Increasing Ambient Temps Effects - Overclock.net - An Overclocking Community
post #1 of 10 (permalink) Old 10-11-2019, 03:22 AM - Thread Starter
AMD Overclocker
Alastair's Avatar
Rep: 260 (Unique: 163)
So I am busy chilling at home. Messing with my Rig trying to get some overclock runs in. And I am noticing something odd to me. Today I am doing my benching in 20C ambient temps. And during my TimeSpy runs. My Vega64 only hit around 32C on the core (stock clocks getting a baseline measurement)
However yesterday. I was benching in a 25C ambient. And my temps were at 42C on the core for stock clocks. Why are my deltas 5C over and above the ambient temps? I have 640mmX45mm of radiator space. I dunno surely my delta should remain roughly the same? So 12c delta would mean +-37c?
On my CPU I am seeing even larger jumps in the Delta. I decided to do a stress test at 20C on my FX 8370 (5GHz @ 1.5v). And I hit around 50C-55C core. But if I run the same stress test at 25C ambient my core hits the 70C limit. Why am I jumping nearly 20C for only a 5C ambient increase?
If You Can Cool It! You Can Clock It! (AMD's Vishera)
GHOST rev 3.5
(26 items)
Rura Penthe
(12 items)
AMD FX-8370 DELIDDED @ 5050MHz 1.535V 2660MHz NB/2925MHz HTT
ASUS M5A99FX PRO R2.0
Sapphire RX Vega 64 (stock)
Corsair Dominator Platinum 2666 32GB @ 2127 9-10-9-27
Samsung 850 PRO 1TB
WD Blue 500GB
WD Blue 1 TB
Samsung Spinpoint HD502HI
Antec High Current Pro Platinum 1300W
XSPC D5 Bay Res
1x CoolerMaster Storm Force 200
XSPC Raystorm CPU Block
EKWB Coolstream PE360
6x CoolerMaster Jetflo's 120mm
XSPC D5 Vario
EKWB Coolstream CE280
6 Corsair ML140's
Barrow Vega 64 full cover waterblock.
NZXT Phantom 820 Black
Operating System
Windows 10 Pro 64-Bit
Dell SE2717H
Keyboard
Roccat Ryos MK Pro
Mouse
Mionix Naos 7000
Mouse
Mionix Alioth
Audio
GX Gaming SW-G2.1 3000
Audio
Kingston Hyper X Cloud Core
AMD Athlon 860K
Asus A88X-Pro
MSI R6850 Cyclone Power Edition
G-Skill Ares 2133 CL10 8GB (2x4GB)
Seagate ST1000VX003
Optical Drive
Samsung HD502HI
Seagate M12II 620W
Arctic Cooling Freezer A30
Corsair Carbide SPEC-02
Operating System
Windows 10 Home Edition 64bit
Keyboard
Razer Lycrosa
Intel Celeron G1840
MSI Z97-Guard Pro
Gigabyte RX580 Gaming 4G
Gigabyte RX570 Gaming 4G
XFX RX480 reference edition 8G
Gigabyte RX570 Gaming 4g
G-Skill Ares F3-1600C9D
Samsung 750 Evo 120GB
Gigabyte XP1200M
Stock
Operating System
Windows 10 Pro
Alastair is offline
post #2 of 10 (permalink) Old 10-11-2019, 04:44 AM
Hardware Princess
Hydroplane's Avatar
Rep: 31 (Unique: 26)
For me ambient temp makes roughly a linear difference. So if I drop the ambient 5C, my CPU temps might drop 4-6c. But this is on an open test bench. Heat can build up in cases. Same thing goes for cooling water in a custom loop. My temps are slightly lower when I first fire up versus running for a few hours.
CHILLER DESTRUCTION
Build Log - White Voodoo
Z390 Station
(11 items)
White Voodoo
(15 items)
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
Trident Z 3200c14 @ 4133c16 1.5v
970 Evo Plus 250gb
silverstone 1200 from 2008 (other one exploded)
HWLabs GTX 360 Rad (in RED)
3x EK Vader 120mm 2200rpm Fans
Dimastech Test Bench
AOC Agon AG251FZ 240Hz
Audio
Built-in Monitor Speakers (3 watt)
7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
2 x Aorus Waterforce WB 1080 Ti @ 2037/6318
Trident Z 16gb 3200c14 @ 3800c16 1.50V (the other two sticks were sacrificed)
960 Evo 1TB
EVGA 1600 T2
HWLabs GTR 420+280 Rads
7 x Noctua Industrial 140mm 3000 RPM Fans
EK D5 Pump/Res (with RGB!)
LD Cooling PC-V7
Operating System
Windows 10 LTSB
NEC PA271W
Keyboard
Razer Blackwidow Chroma V2
Mouse
Logitech M510
Mousepad
anime tiddy mousepad
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Hydroplane is online now
post #3 of 10 (permalink) Old 10-14-2019, 08:18 AM
broodro0ster's Avatar
Rep: 3 (Unique: 3)
Same for me.
When my room heats up by 5°C, my water heats up by 5°C and my components also heat up by 5°C.
But what can happen if that the warm air stays trapped around the computer case if it sits in a corner so you're pulling constantly warmer and warmer air in the case.
My ambient temp around my PC case is usually 2°C higher than roomtemp, but when I open a window, the difference is gone because there is air circulation in the room and around the PC case.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #4 of 10 (permalink) Old 10-14-2019, 09:18 AM
Ashcroft's Avatar
Rep: 87 (Unique: 70)
Measuring ambient temp can be tricky. Unless you have sensors right at the intakes there are lots of ways for air temp being drawn into the PC to be affected.
In my system the ambient intake temp closely tracks along with all other temps.
Ashcroft is offline
post #5 of 10 (permalink) Old 10-14-2019, 02:01 PM - Thread Starter
AMD Overclocker
Alastair's Avatar
I have a thermal probe in my case just in front of my HDD cages. I guess it measures a mix between Internal Case Temps or what I refer to as ICT and the ambient air coming in. My ICT temp is 29C. Ambient currently is 24C.this is during a CPU stress test.
GHOST rev 3.5
(26 items)
Rura Penthe
(12 items)
Samsung 850 PRO 1TB
WD Blue 500GB
WD Blue 1 TB
XSPC D5 Bay Res
XSPC D5 Vario
6 Corsair ML140's
Operating System
Dell SE2717H
Keyboard
Roccat Ryos MK Pro
Mouse
Mionix Naos 7000
Mouse
Mionix Alioth
Audio
Audio
AMD Athlon 860K
Asus A88X-Pro
Seagate ST1000VX003
Optical Drive
Samsung HD502HI
Seagate M12II 620W
Operating System
Keyboard
Razer Lycrosa
Intel Celeron G1840
MSI Z97-Guard Pro
Gigabyte XP1200M
Stock
Operating System
Windows 10 Pro
Alastair is offline
post #6 of 10 (permalink) Old 10-14-2019, 02:05 PM
skupples's Avatar
Rep: 581 (Unique: 325)
lower ambient, lower peak temp, if you have enough cooling potential.
skupples is offline
post #7 of 10 (permalink) Old 10-14-2019, 05:27 PM
D-EJ915's Avatar
Rep: 5 (Unique: 5)
Lower ambient also means it takes more time for the pc running to heat up the room which leads to temperatures going up in the pc as well. This is why for torture tests companies use "hot boxes" so components heat soak quickly.
Kanna
Dark X299
(7 items)
Mitty
(11 items)
Intel i7-7820X
Asrock X299 OC Formula
Asus Strix 1080 Ti
G.Skill DDR C14 3200MHz XMP 4x8GB
Intel P3520 NVMe PCIE AIC 1.2TB
Seasonic X-1250 1250 Watt PSU
NZXT Kraken 62
NZXT S340
Operating System
Windows 10 x64
Asus PA329Q 32" 4k 60Hz
Keyboard
Corsair K70 RGB Lux
Mouse
Logitech G600
Audio
HDMI to my Yamaha CX-A5000 preamplifier and studio monitors.
Intel i9-9900X
EVGA X299 Dark
EVGA Geforce GTX 1080 Ti
G.Skill 4x8GB C14 3200MHz
Samsung Pro 840 250 GB
EVGA Supernova G3 1300
Phanteks PH-TC14PE
Intel i7-3930k
Asrock Fatal1ty X79 Champion
EVGA GTX 780 Ti
Mushkin Redline
WD Velociraptor
Optical Drive
Asus DVD±RW
Seasonic X-1250
Corsair H100i V2
Fractal ARC MIDI
Operating System
Windows 7 Pro x64
Audio
Asus Xonar DX
D-EJ915 is offline
post #8 of 10 (permalink) Old 10-14-2019, 06:50 PM
Overclocker in training
ThrashZone's Avatar
Rep: 91 (Unique: 66)
Hi,
If you can control ambient you rule the day
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #9 of 10 (permalink) Old 10-15-2019, 01:44 AM - Thread Starter
AMD Overclocker
Alastair's Avatar
Quote: Originally Posted by ThrashZone View Post
Hi,
Well I'm getting an AC installed. So yeah
South African summer is coming and we already hitting mid 30s Celsius so its gonna be a hot summer.
I have also delidded my FX cpu and gone direct to die cooling with conductonaut as my Tim. Which shaved 20C off the package
GHOST rev 3.5
(26 items)
Rura Penthe
(12 items)
Samsung 850 PRO 1TB
WD Blue 500GB
WD Blue 1 TB
XSPC D5 Bay Res
XSPC D5 Vario
6 Corsair ML140's
Operating System
Dell SE2717H
Keyboard
Roccat Ryos MK Pro
Mouse
Mionix Naos 7000
Mouse
Mionix Alioth
Audio
Audio
AMD Athlon 860K
Asus A88X-Pro
Seagate ST1000VX003
Optical Drive
Samsung HD502HI
Seagate M12II 620W
Operating System
Keyboard
Razer Lycrosa
Intel Celeron G1840
MSI Z97-Guard Pro
Gigabyte XP1200M
Stock
Operating System
Windows 10 Pro
Alastair is offline
post #10 of 10 (permalink) Old 10-15-2019, 09:10 AM
Rep: 3 (Unique: 3)
Yes, my temp sensor sits outside the case about 3cm away from the intake fans so it isn't affected by the internal components. My PC and desk is located in the living room which has a pretty big volume and it doesn't heat up a lot from the PC under load. But in the area of 30cm around my PC case, there is trapped air that's about 2-3°C warmer than at the other side of my desk. So this means that hot exhausted air from my radiators is partially sucked back into the intake of my PC. Once I close my game, I see the temps of the air around my PC drop for 2-3°C. My PC is sitting along a wall, but not in a corner. If the PC was in corner, this effect would be worse.
And when I open 2 windows in my room so there is a constant circulation of air inside the room, my intake temps drop 2-3°C and it's equal to the ambient temp at the other side of my desk. So in summer when I open my windows, my roomtemp is 25°C, but I'm seeing the same component temps as in winter in a 22°C warm room without ventilation.
I bet having an AC inside the room that circulates air, gives the same results but with the benefits of a controlled environment.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
EK D5 PWM
Operating System
Windows Pro 10
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Audio
