anyone know if this is any good? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 17 (permalink) Old 09-08-2019, 01:09 PM
The 6502 Still Rocks
Master Chicken's Avatar
Rep: 30 (Unique: 28)
As nice as they look, the Aquacomputer radiators with those round tubes are sub-par performers. Radiators with flattened roll formed tubes move heat better.
Master Chicken is offline
post #12 of 17 (permalink) Old 09-08-2019, 01:40 PM
Shooting down fallacies
ciarlatano's Avatar
Rep: 403 (Unique: 271)
Quote: Originally Posted by ubbernewb View Post
well i was eyeing because dont have to find place for pump and res, and my swiftech aio x360 does pretty good and if for nothing else but rad size the 420 i bet it cools better then the x3 360, my case is the thermaltake core x9
well also i was thinking is while the x3 cools good looking at that skinny rad even if they were both 360 the Aquacomputer should cool better i would think the X3 rad is pretty skinny
You're assuming that thicker must be better, but that is not necessarily correct. In actual usage many thin rads will outperform thicker rads simply because the thicker rads require higher fan speeds. So, the thicker rad might be better with the fans above 1500 rpm.....but how often would anyone want that?
Miiksu is there a rad/pump/res in one combo thats better then the alphacool?
Yes. You already own it. You would get far more benefit from adding a rad than you would by replacing what you have. It is also doubtful that your current setup is reaching the point of heat saturation, but an additional rad would allow for more cooling with lower noise.
ciarlatano is offline
post #13 of 17 (permalink) Old 09-08-2019, 04:23 PM
Cobra26's Avatar
Rep: 8 (Unique: 6)
What are you planning to cool btw?
If you want silence with low rpm fans and still have low temps then bigger rad is the answer.
I used prior to my AMS 840 a alphacool 360 Monsta rad and a xspc rc480 rad and my AMS 840 trumps them both temps wise. Sure the AMS 840 is bigger but I have no regrets and others who use it don't either. There are some conflicting reviews about the AMS rads one says it's mediocore while others tell it's really good. Real world application with my AMS 480 on my fx-9590 is at 100% load 51c, idle is 27c. My previous rad was a xspc rc480 idle was around 31c - 33c at same room temp.
As some one mentioned add another (cheaper) rad to your existing setup that should do the trick as well. There are many good rads for around 90 bucks or cheaper. And save the money for something else for your wc or pc.
Cobra26 is offline
post #14 of 17 (permalink) Old 09-08-2019, 05:38 PM
Overclocker in training
ThrashZone's Avatar
Rep: 64 (Unique: 50)
Hi,
Not sure what space this saves it needs a reservoir anyway just get a pump reservoir combo it would take up much more space than just a reservoir does.
Simplifies pump too when not if the pump goes out get a D5 forget the rest.
i9-9940x With Heatkiller IV Pro Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #15 of 17 (permalink) Old 09-08-2019, 08:43 PM - Thread Starter
ubbernewb's Avatar
Rep: 9 (Unique: 8)
Cobra26 its for a AMD 3900X
ubbernewb is offline
post #16 of 17 (permalink) Old 09-08-2019, 09:05 PM
skupples's Avatar
Rep: 544 (Unique: 309)
derp, nevermind
skupples is online now
post #17 of 17 (permalink) Old 09-09-2019, 12:03 AM
Rep: 7 (Unique: 5)
You have that Swiftech's water combo? You can add radiator to it? I saw that watercooling radiator review couple days a go. I would go Koolance 30 FPI 30mm rads if you doing push/pull if not then Hardware Labs GTS. I like thin rads coz they don't take much space and performing well at low speeds.
Miiksu is offline
