In Line Filter - Overclock.net - An Overclocking Community
In Line Filter
post #1 of 22 (permalink) Old 10-15-2019, 02:23 PM - Thread Starter
StAndrew's Avatar
Rep: 12 (Unique: 8)
In Line Filter
Just purchased a Swiftech Apogee SKF block. With 125 micron thick microfins, I'm concerned with blockage overtime. Anyone run an in-line filter and have a recommendation? Or should I just accept that I'll have to clean the block every few months?
Asus Prime Z370, Intel 8700k @5.0Ghz, Nvidia GTX 1080 Ti, 16GB @3400 CL14, Watercooling: x2 MCP355 pumps, x1 280 on front of case, x1 360 on top of case, x1 140 on back of case, x1 240 on bottom of case
StAndrew is online now
post #2 of 22 (permalink) Old 10-15-2019, 02:31 PM
Meep
Gilles3000's Avatar
Rep: 304 (Unique: 223)
Sure, Aqua computer, Koolance and alphacool have inline filters. Never ran them, so can't recommend any.
Gilles3000 is offline
post #3 of 22 (permalink) Old 10-15-2019, 03:04 PM - Thread Starter
StAndrew's Avatar
Rep: 12 (Unique: 8)
Two concerns I have:
-Filter element size (coarse / fine). I don't want something with a coarse mesh that won't filter to the size I need filtered. Would be a waste of effort. Unfortunately, I'm having a hard time finding the specs on the filters I've found.
-Flow rate. I don't want flow rate to be hit too hard. The SFK is probably one of the top 5 most restrictive blocks on the market and its cooling should scale very well with high flow rates (high head pressure). Two MCP355's should have plenty of head but I'm not sure the impact the filter would have (especially if the filter element is very fine).
post #4 of 22 (permalink) Old 10-15-2019, 03:37 PM
Rep: 3 (Unique: 3)
Filters will block up over time too and they are consumable, meaning you will need to replace the core material (if you're able to disassemble the filter) or replace the entire filter ever so often. While I've never used a filter on a liquid-cooled PC I have used them in various other applications and IMHO over time the pleating material becomes restrictive to flow and that is something you might want to keep in mind and monitor I've seen filter pleating that looked as clean as the day it went in service become restrictive to flow and cause undue pressure increase on the pump side of the filter, for a pump motor that isn't designed to maintain backpressure this can shorten life expectancy if the pump has to work against that kind of restriction
Open Air Build
i9
ASUS ROG Strix Z390-H Gaming
MSI GEFORCE GTX1080 TI GAMING X 11G
Corsair Vengeance LPX DDR4 DRAM 3000MHz
Samsung 970 EVO
WD Blue
EVGA SuperNOVA
All PrimoChill parts (Rad 360, Pumps D5, Fittings, and Acrylic Tubing), Byskey CPU&GPU Blocks
Praxis Wet Bench
Operating System
Windows 10 Pro
Asus Predrator
Other
Thermaltake Commander F6 Fan Controller
Other
DIY Sleeved Cables
smilinjohn is offline
post #5 of 22 (permalink) Old 10-15-2019, 03:45 PM
ezveedub's Avatar
Rep: 143 (Unique: 101)
Filter will catch color pigments of opaque colored coolants. If its a basic dye colored coolant like Mayhems X1 UV or just plain coolant and no dye, then the filter will catch only debris IF any are in the system. Put the filter somewhere where you can remove it for cleaning without have to drain most of the loop. I used used Alphacool filters, but haven't put them back in lately since doing a complete soak and flush of my sustems and run X1 UV green coolant now only. It will also catch soft tubing debris/plasticizer that would come from older PrimoChill tubing. So far, not seeing that with Mayhems clear tubing.
i9 9900K
Gigabyte Aorus Master Z390
EVGA RTX2080 Gaming XC Ultra
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
i7 9700k
Gigabyte Z390 Aorus Master
Nvidia GTX1080Ti
G.Skill SNIPER 12GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
G.Skill RGB DDR4-3200
Kingston HyperX SSD
Optical Drive
LG WH10LS30 BD burner
Optical Drive
TSH663B DVD burner
Seasonic SSR-750PD Flagship Prime Series 750W Platinum
EK-Supremacy EVO - Nickel
XSPC RX360 radiator
EK WB D-BAYD5 PWM reservoir
CoolerMaster HAF 932
Operating System
Windows 10 Pro 64bit
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
Lian Li O11 Dynamic
Operating System
Windows 10
ezveedub is offline
post #6 of 22 (permalink) Old 10-16-2019, 05:51 AM
SoMBrA's Avatar
Rep: 2 (Unique: 2)
I had filter once and never again. At some point I was getting super high temperatures and random crashes while gaming... My flow was almost 0 because all the gunk that was trapped inside the filter.
As others said, you will have to change the filter or clean it quite often!
Sent from my SM-G955F using Tapatalk
SoMBrA is offline
post #7 of 22 (permalink) Old 10-16-2019, 06:36 AM - Thread Starter
StAndrew's Avatar
Rep: 12 (Unique: 8)
Yeah that is a concern. I was looking at quick disconnects but way to $$$. A ball check valve at each end is a little better but will need a ton of paper towels. I may do the ball check valve initially and run the loop for about a week then take it out but that,s a lot of investment for a temporary setup... Right now for two valves, filter, and fittings, I'm looking at $102.
No dyes, just water.
post #8 of 22 (permalink) Old 10-16-2019, 06:41 AM
Shawnb99's Avatar
Rep: 26 (Unique: 18)
Flush your radiators with Mayhems blitz part 1 and run part 2 in your whole system and you shouldn’t have to worry about blockage
The only time I’ve ever had blockage was when I didn’t properly maintain my loop
My Baby
(24 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Watercool HEATKILLER IV PRO
2x Swiftech MCP35X2 with MCP35X2 Heat Sink
2x Hardware Labs Black Ice Nemesis 360GTR
2x Hardware Labs Black Ice Nemesis 360GTS
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
2x Noctua NA-A15 PWM
24x EK Vadar F4120ER
Case Labs Magnum M8 with Pedestal
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Mr. Speakers Aeon Closed
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #9 of 22 (permalink) Old 10-16-2019, 07:07 AM
skupples's Avatar
Rep: 563 (Unique: 321)
from what I've read, folks around here like to run them for the first few days, then pull them out.
also this.
coolant is multifaceted. at the least, you need corrosion protection, bio protection, and a proper coolant will also be "wetter" (i forget the word atm, too early, head hurts, no coffee yet)
skupples is online now
post #10 of 22 (permalink) Old 10-16-2019, 07:24 AM - Thread Starter
StAndrew's Avatar
Rep: 12 (Unique: 8)
Its a well maintained loop and been running for a long time. Only run water, but still get crap in the block. Not a lot (Apogee XL2) but the new SKF has a much finer fin structure. I may go with the ball check valves and filter and run it for a few weeks, until it comes back clean...
