Optimus Waterblock - Page 266 - Overclock.net - An Overclocking Community
Optimus Waterblock
post #2651 of 3449 (permalink) Old 03-27-2020, 08:38 AM
KedarWolf's Avatar
Rep: 300 (Unique: 192)
Quote: Originally Posted by Papazmurf View Post
I used to swear by the dot and/or line method. However on these HEDT chips, I was really struggling to get even core spread with thermals. I now spread the TIM with a plastic card on every mount as it gives me the most consistent results.
Also, the instructions in the Kyronaut package say to spread. Why bother putting a how to and not mention other methods, unless Thermal Grizzly thinks it's that much better of a process. That was my logic anyways, and anecdotally it has held true. It's more of a pain in the ass to get a good spread than putting a dot or line, but imo it's worth it for every mount.
With Kryonaut peeps might want to try spreading it thinly with non-powdered surgical gloves, tighten block, run RealBench a few minutes, heat the TIM up, shut down immediately, loosen the screws on the block until you can just move it without losing contact, slide it around in every direction 30 seconds, tighten screws again, TIM on entire CPU IHS.
I did that on my 3950X except I also put a small drop of Kryonaut over each of the three chiplet areas.
At LLC3, 1.2625v CPU, 1.45v RAM, .1.1125 VOC, .950 VDDG's and .900v VDDP, with one 360 RAD and an Optimus Foundation CPU block, I hover around 60C while looping Cinebench
KedarWolf-AMD 3950x @ CCX 44.50/44.25/43.75/43.25GHZ - Motherboard MSI X570 MEG Unify - G.Skill Trident Z Neo CL16 3600MHZ 2x16GB 14-16-15-13-28 2T - 246 tRFC @ 3800MHZ 1.5v Gear Down Mode Disabled- Gigabyte/EVGA 2X 1080 Ti SLI FTW3 Kingpin Fix BIOS - 2x 1TB Sabrent Gen 4 M.2 System/Storage Drives- PSU Corsair AX1600i - Samsung 49" CHG90 QLED 32:9 Gaming Monitor - Logitech G502 Lightspeed Mouse- Logitech Lightspeed Mouse Pad
3950x
MSI X570 MEG Unify
EVGA 1080 Ti SC Black EKWB Waterblock And Backplate
Gigabyte 1080 Ti FE EKWB Waterblock And Backplate
Trident Z Neo 2x16GB 16-16-16-36 3600
Sabrient Gen 4 1TB M.2
Corsair AX1600i
EKWB Phoenix 240
EKWB Predator 360
Thermaltake X9
Operating System
Windows 10 Enterprise 19628
49" Samsung LC49HG90DMNXZA
27" BenQ GW2760
Keyboard
Logitech G910
Mouse
Mousepad
Logitech Lightspeed
KedarWolf is offline
post #2652 of 3449 (permalink) Old 03-27-2020, 09:12 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 440 (Unique: 293)
Quote: Originally Posted by KedarWolf View Post
With Kryonaut peeps ......
My favorite flavor! Just in time for Easter! But, marshmallow is really messy to use as TIM.
ciarlatano is offline
post #2653 of 3449 (permalink) Old 03-30-2020, 11:57 AM
Overclocker in training
ThrashZone's Avatar
Rep: 170 (Unique: 103)
Hi,
Out of the box EK acetal or nickle tops were fails even after several mounts
First render hitting 93c
Only way to keep ek blocks in the game was to alter it's mount not using the springs and using a bitspower summit mount I had that is skinny enough to get though ek narrow holes in it's mounting bracket
Tried a different timm application worked great oddly on both modified ek and non-modified foundation
Did a thin coat on both the chip and on the cold plate got acetal to foundation older results level too
Unfortunate for acetal same application of timm got foundation to sigV2 temps I'm wondering now what it's going to do for sigV2 and nickle top
I really love the foundation out of the box big winner didn't have to anything it just works thermal grizzly hydronaut is growing on me too !
Same setup as these two prior runs 4.5-4.8 blender opendata full long test manual 1.25v
https://www.overclock.net/forum/61-w...thread-26.html
https://www.overclock.net/forum/61-w...l#post28379742
Name:	Foundation-4.8-4.5 shootout verses EK Acetal all polished.jpg
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
Audio
10900k
Samsung 970 evo 500gb
EVGA 1000P2
Corsair 450D
Operating System
ThrashZone is offline
post #2654 of 3449 (permalink) Old 03-30-2020, 07:13 PM
Zurv's Avatar
Rep: 18 (Unique: 15)
Any updates on the water blocks?
Zurv is offline
post #2655 of 3449 (permalink) Old 03-30-2020, 07:28 PM
criskoe's Avatar
Rep: 5 (Unique: 4)
Aside from watercooling gear they make medical equipment. I’m pretty sure they make components for ventilators. My guess that’s their number 1 priority right now as it should be. I doubt people that have pre orders wanna hear that but hopefully people can understand and wait a bit longer.
Current
9900KS
Asus Maximus XI Extreme
Nvidia 1080Ti FE
Corsair Dominator Platinum RGB
Samsung 970 EVO
Evga 1200 P2
Ek Magnitude
EK D5 Kinetic D5 TBE
2X EK 360 PE
EK 1080ti Full Cover Block
AC High Flow USB
10X Corsair 120mm ML Pro Fans
Lian Li 011 Dynamic XL
criskoe is offline
post #2656 of 3449 (permalink) Old 03-30-2020, 07:30 PM
Food Editor
skupples's Avatar
Rep: 720 (Unique: 378)
yeah they said something about the factories they get their fittings made in being converted to making vent fittings.
they did not state anything getting in the way of block milling though. they said AMD blocks are churning as we speak, then supposedly GPUs.
it'll be nice to quietly game into the apocalypse.
Add me on Steam, same name
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #2657 of 3449 (permalink) Old 03-31-2020, 09:21 AM
Rep: 0
This was their last substantive update:
Quote: Originally Posted by Optimus WC View Post
Updates! So we're still making Threadripper and will be shipping hopefully this week. Some of our partners for finishing and anodizing (we don't do that in house) will hopefully stay open, but it is causing some delays.
For Threadripper, the first blocks that will ship will be copper with either clear acrylic or black acetal tops. And either black or silver frames. If you preordered, you can change your order if you want all black or to get the block faster (if you ordered nicke0L.
Shipping is weird because of the covid chaos. So things aren't exactly normal. But when were they ever?
Also, in case you heard that Chicago businesses that aren't essential are shut down. Good news, our office is still open because parts for ventilators and hospital bed hydraulics are made at our facility. Some of our fittings will be delayed because of it (anything round, really).
EU distribution and the like is all on hold until life gets a little more sane again.
But we'll be working to get blocks out the door as long as people are still feeling well!
Made at their facility - not sure if that means they make them or share equipment or space with others, but it sounded like they were still working on the blocks and hoping they might ship the TR's last week - that didn't happen but maybe not too much longer, for the non-plated, non-anodized versions anyway.
qes27 is offline
post #2658 of 3449 (permalink) Old 03-31-2020, 10:17 AM
Food Editor
skupples's Avatar
shared equipment.
you say "I need 100 of these made!" and the business that ACTUALLY makes them says "cool story, but COVID, so we're only making Government grade fittings"
skupples is offline
post #2659 of 3449 (permalink) Old 03-31-2020, 02:02 PM
Rep: 0
shared equipment.
Yes, they did say there was a conflict with round fittings specifically, and the third-party plating and anodizing. The possibly good news for those waiting on TR blocks is that Optimus doesn't need to make any round fittings to wrap those up and ship them out.
... So much right now is simply human labor to assemble and ship blocks, that's where the entire holdup is.
That was their very last update, so hopefully - they seem to say anyway - that manufacturing isn't the hold up at this point, aside from plating and anodizing.
qes27 is offline
post #2660 of 3449 (permalink) Old 03-31-2020, 02:48 PM
ThrashZone's Avatar
Hi,
If anyone wants to correspond [email protected] goes directly to dah man
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Other
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
Operating System
Keyboard
Logitech G710+
Mouse
Audio
10900k
EVGA 1000P2
Corsair 450D
Operating System
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
tistou77
