WC loop setup in new Phanteks Luxe 2 - Overclock.net - An Overclocking Community
post #1 of 9 (permalink) Old 09-19-2019, 01:46 AM - Thread Starter
MoDeNa's Avatar
Rep: 3 (Unique: 3)
Hi all,
I am thinking about a WC setup in the new Phanteks Luxe 2 and I have several doubts. I am targeting for the best cooling performance with minimun noise at the same time and using the best quality components that is possible.
The hardware will probably be a Ryzen 3900x/3950x and one RTX 2080 Ti.
The water cooling setup I have in mind is the following:
· 2 x 360mm Alphacool NexXxos XT45 V2 rads for bottom and top.
· 1 x 480mm Alphacool NexXxos XT45 V2 rad for front
· 1 x 480mm XSPC TX rad for side
· 1 x D5 pump
· Heatkiller IV Pro block for CPU
· Heatkiller IV por GPU
· Fans: Noctua NF A12-25 for all rads (push config)
· Aquaero 6 LT controlling and monitoring pump, water temp and fans rpms
I realize that this could be a bit overkill but I want fans spinning at their lowest rpm without compromise cooling performance.
My doubts are:
1) Are these Alphacool NexXxos XT V2 radiators good enough in terms of performance, build quality and durability? Does Alphacool make good components or it should be better to look for other rads?
2) What about this XSPC rad? I was having a look at several reviews and they looks good enough (similar to my current HWL GTS rads but less restrictive and also with good quality).
3) Is one D5 pump enough for this loop or it will be better to use 2 x D5 pump?
Many thanks all in advance!
R9 3900x
(10 items)
AMD Ryzen9 3900x
Gigabyte X570 Aorus Xtreme
EVGA RTX 2080 Ti XC Ultra
G.Skill 32 GB (2x16) DDR4 3200 MHz CL14 @ 3800 CL16
Corsair MP600 1TB m.2 SSD
Seasonic 850w Prime Ultra Titanium
Phanteks Luxe 2
Dell Alienware AW3418DW
Keyboard
Corsair K63 Wireless
Mousepad
Logitech G900 Chaos Spectrum
MoDeNa is offline
post #2 of 9 (permalink) Old 09-19-2019, 02:04 AM
Smug, Jaded, Enervated.
GHADthc's Avatar
Rep: 101 (Unique: 66)
No such thing as overkill here!
To answer your questions, firstly, Alphacool radiators are perfectly fine (I have several 180mm rads in my current project, and have used their rads for years without issue), they perform great (They aren't the best out there, but the difference in marginal between the top end rads), they look great, and these days their quality is fine (but be sure to thoroughly flush them regardless)...and for 45mm thickness rads, I don't think there is anything else on the market that competes really.
The XSPC rad should be fine for its purpose, the performance difference between all the super thin rads is marginal at best, but keep in mind, that being 22fpi, it'll require a bit more airflow than the other rads, and probably raise the sound output of your set-up slightly (it'll probably be negligible though), you could just go with an Alphacool ST30 480mm rad instead, they are only 10mm thicker than the XSPC radiator, and far less dense in fins per inch.
And I would recommend going with two D5's, so that if one dies, you have redundancy in the loop.
Otherwise, it all sounds like it will be a pretty solid loop, and impressive system.
GHADthc is offline
post #3 of 9 (permalink) Old 09-19-2019, 05:15 AM
Shawnb99's Avatar
Rep: 24 (Unique: 16)
I don’t see a flow meter among your list. I suggest adding one.
My Baby
(24 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Watercool HEATKILLER IV PRO
2x Swiftech MCP35X2 with MCP35X2 Heat Sink
2x Hardware Labs Black Ice Nemesis 360GTR
2x Hardware Labs Black Ice Nemesis 360GTS
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
2x Noctua NA-A15 PWM
24x EK Vadar F4120ER
Case Labs Magnum M8 with Pedestal
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Mr. Speakers Aeon Closed
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is online now
post #4 of 9 (permalink) Old 09-19-2019, 12:41 PM - Thread Starter
MoDeNa's Avatar
Rep: 3 (Unique: 3)
Many thanks for your answer. One of my main concerns is about the quality of Alphacool rads, but as far as I know they look fine as you say, so know I feel a bit more confidence with them.
The free space in the side of the tower once the front radiator and fans are installed is 30 mm maximum, so I need to go with the XPSC TX rad without doubt if I want to carry out this setup as I have planned.
I didn't mention it but I will include one. In fact I will use the one I have in my current build (Aquaero flow sensor). Thanks for the reminder!
R9 3900x
(10 items)
AMD Ryzen9 3900x
Phanteks Luxe 2
Keyboard
Mousepad
MoDeNa is offline
post #5 of 9 (permalink) Old 09-20-2019, 12:38 AM
Vlada011's Avatar
Rep: 38 (Unique: 28)
Nice choice with Heatkiller parts. In every situation where you could choose Heatkiller block, pump, reservoir, combo use them.
Companies who didn't move production in China should be rewarded and helped to grow.
Alphacool V2 radiators look interesting on first place, I doubt performance could be worse then previous models.
It's full copper radiator. Only I would rather go on Black Ice Nemesis GTS/GTX.
It would be interesting comparison of new CORSAIR radiators and HW Labs. New CORSAIR radiators look to similar to Bitspower Leviathan and HW Labs, maybe HW Labs made them and if difference is small that' nice because CORSAIR is more avaialble then HW Labs Black Ice Nemesis.
But if I remember difference between Leviathan and Black Ice Nemesis is visible and worth buying original Black Ice Nemesis.
Vlada011 is offline
post #6 of 9 (permalink) Old 09-20-2019, 02:32 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 404 (Unique: 271)
The Corsair rads are rebranded HWL L Series, the same rads as the Leviathan. Corsair just did their usual ridiculous upcharge for putting a little sailboat logo on it. The Alphacool V2 is a better performing rad with less restriction.
ciarlatano is offline
post #7 of 9 (permalink) Old 09-20-2019, 11:17 PM
Vlada011's Avatar
But HW L series is not so good as Black Ice Nemesis GTS/GTX/GTR.
How much CORSAIR ask for their radiators? To be honest I like more clean radiators without names on them.
Vlada011 is offline
post #8 of 9 (permalink) Old 09-21-2019, 07:56 AM
ciarlatano's Avatar
Of course the L series is not as good. It is their budget line.
As far as pricing....the attached shows three prices for the same rad with different brand names. The Corsair is upcharged 50% for the logo. :eyeroll:
PPC is really high on the Leviathon. It can be had for ~$50 elsewhere.
post #9 of 9 (permalink) Old 09-22-2019, 05:07 AM - Thread Starter
MoDeNa's Avatar
Rep: 3 (Unique: 3)
I would prefer to use HWL SR2 black ice radiators but due to case space limitations (bottom rad max width is 125mm), front rad with fans to a 36omm bottom rad is 76mm and side space with front rad installed is 30mm, I need to go with the setup metioned in the first post.
Hope to do this config possible, I have my doubts but I will try it. I am thinking in +/- things of doing a dual loop for CPU and VGA vs one single loop for everything.
Many thanks for your comments!
R9 3900x
(10 items)
AMD Ryzen9 3900x
Phanteks Luxe 2
Keyboard
Mousepad
MoDeNa is offline
