Optimus Waterblock - Page 2 - Overclock.net - An Overclocking Community
Optimus Waterblock
post #11 of 4237 (permalink) Old 10-04-2019, 11:42 PM - Thread Starter
Section31's Avatar
Rep: 39 (Unique: 18)
I just got the block.
Section31 is offline
post #12 of 4237 (permalink) Old 10-05-2019, 12:39 AM
Rep: 8 (Unique: 6)
that was fast. My is still coming. It may take a while.
Miiksu is offline
post #13 of 4237 (permalink) Old 10-07-2019, 08:02 PM - Thread Starter
Section31's Avatar
More block comparison
The Ever Ongoing Build. 3950X. X570 Hero VIII, 32GB GSkill Trident Z 4000mhz, Seasonic Prime Titanium 1000Watt, 1TB 960 Pro, 1TB WD SN750.
post #14 of 4237 (permalink) Old 10-07-2019, 08:25 PM - Thread Starter
Section31's Avatar
The top is modular. Very much appreciated.
post #15 of 4237 (permalink) Old 10-15-2019, 08:42 AM
Rep: 8 (Unique: 6)
Finally I got mine. That was quite expensive for a block. Total cost was 165$ (150â‚&#172. I ordered the cheapest one the black model. The Anfi-Tec Drei block is still in the delivery. I still not have the new Ryzen 3950X CPU. It was delayed to november. I can still compare those blocks to 2700X and later to the 3000 series.
Miiksu is offline
post #16 of 4237 (permalink) Old 10-15-2019, 09:47 AM
crerc's Avatar
Rep: 0
I received my AM4 plexi block and put it on over the weekend. Previously, I had the Bykski AM4 TR4 block on a 3900X.
Comparing the temps at load with the same settings, I'm noticing a 5C improvement.
- PBO on, P95 small FFT
Bkyski - 97C
Optimus - 92C
- Gaming (Civ 6)
Bykski - 70C
Optimus - 62C
NOTE: I have it installed in the default orientation it came in (ie. inlet at bottom, outlet at top). Not sure if this is the optimal orientation?
crerc is offline
post #17 of 4237 (permalink) Old 10-16-2019, 08:39 AM
Rep: 8 (Unique: 6)
Bkyski - 97C
Optimus - 92C
- Gaming (Civ 6)
Bykski - 70C
Optimus - 62C
Bykski is not the best CPU block but still quite impressive. And I just ordered for my setup a Bykski GPU block for Radeon 5700XT :d Because I did not want EKWB and not Alphacool. Seems I can do comparison with: Anfi-Tech Drei, Optimus Foundation and old Aqua Computer Derlin.
Miiksu is offline
post #18 of 4237 (permalink) Old 10-16-2019, 10:03 AM - Thread Starter
Section31's Avatar
Quote: Originally Posted by Miiksu View Post
Bykski is not the best CPU block but still quite impressive. And I just ordered for my setup a Bykski GPU block for Radeon 5700XT :d Because I did not want EKWB and not Alphacool. Seems I can do comparison with: Anti-Tech Drei, Optimus Foundation and old Aqua Computer Derlin.
That is about right. The Bykski and Heatkiller are about 2 degree apart themselves. So 5 degrees difference would be correct.
post #19 of 4237 (permalink) Old 10-16-2019, 09:47 PM - Thread Starter
Section31's Avatar
I am curious if anyone bought optimus GPU waterblock. I want to see how it performs so i can determine the direction for the 3080TI.
post #20 of 4237 (permalink) Old 10-17-2019, 09:58 AM
Rep: 8 (Unique: 6)
I have now both CPU block. Optimus is so nicely finished. But also Anfi-Tec Drei looks promising even the heat plate is thinner than Optimus block. I can't wait to test the performance of them. Anfi-Tec Drei came in the sealed can and I had to open it up [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
Miiksu is offline
