Optimus Waterblock - Page 263 - Overclock.net - An Overclocking Community
Optimus Waterblock
post #2621 of 2656 (permalink) Old 03-25-2020, 07:06 PM
Old and Decrepit
JustinThyme's Avatar
Rep: 45 (Unique: 31)
Quote: Originally Posted by criskoe View Post
What were the temp differences with the sigv2 stock as shipped vs sigv2 modified?
Mine as shipped without springs worked great. First springless Mount was just taking the springs out. No grinding, cutting reconfiguring necessary and I’m fairly certain my temps are a bit better than Thrashes. Mine is the full nickel version. 10-12C spread with AVX workloads 14 cores at 4.8GHz 1.225 Vcore and no AVX offset. Max 80C after multiple 30 minute runs with 24C ambient.
Das Beast
(30 items)
I9 9940X
Asus Rampage VI Extreme
Asus Strix 2080 Ti OC
Corsair Dominator Platinum RGB CMT64GX4M8Z3600C16
Samsung 960 Pro
Samsung 850 EVO
Intel 905P
Corsair AX1600i
2x Heat Killer IV Strix 2080ti blocks with back plates
Aquaero 6 pro controller
Corsair SP120 PWM x 11
Heatkiller IV pro
Heatkiller Tube 200
EKWB 480 XE
EKWB 480 PE
EKWB 360XE
Corsair LL 120 PWM X8
D5 pumps x2 in serial bitspower head with mod kit
Heatkiller VRM block
Aquacomputer Next D5 pump mounted to Heatkiller tube 200 res
Phantek Entoo Elite Black
Operating System
WIN 10 Pro
ASUS PG349Q
Keyboard
ASUS Core
Mouse
Asus spatha
Mouse
Asus Sheath
Audio
Audio Engine A5+
Audio
SVS1000 Sub
Audio
Audio engine 192kBPS DAC
JustinThyme is offline
post #2622 of 2656 (permalink) Old 03-25-2020, 08:40 PM
KedarWolf's Avatar
Rep: 295 (Unique: 189)
My 3950x at 1.25v, VDDGs at .950v, VDDP at .900v, memory at 1.45v, with my AMD Foundation while looping Cinibench my temps hover around 60C in HWInfo.
I used the spread method with a drop of thermal paste on each of the three chiplet areas, then heated up the block and CPU with Cinebench, shut down immediately.
Then I loosened the block screws without losing contact, moved the block around slightly to respread the Grizzly Kryonaut, tightened the screws enough I never bowed the board. Have those temps.
KedarWolf-AMD 3950x @ All Core 4.3GHZ - Miotherboard MSI X570 Prestige Creative - G.Skill Trident Z Neo CL16 3600MHZ 2x16GB 14-15-8-13-29 1T @ 3800MHZ 1.5v Gear Down Mode Enabled- Gigabyte/EVGA 2X 1080 Ti SLI FTW3 Kingpin Fix BIOS - 1TB Samsung 970 Evo Plus M.2 System-Game Drive- 4TB Hitachi 7200RPM Storage Drive- PSU Corsair AX1500i - Samsung 49" CHG90 QLED 32:9 Gaming Monitor - Logitech G502 Lightspeed Mouse- Logitech Lightspeed Mouse Pad
3950x
MSI X570 Creation
2x EVGA 1080 Ti
Trident Z Neo 2x16GB 16-16-16-36 3600
Samsung Evo Plus M.2
Toshiba X300
Corsair AX1500i
EKWB Phoenix 240
EKWB Predator 360
Thermaltake X9
Operating System
Windows 10 Enterprise 1909
49" Samsung LC49HG90DMNXZA
27" BenQ GW2760
Keyboard
Logitech G910
Mouse
Mousepad
Logitech Lightspeed
KedarWolf is offline
post #2623 of 2656 (permalink) Old 03-25-2020, 11:05 PM
Old and Decrepit
Yeah that’s my favorite method with Kryonaut. Run it hot, loosen screws just enough to move the block ever so slightly, re torque mounts and let her rip. You should note that In 24-48 hours temps will get even better as it sets and cures. Good stuff. One step down from LM.
Das Beast
(30 items)
I9 9940X
Samsung 960 Pro
Samsung 850 EVO
Intel 905P
Corsair AX1600i
Heatkiller IV pro
Heatkiller Tube 200
EKWB 480 XE
EKWB 480 PE
EKWB 360XE
Operating System
WIN 10 Pro
ASUS PG349Q
Keyboard
ASUS Core
Mouse
Asus spatha
Mouse
Asus Sheath
Audio
Audio Engine A5+
Audio
SVS1000 Sub
Audio
post #2624 of 2656 (permalink) Old 03-26-2020, 12:57 AM
zGunBLADEz's Avatar
Rep: 103 (Unique: 76)
Quote: Originally Posted by ThrashZone View Post
Hi,
I believe you've said at least a few times not to use mothers on plated materials.
I did its on the warning itself in bare copper its not an issue tho xD
Same as toothbrush "es" xD and toothpaste... Same ordeal lol.
zGunBLADEz is offline
post #2625 of 2656 (permalink) Old 03-26-2020, 02:31 AM
KCDC's Avatar
Rep: 28 (Unique: 23)
Maybe I've been "spreading" paste wrong my entire life but having a new mobo out of the case, using the Noctua goop with a credit card, I got an even layer in no time. I couldn't do this with Kryonaut however I was trying that with the mobo in case vertical with their flappy spatula and a bunch of stuff in the way. Was pasting it like a hole in drywall since I couldn't get it to just spread. Used a pea drop of NT-H1 like I usually do and did the spread... has a better consistency for spreading and now my cores seem to be a lot closer in temps. Gues I am pleased with that since when I used to do the spread for workstations and servers back in the old days it was not fun. Still running more stressing on this Encore, but I can now drop my 49 down to 1.290 which was 1.30. Did a few runs at 50 1.32 with cinebench but crashed eventually. Realbench @ 1.335 wasnt happy either. Fine with 49 1.29. This sig V2 is a delight.
Also, this is what I guess was in my loop after a couple months of running the V2. Seems more like tarnish than gunk when I was toothbrushing it, no actual blockage. Running detergent as we speak, primochill reboot since I'm lazy and need this back up in the morning.
Name:	Annotation 2020-03-26 022828.jpg
Name:	Annotation 2020-03-26 022854.jpg
ZMT watercool setup -- Phanteks Enthoo Elite -- hwlabs gtr 420 x 2 -- -- xspc tx360 crossflow -- noctua A14 PWM x9 -- 10940x -- Rampage VI Extreme Encore
Optimus Signature V2 -- 64gb 3200 tridentZ Royal CL14 @3600 CL16 -- AX1500i -- 2x 7600p nvme -- EK ZMT Tubing -- Ek Fittings -- dual Aorus Waterforce xtreme 2080ti -- asus PG279UZ monitors x3 7680x1440 surround
Bertha5.5
(22 items)
9900x
X2399 TUF Mk1
Aorus 2080ti Waterforce Xtreme
TridentZ Royal 3200 CL14
VROC 7600P x2
Ax1500i
HWL GTR 420 x2
XSPC TX360 Crossflow
EK ZMT 10/16
Corsair XC9
Corsair XD5
EK 10/16 Fittings
Noctua A14 PWM x9
Noctua NF-P12 PWM redux x3
Corsair Commander Pro
Enthoo Elite
Operating System
Win 10 Pro 64
Asus PG279QZ x3
Keyboard
Corsair K95 RGB Platinum
Mouse
Corsair Nightsword
Mousepad
Corsair MM800
KCDC is offline
post #2626 of 2656 (permalink) Old 03-26-2020, 03:09 AM
KedarWolf's Avatar
Before I added the three drops on top of my chiplet areas on my 3950X, I used a surgical glove with no powder on it and spread the Kryonaut thinly over the entire CPU.
3950x
MSI X570 Creation
2x EVGA 1080 Ti
Toshiba X300
Corsair AX1500i
EKWB Phoenix 240
EKWB Predator 360
Thermaltake X9
Operating System
27" BenQ GW2760
Keyboard
Logitech G910
Mouse
Mousepad
Logitech Lightspeed
post #2627 of 2656 (permalink) Old 03-26-2020, 03:29 AM
Overclocker in training
ThrashZone's Avatar
Rep: 150 (Unique: 92)
Hi,
SigV2 doesn't get any sun light or light at all seeing it has no plexi so yeah you need to get some real fluid man no reason for that to happen enclosed.
Only other way it might happen that fast is if there is air pocket from sitting for a while copper wet/ dry tarnish.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is online now
post #2628 of 2656 (permalink) Old 03-26-2020, 07:37 AM
ThrashZone's Avatar
Quote: Originally Posted by ciarlatano View Post
Foundation is still the block to buy given the price/quality/performance. The V2 is nice if you don't mind spending for the very best despite modest gains.....the Magnitude is a no go in my eyes - too expensive, and nothing about it warrants it.
Hi,
Never put the two together but here they are foundation 1c cooler at 4.8 against the ek top dog mag nickle
120.us verses 300.us+- depending on where you get it.
Spoiler!
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #2629 of 2656 (permalink) Old 03-26-2020, 08:13 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 427 (Unique: 284)
Hi,
Yup, that was exactly my point. Let's even call them equal performance. You would have to be one hard up EK fan boy to buy a Magnitude over a Foundation. And when they start crying "oh! the restriction!"....well, you could buy a Foundation AND another D5 or DDC and still be at a significant savings over buying a Magnitude....heck, you may even be able to buy two more pumps if you find a deal. ::insert the ROTFLMAO emoji here::
ciarlatano is offline
post #2630 of 2656 (permalink) Old 03-26-2020, 09:33 AM
tatmMRKIV's Avatar
Rep: 131 (Unique: 88)
Quote: Originally Posted by zGunBLADEz View Post
lol somebody is really surfing this forums as lately right steve?
https://www.youtube.com/watch?v=-sv6CE9wybI
remember the red copper type looking that i mention on the ek topic well thats what he ended with lol
theres not...... i will expend all this money on this machine and it will do all the job for me type of deal..
cheapo way to do that with same effects boil your copper piece on water with vinegar you will end with similar results but faster and way cheaper...
you still need some elbow grease to polish the copper.
i do not recommend using mothers inside where the fin area is... if you dont know how to get the residue off that the mother cream leave without reverting to boiling it again lol "red looking copper piece again"... but it will clean it spotless and shiny copper like it aint nothing lol
as you dont want that residue mothers cream leave inside your loop.. alot of bare cleaning with alcohol/water after to remove the protective layer and residues from the fins..
thats why i prefer copper easiest metal to clean in this circunstances... now nickel... well dont use mothers IN ANY PLATED metal surfaces.. XD
also, if the nickel is bad ((cough EK cough)) when you using cleaning methods like toothpaste and brush etc you are eating away the plating little by little and all it takes is a little "microscopic" / "imperfection" entrance to the bare copper/brass and it will mess it up just like that eventually..
you can also clean the stuff with electrolysis but now thats more complicated ""maybe dangerous process"" lol
https://www.youtube.com/watch?v=rUVdIKNX2P8
now if you really love your block that much you can plate this yourself.. this is a summary on howto..
https://www.youtube.com/watch?v=G-PtnwtOR24
you can also remove the plating if is messed up XD
what the heck is your problem why are you trying to stir some crap...
DROP IT
(If y'all) ain’t ready for the old murder, then what you gonna do with the new me?
tatmMRKIV is offline
