Best AIO to buy - Overclock.net - An Overclocking Community
Best AIO to buy
post #1 of 45 (permalink) Old 09-03-2019, 03:46 AM - Thread Starter
hellasinc's Avatar
Rep: 0
Best AIO to buy
Wanted to some advice on with best AIO to buy , im looking for either a 280mm or a 360mm . I need a good one for overclocking
hellasinc is offline
post #2 of 45 (permalink) Old 09-03-2019, 03:55 AM
Senior OCN Member
shilka's Avatar
Rep: 2739 (Unique: 1626)
By AIO do you mean CLC aka closed liquid cooler or a AIO kit?
CLC coolers are rubbish https://www.overclock.net/forum/61-w...lc-cooler.html
Buy an AIO kit from EK, Alphacool or Swiftech they might cost more than a CLC cooler but they are also far better and you said you wanted the best
Seravee
(30 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
MSI RTX 2070 Super Gaming X Trio
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Corsair Force MP510 1,92 TB
Seagate Ironwolf Pro 14 TB
Seagate Ironwolf 12 TB
WD Ultrastar DC HC530 14 TB
Seagate Ironwolf Pro 12 TB
Seagate Ironwolf Pro 16 TB
Optical Drive
LG CH12NS30
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod 30 CM Magnetic Red LED strip
shilka is offline
post #3 of 45 (permalink) Old 09-03-2019, 04:17 AM - Thread Starter
hellasinc's Avatar
Rep: 0
I don't think its worth it , the cheapest from EK is 312 euros when I can get a Corsair H115i pro for half that price
post #4 of 45 (permalink) Old 09-03-2019, 04:20 AM
Senior OCN Member
shilka's Avatar
The H115i is cheaper because its worse in every way like in much lower quality and the pump is trash and the whole CLC cooler wont last all that long as the liquid will evaporate over time
You said you wanted the best not the cheapest so there is a good reason for the higher cost
Those kits by the way can be expanded so you can add more stuff to the loop later if you want
Read the link i gave you in my last post
Seravee
(30 items)
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Audio
Sennheiser HD-599
Other
shilka is offline
post #5 of 45 (permalink) Old 09-03-2019, 04:28 AM - Thread Starter
hellasinc's Avatar
Rep: 0
Yes I want the best but spend double the amount on something that performs the same as a AIO isn't worth it in my opinion . I looked at reviews for the performance line from EK they where performing on par with the AIO's . I gave the Corsair H115i pro as an example I usually buy NZXT Kraken and ive had them run for over 2 years with no issues but im sure the failure rate is higher than a custom loop
post #6 of 45 (permalink) Old 09-03-2019, 04:34 AM
Senior OCN Member
shilka's Avatar
Like i said there is a reason for the higher costs the fans and the pump in particular are light years better than what you get on a CLC cooler and once the liquid start to run dry you can refill it
And as said one reason for the higher cost is the expandability so you can buy a water block and add the GPU to the loop if you want something you cant do with a CLC cooler
I am not an expert on liquid cooling but i would take a second look at those kits as i dont believe CLC coolers are as good as them (i have had 6 CLC coolers all of them terrible)
If you have a link that shows EK, Alphacool and/or Swiftech kits are not much better than a CLC cooler i would like to take a look at that
Seravee
(30 items)
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Audio
Sennheiser HD-599
Other
shilka is offline
post #7 of 45 (permalink) Old 09-03-2019, 04:46 AM - Thread Starter
hellasinc's Avatar
Rep: 0
Take a look at this review of one of there kits from the performance line from EK , performs worse that a coolermaster AIO and basically on par with a kraken x72 https://www.tomshardware.com/reviews...er,5840-2.html . My evga 2070 Super xc ultra is a hybrid already running on a AIO so I wont be adding a block to that its just the cpu that needs some good cooling so I just don't see it worth the extra money for a kit
post #8 of 45 (permalink) Old 09-03-2019, 04:50 AM
Overclocker in training
ThrashZone's Avatar
Rep: 64 (Unique: 50)
Hi,
Nothing wrong with corsair products
Sometimes one gets a bad batch but 5 year warranty who cares that's what rma is for
You can get a bad batch from anyone I wouldn't bother with any other brand than corsair frankly.
i9-9940x With Heatkiller IV Pro Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #9 of 45 (permalink) Old 09-03-2019, 04:55 AM
poah's Avatar
Rep: 4 (Unique: 3)
not a huge amount of difference between the two sizes. a lot depends on the fans.
Are you wanting to just get a good overclock or wanting to submit to HWbot?
for a 280 the H115i pro is good as for a 360 check reviews.
poah is offline
post #10 of 45 (permalink) Old 09-03-2019, 04:58 AM
daniel audanie's Avatar
Rep: 0
Hey there!
I have an EVGA CLC 280 cooling my 9900k at 5ghz and loads at about 90c with prime 95 AVX after a few hours in my current ambient. EVGA also has a 5 year warranty and if you search around, you can find that their warranties are usually pretty awesome. The only issue is that the fans are a bit loud but I just set them to 60% manually.
You can see here that they're mostly the same https://www.gamersnexus.net/hwreview...r-h115i/page-3
The only real difference is noise but the EVGA AIO definitely has the highest CFM for their fans.
Desktop
(5 items)
np9770zm
(7 items)
9900k
Aorus Wifi Pro
1660 TI
EVGA CLC 280
Meshify C
4790k
gtx 980m
HGST
Micron m600
Operating System
Windows 8.1
Mouse
Razer Mamba
Audio
Sennheiser HD 380 Pro
daniel audanie is offline
