Going EK from AIO, maybe? - Overclock.net - An Overclocking Community
post #1 of 9 (permalink) Old 09-09-2019, 11:47 PM - Thread Starter
Sedyn's Avatar
Rep: 3 (Unique: 2)
It's been ages since I built a system. Feb. 2011 to be exact. The Corsair AIO on that system is still running to this day, so I wanted to go Corsair again. I mean 8 years without anything but dust removal on a OC'd 2600k sounds good to me!
I put together a pretty decent set of parts, assembled them and found I have extremely poor contact between the Corsair h150i pro and the 9900k. I've assembled it multiple times and I know it's done right. Actually there is just a small ring of contact around the outside of the CPU. There is still untouched TIM on the Corsair where the convex isn't filled. Maybe that is a CPU issue, I am not sure... I'm hoping it's not a MOBO issue, but I won't know until I try another option.
So I got to looking at other AIO's to see if there is another option but they all seem to be using the same crap mounting from Asetek.
I found some comparisons that lead me to see the all aluminum EK Fluid Gaming A240 kit. But then I got to thinking CU is still better. I don't want the Aluminum risk.
So is there any real option out there outside something like a basic CPU only kit/system from the performance line, or assemble my own kit from the Quantum line, about $500ish? I'm afraid I may have picked a terrible case for the option. I went Corsair Obsidian 500D SE.
Or should I try another AIO?
At this point I have 3 kids and a wife now, so I'm out of the loop with the latest greatest technology and know next to zero about a custom loop. I'm reading through the blogs on EK's site but don't have the kind of time it takes to digest everything in just a couple days and make a good call. I am making a point of building a great system though, something that will last me years again and want this done right.
AIO is attractive from a known quantity perspective. I'm a fast learner.
Thanks all.
Sedyn is offline
post #2 of 9 (permalink) Old 09-10-2019, 03:59 AM
Overclocker in training
ThrashZone's Avatar
Rep: 64 (Unique: 50)
Hi,
Just get another aio save time and money and know you have a five year warranty which a custom loop/ kit will not have.
Even corsair now has custom loop kits if you love corsair stuff but costs is a lot more and not all that much different especially if you look at 240mm kits aluminum or copper.
280mm kit or aio minimum and 360mm would be best.
i9-9940x With Heatkiller IV Pro Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #3 of 9 (permalink) Old 09-10-2019, 09:39 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 403 (Unique: 271)
Quote: Originally Posted by Sedyn View Post
It's been ages since I built a system. Feb. 2011 to be exact. .
Well, since you've been out of the loop, a lot has changed. A big part of that change has been EK going from a (more like THE) leader in quality blocks, to being a marketer of all things mediocre in liquid cooling while retaining a ridiculous price tag. So....yeah.....pretty much the Corsair of custom loops, now actually competing against Corsair in the battle of overpriced mediocrity.
If you want to go custom loop, you can put together a far better loop at lower cost than going with EK components. There are plenty of threads on the subject, and I'm sure many would chime in here with suggestions.
If you want to stay AiO, you can get into a Swiftech X3, which is all copper and expandable. It was designed specifically to add a rad and GPU block to. It's reasonably priced and has lots of argeebee capabilities if you are into that - http://www.swiftech.com/drive-x3-aio.aspx
ciarlatano is offline
post #4 of 9 (permalink) Old 09-11-2019, 04:48 PM - Thread Starter
Sedyn's Avatar
Rep: 3 (Unique: 2)
Thanks Guys,
Sad to hear about EK, part of the reason I was looking that way was my MOBO has the EK CrossChill VRM Waterblock . I opened a cap and it's copper in there, so I would need a CU based system to integrate that.
However I want to get this thing up and running, and since I have a convex CPU chip, I am probably stuck with bad contact no matter what CPU waterblock I get.
Thanks for the heads up on the Swiftech X3. I will look into that. Seems more of what I am after.
I'm looking to get 5.0 out of this CPU, not going nuts and in a couple years when I want to build something new I can take my time and make something while this system is still running, or if I want to I can just install something on this.
If this build was a car, I'm looking for a reasonable maintenance, high performance yet reliable build. Not a high maintenance ultra performance race car.
Sedyn is offline
post #5 of 9 (permalink) Old 09-11-2019, 04:59 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1065 (Unique: 628)
If your 9900K is really concave/convex then delid it, because if that's the case just about any cooler is going to give you less than optimal temps. That's assuming there is genuinely something wrong with the IHS and not something you *think* is wrong, but if it is you should fix that before putting a penny into a cooler.
My 9900K is by no means a lottery winner and it's cooled by a H115i just fine @ 5.0.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is online now
post #6 of 9 (permalink) Old 09-11-2019, 05:08 PM
skupples's Avatar
Rep: 544 (Unique: 309)
EK's gone to shart, and Mayhem's has finally taken over the coolant world.
skupples is offline
post #7 of 9 (permalink) Old 09-11-2019, 10:20 PM - Thread Starter
Sedyn's Avatar
Rep: 3 (Unique: 2)
Checked against a straight edge it's 100% concave. I think I'd return it before I risked a delid. I'd probably mess it up.
Right now with CPU temps as high as 70 my coolant temp is pretty stable at 30. I'm gonna switch TIM and remount it tomorrow. If I can't get decent results, I will return it and see what I get next time. It's from Newegg.
@skupples I'll keep them in mind. The more I look at all the wires etc coming from the h150i I dislike it more and more. I don't mind spending $500 on a really good system that will be reliable and perform quietly. My computer is in the bedroom and my wife hates it already. RBG has gotta go.
Sedyn is offline
post #8 of 9 (permalink) Old 09-12-2019, 04:48 AM
ciarlatano's Avatar
Keep in mind, when @skupples says Mayhems has taken over the coolant world, he is referring to exactly that - coolant. As in the liquid that goes in the loop, and just that.
post #9 of 9 (permalink) Old 09-12-2019, 05:49 AM
ThrashZone's Avatar
Hi,
You'd also be flushing a 3 year Intel warranty down the toilet
If you end up returning
Think about the board too and look into amd 3000 series
Although temps they are having the same issue with 3000 series too basically no blocks are really optimized for them yet.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
