If you warped your IHS, the whole cpu would be bent. You really can't warp it at the temps where your pcb wouldn't burn to a crisp. I had an old coolermaster aio (3 or 4 years old) half/mostly die. It started getting high temps like yours, I replaced it and everything was good again. I kept it around and tried using it on my daughter's computer. It worked again for a little bit and then started performing like yours again where it cooled at a fraction of it's previous potential. Also you seem like the type that would find delidding your 4690k worth it.
Maximus VII Hero
Aorus 1080ti Waterforce
16 Gb Gskill Trident @ 2400,cas10,1.575v
8 Gb Gskill Trident @ 2400,cas10,1.575v
seagate barracuda 3T
Optane 900p 480G OS
Optical Drive
Asus BW-16D1HT
EVGA Supernova 1300 G2
Cooler Master MasterLiquid Pro 120 (cpu)
2 140mm case fans, 2 120mm
Fractal Design R4 (no window)
Operating System
W10 64 pro
panasonic TC-58AX800U
Audio
Focal Elear, Nova 40, 598se, HE4xx, DT990pro w b.boost earpads
Audio
SoundbasterX AE-5, onboard
Asus Z87 Deluxe
8Gb klevv urbane 2133
ROG Raidr 240Gb pcie
Pc Power&Cooling silencer Mk2 950w
Deepcool Lucifer V2
Operating System
W10 64 pro
Asus H81T/CSM
Samsung 850 evo 120gb
Skyvast 90w brick for hp pavilion something
SilverStone Tek Super Slim
SilverStone Tek PT13B
Operating System
W10 64 pro
24" samsung 1080p
Other
Intel wifi ac card and noname antennas
