Old Crosair h100i. Unusally high temps - Page 3 - Overclock.net - An Overclocking Community
post #21 of 31 (permalink) Old 10-12-2019, 05:53 PM
Hardware Princess
Hydroplane's Avatar
Rep: 31 (Unique: 26)
Quote: Originally Posted by bhsmurfy View Post
Yes. I have cut the rad out and removed the rubber gourmet from inside the block that focuses water into fins(the submersed pump i use is too strong for the gromet to be in there and im not finding any negative from it *yet*
I have a res outside my window where i have a couple gallons of water/antifreeze/organic hydrogen peroxide flowing. The rez sits in like a pile of snow outside my window. My only problem now is I cant get pass 4.9stable. Ive gotten a couple post at 5Ghz but get hardware checks/clock watch dogs/kernel exceptions etc BSOD when logging into windows. Think its this VRM on the ASRock z97 f4tality killer was a cheap mobo at the time and surprised it has lasted this long with all the abuse and shorts and forgetting to ground my self and bending capacitors i have done to it.
I have a liquid metal in the mail.
Im waiting for a waterblock for my 2080 ti also. and a actual ek block for my cpu instead of the gutted h100i.
672 r15. Not bad for a i5 4690k considering stock score is 430-450 i think.
I'm interested in the hydrogen peroxide, what purpose does it serve? Anti-microbial? Doesn't it evaporate very readily, or does mixing it with water reduce that?
So far, I've tried propylene glycol, methanol, and isopropyl alcohol in my loop. Running isopropyl/water right now. Keeps it clean lol.
CHILLER DESTRUCTION
Build Log - White Voodoo
Z390 Station
(11 items)
White Voodoo
(15 items)
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
Trident Z 3200c14 @ 4133c16 1.5v
970 Evo Plus 250gb
silverstone 1200 from 2008 (other one exploded)
HWLabs GTX 360 Rad (in RED)
3x EK Vader 120mm 2200rpm Fans
Dimastech Test Bench
AOC Agon AG251FZ 240Hz
Audio
Built-in Monitor Speakers (3 watt)
7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
2 x Aorus Waterforce WB 1080 Ti @ 2037/6318
Trident Z 16gb 3200c14 @ 3800c16 1.50V (the other two sticks were sacrificed)
960 Evo 1TB
EVGA 1600 T2
HWLabs GTR 420+280 Rads
7 x Noctua Industrial 140mm 3000 RPM Fans
EK D5 Pump/Res (with RGB!)
LD Cooling PC-V7
Operating System
Windows 10 LTSB
NEC PA271W
Keyboard
Razer Blackwidow Chroma V2
Mouse
Logitech M510
Mousepad
anime tiddy mousepad
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Hydroplane is offline
post #22 of 31 (permalink) Old 10-12-2019, 07:32 PM - Thread Starter
bhsmurfy's Avatar
Rep: 5 (Unique: 5)
yes anything with an extra hyrdo to it will ad very rapidly. My res is a old pony keg thats light proof so only my lines are the only place light hits. I work at a brewery so we have 55gal drums of organic-peroxide outside. We use it after we brew sours so im assuming it kills bacteria. Again. This is some me just guessing ****. Id assume anything iso evaps faster than hydro or meth tho. Methanol is just expensive here and i dont trust the plastics of my gutted h100i block, lol.
I've had nothing green building up tho.
it works...
delidding and reapply TIM brought my core1 from 94+ and others at 55c @ 4.3g 1.3vcore to all of them at 63c full load at 4.7g at 1.375vcore.
I didnt win the silicon lottery so my chip eats watts.
Edit. I know the waterblock is upside down. vertical cores in the i5 tho so same pattern as long as its not horizontal.
bhsmurfy is offline
post #23 of 31 (permalink) Old 10-12-2019, 11:37 PM
NewType88's Avatar
Rep: 1 (Unique: 1)
Why does your local library have a table vice ?
NewType88 is offline
post #24 of 31 (permalink) Old 10-13-2019, 12:19 AM - Thread Starter
bhsmurfy's Avatar
Rep: 5 (Unique: 5)
They have a tool section. Just about everything to build a house and or a car.
Library in remote mountain towns are normally top notch and have tools and recreational things to take out too. Not just books.
bhsmurfy is offline
post #25 of 31 (permalink) Old 10-13-2019, 01:30 AM
NewType88's Avatar
Rep: 1 (Unique: 1)
Library in remote mountain towns are normally top notch and have tools and recreational things to take out too. Not just books. [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
Oh that’s pretty cool. I don’t see how you deal with that snow though. I couldn’t do it 😜
post #26 of 31 (permalink) Old 10-13-2019, 04:42 PM - Thread Starter
bhsmurfy's Avatar
Rep: 5 (Unique: 5)
Yeah its sweet i like it. I do tons of skiing and snowmobiling
bhsmurfy is offline
post #27 of 31 (permalink) Old 10-13-2019, 05:58 PM
skupples's Avatar
Rep: 588 (Unique: 329)
what about ph and corrosion control though? You're only accounting for one of the two main coolant variables. distilled's ph does nothing but go up, every second it spins in your loop.
skupples is offline
post #28 of 31 (permalink) Old 10-13-2019, 06:10 PM
Ragsters's Avatar
Rep: 220 (Unique: 204)
Sorry to thread jack but does a AIO cooler need to be used ever so often? I currently have one sitting in its box for like a year now.
Tiny Dancer
(19 items)
Son's Build
(16 items)
White Noise (R.I.P)
(31 items)
i7 6800k
Asrock X99e-itx
RX Vega 56
Corsair Vengence LPX
SAMSUNG 960 EVO M.2 500GB NVMe
Corsair SF600w
Corsair H75
NF-F12 industrialPPC-2000 PWM
Ncase M1 V5 (Silver)
Operating System
Windows 10
BenQ 32" IPS 4K (BL3201PH)
Keyboard
Vortex Poker 3 (White with White LED)
Mouse
Logitech G102 Prodigy (Matte White)
Mouse
Glorious PC Gaming Race XXL Extended
Audio
Soundblaster Omni 5.1
Audio
Sennheiser HD 598
Audio
kanto Yu2 Desktop Speakers (Gloss White)
Audio
Kanto Sub 6 (Gloss White)
AMD Phenom II X6 1055T
Gigabyte 880GMA-UD2H
Asus GTX 660 Ti
Corsair Vengeance Pro
PNY SSD CS1311
Samsung SSD 830
Samsung Spinpoit F3
Antec Neo Eco 520C
Corsair H50
Silverstone FT03B
Operating System
Windows 7 Home Premium 64bit
Samsung SyncMaster 220wm
Keyboard
Coolermaster Quickfire Rapid
Mouse
Steelseries QcK
Mouse
Zowie Mico
Audio
Logitech LS21 2.1 Stereo Speakers
i7-3770K
Asus Maximus V Formula
VisionTek Reference 7970
Diamond Reference 7970
Corsair Dominator-GT 16GB (4x4GB)
SanDisk Extreme Pro
Western Digital Black 640GB
Seasonic X650 (Custom MDPC Sleeve)
Swiftech MCP35X DDC Pump - White Top
XSPC AX360 Triple 120mm Radiator - White
EK-Supremacy Clean CSQ - Nickel Plexi
Bitspower Silver Shining Fittings
7 x Scythe Gentle Typhoons D1225C12B4AP-15
Bitspower Acrylic DDC Pump Top
Bitspower DDC Top Upgrade Kit
Bitspower DDC / MCP35x Pump Heatsink - White (BP-DDCPC-WH)
2 X EK-FC7970 Nickel CSQ GPU Block
2 X EK-FC7970 Backplate - Black CSQ
EK-FB KIT ASUS M5F Nickel Motherboard Block
XSPC AX480 Quad 120mm Radiator - White
EK-Ram Monarch X4 CSQ - (EN) Nickel Plexi
CaseLabs Merlin SM8 (All White)
Operating System
Windows 7 64bit Home Premium Upgrade
Achieva Shimian Lite "Perfect Pixels"
Keyboard
Das Keyboard Model S Professional
Mouse
Mionix Avior 7000
Mouse
SteelSeries QCK Mini
Audio
Klipsch Pro Media 2.1
Audio
Sennheiser 598
Audio
Creative Soundblaster Z
Other
NZXT LED Kit - 2 Meter - White (CB-LED20-WH)
Ragsters is offline
post #29 of 31 (permalink) Old 10-13-2019, 08:36 PM - Thread Starter
bhsmurfy's Avatar
Rep: 5 (Unique: 5)
I grew up on a farm. If I can handle watering 120 acres of blue fraser fir im sure I can handle watering my computer.
Empty it out, clean er with bio-green or some type of organic sink cleaner and refill and repeat.
Too cold of temp is my biggest enemy. Some nights I'll have to turn on my res warmer.
bhsmurfy is offline
post #30 of 31 (permalink) Old 10-14-2019, 04:46 AM
Hardware Princess
Hydroplane's Avatar
Want to see pics of said res warmer... sounds cool lol
CHILLER DESTRUCTION
Z390 Station
(11 items)
White Voodoo
(15 items)
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
970 Evo Plus 250gb
Audio
960 Evo 1TB
EVGA 1600 T2
LD Cooling PC-V7
Operating System
Windows 10 LTSB
NEC PA271W
Keyboard
Mouse
Logitech M510
Mousepad
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
