High "GPU" Temps After Watercooling - Page 3 - Overclock.net - An Overclocking Community
post #21 of 24 (permalink) Old 10-09-2019, 02:52 PM - Thread Starter
snipersaim's Avatar
Rep: 0
Quote: Originally Posted by skupples View Post
correct, the long flat top screws are for back plates.
the small button heads are for no back plate.
yes, it's possible the thermal pads are too thick/in the wrong place, but didn't OP say they were pre-applied? that would drastically reduce error, not increase it
was the card acquired second hand? If so, then its more likely there are thermal pads in the wrong place. Most blocks use .5mm and 1mm pads.
you could always look up the schemes and replace.
I found a thread on the EVGA site which suggests the thermal pads are 1mm thick. Now, the card is back together and running so I cannot currently measure their thickness with a caliper. The attached photos are the best I can do at the moment. The card was purchased brand new, and the block was purchased off of the EVGA site.
snipersaim is offline
post #22 of 24 (permalink) Old 10-09-2019, 02:58 PM
skupples's Avatar
Rep: 551 (Unique: 312)
sorry for the repeat, were they pre-installed? if so, then 99% chance they're fine.
typically you have both .5 and 1mm pads you install yourself, i could see that .5m gap being the cause if you did happen to do the work yourself.
assuming the pads came pre-installed, and you can prove they're wrong, RMA or replace. s
skupples is offline
post #23 of 24 (permalink) Old 10-09-2019, 03:01 PM
Bratislav's Avatar
Rep: 3 (Unique: 3)
Compared to the thickness of the pcb, they are thicker than 1mm.
Bratislav is offline
post #24 of 24 (permalink) Old 10-09-2019, 05:43 PM
Overclocker in training
ThrashZone's Avatar
Rep: 71 (Unique: 55)
Hi,
I believe evga has terrible thermal pads anyway they are more like double stick tap and greasy as hello
You might consider getting some 1.0 and 0.5 thermal pads they are pretty cheap and better
https://www.amazon.com/ARCTIC-Therma...0K0KW3Z481TAHT
https://www.amazon.com/ARCTIC-Thermal-Efficient-Conductivity-Handling/dp/B00UYTTXSM/ref=pd_cp_147_1/135-0304385-6124729?_encoding=UTF8&pd_rd_i=B00UYTTXSM&pd_rd_r=6cb5d80d-9bad-4f86-bc0a-9afe76c39639&pd_rd_w=OUVk7&pd_rd_wg=xDv6r&pf_rd_p=ef4dc990-a9ca-4945-ae0b-f8d549198ed6&pf_rd_r=Z94X7T0K0KW3Z481TAHT&psc=1&refRID=Z94X7T0K0KW3Z481TAHT
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
