High cpu temps in my loop? - Overclock.net - An Overclocking Community
post #1 of 17 (permalink) Old 09-10-2019, 10:14 AM - Thread Starter
leonman44's Avatar
Rep: 2 (Unique: 2)
Hello guys , finally i upgraded to 2x360mm rads and i also delidded my i5 8600k , i was expecting temps closer to 60-65c under full load but i get spikes up to 72-73c on some cores under load (cinebench , realbench even csgo!).
The cpu was delidded twice just to make sure i did everything right the 1st time and i apllied some liquid metal within the cpu but also between my nickel cpu block and ihs for best performance.
My card full oced , a 2080 seahawk ek gets absolutely max 55-57c which is more than great for the stock paste which is usually pure junk.
Room's ambient temp is a bit high 30c.
Are cpu's temps what i should expect or its something really wrong here?
*Cpu is at 1.27v 4.8ghz which is not really that high , i was hoping to push 5ghz 1.4v and get 70-75s but as far as i can see that aint happening.
leonman44 is offline
post #2 of 17 (permalink) Old 09-10-2019, 10:28 AM
MrGrievous's Avatar
Rep: 10 (Unique: 8)
It kinda looks like you just lost the CPU lottery here, since you have delided the cpu twice now I dont believe it is a mounting issue. What 360mm rads did you get? Also what fans are you using and how fast are they spinning?
MrGrievous is offline
post #3 of 17 (permalink) Old 09-10-2019, 10:39 AM
Bratislav's Avatar
Rep: 3 (Unique: 3)
Hello,
- turn the fans on the front and top radiators to be intake
- turn the rear fan to be exhaust
- keep the CPU block in the normal position
- the hose from the pump to the GPU should enter on the left side of the block
Good luck!
Bratislav is offline
post #4 of 17 (permalink) Old 09-10-2019, 03:08 PM - Thread Starter
leonman44's Avatar
Rep: 2 (Unique: 2)
Is there a cpu lottery on temps? I thought it was only for the overclock.
I have the intake 2 fans on the motherboard rear one running 60% until 75c which ramps up 100%
Bottom fan switching off (it makes a lot noice for some reason on this specific case) until 55c , then 60% until 75c that again ramps up 100%
All radiators fans are as exhaust connected to the case fan controller , i am running it at 1/3 of their speed to keep it quiet but even at full speed the performance gain is small compared to the noise gain.
I also removed the filters from inside the front and top panels , also completely removed the bottom panels so i can improve the raw airflow.
* The top rad is from the phobya's 60mm one but i think its rebranded Alphacool UT60 with the kits 3 included fans and the front one is the PE360 from ek with vardar fans.
Quote: Originally Posted by Bratislav View Post
Hello,
Good luck!
That was my first plan but the case's front mount is not that great , it has some weird bumps that creates a space between the fan and the radiator , so i couldnt mount it with ek's included screws. What i did is that i removed the air filters in the front and upper panel to increase noticeably the fans performance.
Rear and bottom fans are also unfiltered as intakes.
Is this fan layout loosing that much performance?
The cpu block is indeed in the normal position
As for the card that wasnt in the instructions and temps are more than great , sorry to argue here but why this could be an issue?
post #5 of 17 (permalink) Old 09-10-2019, 03:11 PM
u broke 666 rep :(
skupples's Avatar
Rep: 676 (Unique: 359)
pretty sure most modern GPU blocks do not have a "correct" flow pattern, at least i know EK is this way.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
KAIHL Switches < CHERRY Switches, 10/10, blind taste test @ work.
skupples is offline
post #6 of 17 (permalink) Old 09-10-2019, 03:23 PM
Newb to Overclock.net
mouacyk's Avatar
Rep: 171 (Unique: 126)
Pretty sure this particular one does though:
If it has a jet plate, you can guarantee the flow is optimized for a specific inlet port.
CPU: Q6600 X5470 2100T 1680V2 9900K
GPU: 8800GT 9800GTX+ 750Ti 1080Ti
RAM: 2x8GBTZ
Gentoo64 in Water
(14 items)
LGA775 X5470
(6 items)
9900K 5GHz 1.224v
EVGA Z370 Micro
MSI 1080TI GXEK 2100.5/12627
16GB Trident Z 4000C16
970 EVO 500GB
Seasonic X850 Gold
480mm Radiator Custom
Silverstone FT03
Operating System
Windows 7 Ultimate 64-bit
Operating System
Gentoo Linux 64 Multi-Lib
Acer Predator XB271UH 165Hz
Keyboard
Logitech G710+
Mouse
Logitech G502
Audio
Sound Blaster Z
X5470 4GHz (stock v)
GA-EP45-UD3P
EVGA 9800 GTX+ 512MB
8GB 4x2GB GSkill 1066MHz DDR2
XSPC Rasa, D5 + Res, 240mm Rad
Lian-Li PC7-HX
mouacyk is offline
post #7 of 17 (permalink) Old 09-10-2019, 03:37 PM
u broke 666 rep :(
skupples's Avatar
oh shart! look at that. A tiny little jet plate. It's so cute! Maybe I'm just way behind these days.
you're definitely correct here, sir.
looks like I'm just behind on the times. I hadn't seen this new block style from EK yet, cuz I haven't looked at 20xx series at all.
My 1080ti blocks still use the classic style that ran from like fermi+
skupples is offline
post #8 of 17 (permalink) Old 09-10-2019, 03:47 PM - Thread Starter
leonman44's Avatar
Rep: 2 (Unique: 2)
That is getting fixed tommorow! Just after my blitz 2 drain.
Also turned off my pc and found out that HUGE bubble coming out from my front rad when the pump stops working , thats weird because i tilted noumerious times the case in all different ways except upside-down and it doesnt really go away.
post #9 of 17 (permalink) Old 09-11-2019, 06:12 AM
PhillyB's Avatar
Rep: 26 (Unique: 25)
I ran with an air pocket in the rad for years. its not a big deal as its just sitting in the tank area of the rad. Even makes a nice waterfall sound. Over time, the air will blend into the water and go away.
On the last rebuild, I ended up laying my case on its side, cycled the pump a few times and that got rid of my huge air pocket in the radiator. Just make sure the pump doesnt run dry, obviously. I was just trying to clear air out of the monoblock, ended up getting a huge bubble out of the radiator. then had to clear the monoblock all over again... This is why I go with plexi covers.
PhillyB is offline
post #10 of 17 (permalink) Old 09-11-2019, 06:19 AM
u broke 666 rep :(
skupples's Avatar
yep, i've done some silly stuff to properly cycle the air outta my STH10.
also note, you aren't going to get it all out on the first day, or even week. Just get it good enough, then give it a shake every once in awhile and make sure water is above the drip tip in the res.
skupples is offline
