Motherboard header not compatible with Barrow temperature sensor? - Overclock.net - An Overclocking Community
post #1 of 20 (permalink) Old 09-08-2019, 09:02 PM - Thread Starter
Rep: 0
Hello, I have the following temperature sensor hooked up in my loop: http://www.barrowint.com/plus/view.php?aid=1210
I'm using a Gigabyte Z390 Aorus Master in my build and I have the temp sensor hooked up to one of the system fan headers. I believe all fan headers on this motherboard are hybrid PWM fan headers (at least according to Gigabyte's website).
The temp sensor display shows nothing when I boot the system. I set the fan speed to 100% and the control mode to "Voltage" in the BIOS and I still don't see any output. Any chance that I can run this sensor off of my motherboard?
Thanks!
annul is offline
post #2 of 20 (permalink) Old 09-08-2019, 09:13 PM
Rep: 3 (Unique: 3)
A quick google reveals that motherboard has temperature headers EC_TEMP1 and EC_TEMP2 for connecting temperature sensors. Are you using those for your sensor or the fan headers ?
EDIT: OK I see the device you are using directly measures water temp so ignore that comment.
clannagh is offline
post #3 of 20 (permalink) Old 09-08-2019, 09:21 PM
skupples's Avatar
Rep: 544 (Unique: 309)
based on a quick look @ barrow's advertising.
it comes with a splitter.
the skinny long one goes to USB, the other one goes to fan.
i'm not actually sure why you'd need the usb connection, if its a stand alone flow meter. Or vice versa, seems like it would be powered just fine from USB header.
this is why I stick to aquacomputer for anything digital-watercooling. Barrow does have them beat on aesthetic here though. I think i'd take aquacomputer software any day of the year though. They've been tuning it since before barrow was a company.
skupples is offline
post #4 of 20 (permalink) Old 09-08-2019, 09:23 PM - Thread Starter
Rep: 0
Quote: Originally Posted by clannagh View Post
A quick google reveals that motherboard has temperature headers EC_TEMP1 and ECTEMP2 for connector temperature sensors. Are you using those for your sensor or the fan headers ?
I'm using the fan headers. I believe this is what Barrow recommends as well (under "Feature" in this table): http://www-x-barrowint-x-com.img.abc...15ad9d9701.jpg
annul is offline
post #5 of 20 (permalink) Old 09-08-2019, 09:24 PM
skupples's Avatar
have you tried connecting the usb? That'll be way more power than a fan header. I think the fan header is just to read tach back to board based monitoring software.
skupples is offline
post #6 of 20 (permalink) Old 09-08-2019, 09:27 PM - Thread Starter
Rep: 0
The weird thing is the sensor that I ordered doesn't come with the splitter. My interpretation of that image on their website is that the splitter is so you can use their proprietary fan controller. So I'm not sure why the splitter is needed and as I understand it's just a way to integrate it with another product. Would be awesome if any Chinese-speaking users can chime in on that one.
You're right that Aquacomputer has Barrow beat on most fronts when it comes to digital monitoring. I planned to fit this in-line in my loop for mostly aesthetic reasons.
annul is offline
post #7 of 20 (permalink) Old 09-08-2019, 09:28 PM
skupples's Avatar
idk man, idk enough to know if a single fan header can power all that's going on in there.
skupples is offline
post #8 of 20 (permalink) Old 09-09-2019, 01:26 AM
professional curmudgeon
looniam's Avatar
Rep: 790 (Unique: 450)
FBFT02-V3,
Only can connect 5v interface, do not connect motherboard 12v
Compatible with ARSKZQ, DK301 controller
https://www.formulamod.com/barrowch-...-p1798520.html
best i found googling around.
though the previous version, i found somewhere, mentioned to make sure you set the fan header 100% (full speed) in the bios before using . . .
disappointed i couldn't find a PDF/manual anywhere.
Remember the golden rule of statistics: A personal sample size of one is a sufficient basis upon which to draw universal conclusions.
Upload the computer to Dropbox and provide a link to it so others may download it to examine and give advice for repairs.
loon 3.2
(18 items)
i7-3770K
Asus P8Z77-V Pro
EVGA 980TI SC+
16Gb PNY ddr3 1866
PNY 1311 240Gb
1 TB Seagate
3 TB WD Blue
Optical Drive
DVD DVDRW+/-
EVGA SuperNova 750 G2
EKWB P280 kit
EK-VGA supremacy
Stryker M [hammered and drilled]
Operating System
Win X
LG 24MC57HQ-P
Keyboard
Ducky Zero [blues]
Mouse
corsair M65
Audio
SB Recon3D
Audio
Klipsch ProMedia 2.1
looniam is offline
post #9 of 20 (permalink) Old 09-09-2019, 12:13 PM - Thread Starter
Rep: 0
Yeah I think you're right. Now that I look at it more, I'm having some doubts if the unit could be powered off of the fan header alone.
Yikes, this is pretty interesting. So what I'm taking away from this is that I need Barrow's proprietary fan/RGB controller in order to power this thing?
Apologies if it seems like I'm asking stupid questions. I haven't really seen a connector like this and Barrow's documentation is basically nonexistent. I've already contacted Gigabyte support but I suppose I'll contact Barrow as well.
EDIT: So after looking more closely at the Formulamod website, it looks like the connector for the sensor is specific to the pinout for the DK301 controller. This means the connector's pin 1 is the hot and pin 3 is the ground. The Aorus Master fan header pinout consists of GND, Voltage Speed Control, Sense, and PWM Speed Control for pins 1-4 respectively. I think this means there's no way to use a conventional 3-pin or 4-pin fan header (or even adapter) to connect this thing unless I re-pin the connector to a 3- or 4-pin fan connector. That's extremely disappointing, but I suppose I should have done my due diligence.
annul is offline
post #10 of 20 (permalink) Old 09-09-2019, 02:35 PM
looniam's Avatar
i overlooked the pin out on the sensor connector - i assumed it was four pin as a usb 2.0 header. so maybe that just for the barrow controller and i misunderstood it. yeah lack of alot info here even when trying to be diligent.
the 3 pin should work on a 4 pin header since all standard headers have 1)ground 2)12v 3)sense 4)pwn control. the 3 pin ignores/doesn't use pwm control.
this show how the "clip" lines up for the difference comparing a 3 to 4 pin header:
i don't think gigabyte would break standards as that would cause issues with all fans.
loon 3.2
(18 items)
i7-3770K
Asus P8Z77-V Pro
EVGA 980TI SC+
16Gb PNY ddr3 1866
PNY 1311 240Gb
1 TB Seagate
3 TB WD Blue
Optical Drive
DVD DVDRW+/-
EKWB P280 kit
EK-VGA supremacy
Operating System
Win X
LG 24MC57HQ-P
Keyboard
Ducky Zero [blues]
Mouse
corsair M65
Audio
SB Recon3D
Audio
looniam is offline
