:34 PM - Thread Starter
Shafiurr3's Avatar
Rep: 0
Quote: Originally Posted by ThrashZone View Post
Hi,
Well I will go to micro center a d see if they have the collant once all my things come in. Ty for your help
Shafiurr3 is offline
post #23 of 41 (permalink) Old 09-03-2019, 02:28 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 403 (Unique: 271)
Don't use the Alphacool 90s, they are poorly made and prone to leaks. Get Bitspower 90s from Performance PCs.
ciarlatano is offline
post #24 of 41 (permalink) Old 09-03-2019, 03:42 AM
ThrashZone's Avatar
Hi,
All rotaries are prone to leak but yeah I started out with bitspower until I saw prices think the budget is officially blown have to see all in cart to know by how much :/
Search is a little better than yesterday for some reason think it was the price gougers on amazon for bitspower fitting was the issue and PPC was mostly out of stock
21.us a pop you may only need 2 on the pump and maybe 1 elsewhere rest can be straight barbs 3/8-5/8" soft hose bends nicely
http://www.performance-pcs.com/bitsp...od-5-8-v3.html
12 of these 13.us a pop
http://www.performance-pcs.com/bitsp...-8-od-5-8.html
Shut off valve
http://www.performance-pcs.com/fitti...-extender.html
T block for the bottom front rad for shutoff valve/ drain
https://www.amazon.com/Bitspower-T-B...F5DZDJ402TZAF0
Doubt microCenter will have anything but EK fluid STAY FAR AWAY FROM IT !!!!
Amazon or Newegg probably has mayhem X1 clear premix
Modmymods has a good deal on it on amazon
https://www.amazon.com/Mayhems-Coola...0067I7M32?th=1
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #25 of 41 (permalink) Old 09-03-2019, 12:13 PM - Thread Starter
Shafiurr3's Avatar
Rep: 0
wow thats $275 just in fittings
post #26 of 41 (permalink) Old 09-03-2019, 01:08 PM
I can count to potato
Fluxmaven's Avatar
Rep: 15 (Unique: 8)
Water cooling is not a financially responsible hobby.
That said, you can spend quite a bit less on fittings. Barbs with hose clamps is usually the cheapest but doesn't look as nice. For straight fittings, you can get by with cheaper compression fittings. If you find a spot where you absolutely need a rotary fitting, I would spend a bit more for quality rotaries.
http://www.performance-pcs.com/barro...ing-black.html
Fluxmaven is offline
post #27 of 41 (permalink) Old 09-03-2019, 01:27 PM
Rep: 2 (Unique: 2)
Think about the people that have multiple rads, pumps, and reservoirs. Not to mention dual GPUs.
Now someone tells me Glad I'm not married, probably be looking at a divorce by now.
And don't put them in a bind or they will leak even if they are new. Of course, this is more of a threat with hard tubing but if you have a line pushing or pulling on a rotary the pressure will cause it to leak.
Open Air Build
i9
ASUS ROG Strix Z390-H Gaming
MSI GEFORCE GTX1080 TI GAMING X 11G
Corsair Vengeance LPX DDR4 DRAM 3000MHz
Samsung 970 EVO
WD Blue
EVGA SuperNOVA
All PrimoChill parts (Rad 360, Pumps D5, Fittings, and Acrylic Tubing), Byskey CPU&GPU Blocks
Praxis Wet Bench
Operating System
Windows 10 Pro
Asus Predrator
Other
Thermaltake Commander F6 Fan Controller
Other
DIY Sleeved Cables
smilinjohn is offline
post #28 of 41 (permalink) Old 09-03-2019, 01:55 PM
chas1723's Avatar
Rep: 2 (Unique: 2)
You could go with Barrow fittings. Same quality as bitspower without the tax for being name brand.
Sent from my SM-N950U using Tapatalk
chas1723 is offline
post #29 of 41 (permalink) Old 09-03-2019, 04:01 PM
ciarlatano's Avatar
This. I had made the same recommendation to you initially. You would only be in for about $40 in fittings and they are better quality than the Alphacool you are looking at. Stick with Bitspower rotaries, but you should only need a few. Forget that silly flow wheel, you can see as much by looking at your res.
post #30 of 41 (permalink) Old 09-03-2019, 05:41 PM
ThrashZone's Avatar
Hi,
Yep there are ways to save a little
Modmymods has the soft tubing for cheaper just for one
https://modmymods.com/mayhems-3-8-5-...t10-16-30.html
Think the also have the 6 pack alphacool fittings cheaper too
https://modmymods.com/alphacool-hf-1...ack-17389.html
Mayhem fluid too but out of stock unfortunately
https://modmymods.com/mayhems-x1-cle...-myh-0087.html
8 pack of xspc fittings just as good
http://www.performance-pcs.com/xspc-...v2-8-pack.html
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
