anyone know if this is any good? - Overclock.net - An Overclocking Community
post #1 of 17 (permalink) Old 09-06-2019, 02:37 PM - Thread Starter
ubbernewb's Avatar
Rep: 9 (Unique: 8)
http://www.performance-pcs.com/aquac...el-panels.html i know overpriced but just wondering about it
ubbernewb is online now
post #2 of 17 (permalink) Old 09-07-2019, 04:50 PM
Cobra26's Avatar
Rep: 8 (Unique: 6)
I have 2 of these lineup:
Aquacomputer AMS 840 full copper (cooling a i7-6800k and GTX 1070 SC) push/pull config
Aquacomputer AMS 480 full copper (cooling only a AMD FX-9590 220watt cpu Currently while browsing watch YT videos etc 28c) push only
What can i say they cool excellent on my gaming rig cpu idles around 21c to 29c depending on the season and gpu always adds 5c in comparison with the cpu. In heavy gaming sessions it doesnt sweat at all see link post 288:
https://www.overclock.net/forum/61-w...iators-29.html
All fans running @ 600 rpm silence is my goal plus these rads are designed for low rpm fans.
Another benefit is the no flux design of the rads so no more crap in your blocks.
But they are more restrictive then your average rad a single D5 can handle the rad and 2 blocks with ease and maybe with 2 pairs of QD4's if needed.
I would suggest not getting that combo you linked rather get a separate AMS rad and separate D5 pump and res combo makes it easier to fill and bleed. If you want to cool a cpu and gpu get the 840 and some QD4's for external setup.
For coolant i highly advise using "Koolance 702 clear" the best coolant i have used keeps your (nickel) blocks clean and without oxidation for more then 2.5 years straight.
And yes good WC setup costs money...
Aquatuning USA sells them as well btw.
Or directly order them from Aquacomputer shop i have no clue how much you have to pay for custom fees tho...
Cobra26 is offline
post #3 of 17 (permalink) Old 09-08-2019, 02:03 AM
Jakerz's Avatar
Rep: 2 (Unique: 2)
They probably cool just fine for everyday use but they don't really perform as well as most "traditional" radiators.
This is a great read: https://www.xtremerigs.net/2015/02/1...or-round-2015/
Just keep in mind that the charts show large differences between top and bottom performers but are only a few degrees if I recall correctly, lol
Jake
Lian Li PC-O6SX
(21 items)
i7 8700K
EVGA Z370 Micro
GTX 1080Ti
Corsair Vengeance LED
Samsung 960 Pro M.2 NVMe
Samsung 950 Evo
Corsair SF600
Watercool Heatkiller IV CPU Block
Watercool Heatkiller 1080Ti Block & Backplate
Watercool Heatkiller 200mm DDC Pump/Res Combo
Hardware Labs 360GTS Radiator
Bitspower Fittings
Bitspower 16mm PETG Tubing
Thermaltake RIING Plus Fans
Barrow Flow Meter
Lian Li PC-O6SX
Operating System
Window 10 Home
Alienware AW3418DW Ultrawide 34"
Keyboard
DAS Keyboard 4 Pro
Mouse
Razer Deathadder RGB
Mousepad
Mionix Alioth XXL Stiched Gaming Pad
Jakerz is offline
post #4 of 17 (permalink) Old 09-08-2019, 02:32 AM
Rep: 7 (Unique: 5)
I would not buy. Even Aqua Computer makes good blocks but their radiators a bit weak even the desing is good to maintain water cleaness. Not so much corrosion can happen if happen it's easier to clean than tradition radiators. Depends your configuration what works best. High fpi is for push/pull and high rpm fans and low fpi for low speeds and push. If you are gonna use more than one radiator you can combine different radiators to the best cooling.
Aqua Computer radiators avarage efficiency was only 76-80%. Koolance and Hardware Labs doing way better even with 30mm thickness.
Miiksu is offline
post #5 of 17 (permalink) Old 09-08-2019, 11:30 AM - Thread Starter
ubbernewb's Avatar
Rep: 9 (Unique: 8)
well i was eyeing because dont have to find place for pump and res, and my swiftech aio x360 does pretty good and if for nothing else but rad size the 420 i bet it cools better then the x3 360, my case is the thermaltake core x9
post #6 of 17 (permalink) Old 09-08-2019, 11:44 AM
skupples's Avatar
Rep: 544 (Unique: 309)
well yes, its a 420, it by definition should have more cooling capacity than a = quality 360...
skupples is offline
post #7 of 17 (permalink) Old 09-08-2019, 11:47 AM - Thread Starter
ubbernewb's Avatar
Rep: 9 (Unique: 8)
well also i was thinking is while the x3 cools good looking at that skinny rad even if they were both 360 the Aquacomputer should cool better i would think the X3 rad is pretty skinny
post #8 of 17 (permalink) Old 09-08-2019, 11:50 AM
skupples's Avatar
marten's liquid lab breaks a lot of that down. Thicc boiis require more fanspeed/pressure for = and/or better efficiency, if I remember correctly.
skupples is offline
post #9 of 17 (permalink) Old 09-08-2019, 12:33 PM - Thread Starter
ubbernewb's Avatar
Rep: 9 (Unique: 8)
Miiksu is there a rad/pump/res in one combo thats better then the alphacool?
post #10 of 17 (permalink) Old 09-08-2019, 12:44 PM
Ironsmack's Avatar
Rep: 52 (Unique: 49)
IMO, those Watercool rads are pretty. The aluminum, black color + copper is hot.
Performance wise, there are better options out there. But damn they look good.
Gaming Rig: (2) Swiffy MCP35x, (2) Aphacool UT60 480 rad, (1) 360 HWL GTX, (1) 240 HWL GTS, HK IV, AMD 2920X @ 4.2 GHz, AsRock X399 Fatality, (2) NVidia 1080 w/ HK IV blocks, Gammix S11 Pro 1TB, 500 GB Samsung EVO 850, 2TB Samsung F4, (4) 3 TB & (2) 5 TB Toshiba HD, CL STH10, EVGA 1300 PSU, Win 10 Pro
HTPC Rig: G3258 @ 4.4Ghz, Asrock Z97 Pro 4, D5 vario w/ EK top, 480 XSPC RX, 240 HWL GTX, Asus 290 w/ XSPC WB 1000/1300, Kingston 240 GB SSD, 12TB Ironwolf, 6TB & 8TB HGST, Enthoo Primo, Corsair HX620 PS, Win 10 Pro
Ironsmack is online now
