New Loop for 3900x + 2080TI - Overclock.net - An Overclocking Community
post #1 of 24 (permalink) Old 10-20-2019, 09:14 PM - Thread Starter
firefox2501's Avatar
Rep: 2 (Unique: 2)
Have most of my components purchased and going to be running on air for awhile but really want to get the build for my water cooling loop figured out since my evolv-x was purchased with water cooling in mind. Also I will be vertically mounting the video card.
For my last build I went with a ekwb kit and then added in the GPU to my loop with an additional radiator. While I've really been happy with my ek system I'm open to other options especially if the performance is greater for the cost.
1. What would be the best options for the 3900x heat block?
2. What would be the best option for the gpu heat block? I'll likely get a reference design like the evga black but that hasn't been purchased yet.
3. What radiator setup for my case? Was thinking 360 for the front and 240/360 for the top. Think either will be more then enough to get the heat out.
4. Best fans for the radiator, doesn't need to be RGB.
5. Soft or hard tubing? I did soft tubing on my current build but have been debating hard tubing.
My rig
(16 items)
7700k
MSI Z270 gaming M5
Zotac 1080TI FE w/ EK Block
Corsair Vengeance 16GB DDR4-3200
samsung 512gb 960 pro
SeaSonic PRIME 650W
EKWB 360rad+280rad
IN Win 303
Operating System
Windows 10 64bit Pro
Dell U2412M
Dell S2417DG
Samsung JU7100 40"
Keyboard
OCN ducky shine
Mouse
Corsair scimitar
Audio
Creative X7
Audio
Audio Technica ATH-AD900
firefox2501 is offline
post #2 of 24 (permalink) Old 10-20-2019, 11:22 PM
Ironsmack's Avatar
Rep: 55 (Unique: 51)
1. Im quite happy with my Heatkiller IV block. It cools my 2920x and 2600 with no problems. But if you have the EK block, use that for your 3900x and see if it cools it decently.
2. Ive never tried the new EK, Alphacool, Corsair, Phanteks GPU blocks. But nowadays, most CPU/GPU block (except the TR4 blocks) tend to perform close to one another with a small temp difference.
3 & 4. If you're happy with your EK rad + current fans, stick with it. Other wise, HWL for rads and NB eLoops or Darkside GT fans.
5. Personal preference.
Gaming Rig: (2) Swiffy MCP35x, UT60 + GTX 480 rad, (1) 360 HWL GTX, (1) 240 HWL GTS, HK IV 2920X @ 4.2 GHz, AsRock X399 Fatality, (2) NVidia 1080 w/ HK IV blocks, Gammix S11 Pro 1TB, Crucial MX500 1TB, 2TB Samsung F4, (4) 3 TB & (2) 5 TB Toshiba HD, CL STH10, EVGA 1300 PSU, Win 10 Pro
HTPC Rig: HK IV Stock 3700x, Asus Strix B450, D5 vario w/ EK top, 480 UT60, 240 HWL GTX, Asus 290 w/ XSPC WB 1000/1300, Crucial P1 500 GB, 12TB Ironwolf, 6TB & 8TB HGST, Enthoo Primo, EVGA G2 750, Win 10 Pro
Ironsmack is offline
post #3 of 24 (permalink) Old 10-21-2019, 07:43 AM
StAndrew's Avatar
Rep: 12 (Unique: 8)
1. TechPowerUp has, I think, one of the better lineup of CPU performance. Here is the latest CPU block lineup: https://www.techpowerup.com/review/c...r-block/6.html
2. I wouldn't sweat GPU blocks. GPU's are easy to cool and block performance is generally going to be too close to call. Pick the block that you feel looks the best IMO.
3. The issue with running radiators in series (as far as air flow) is the top radiator looses efficiency. If you run a front and top, turn your rear exhaust fan around to blow fresh air into the case for the top radiator.
4. Whats your budget on fans? Whats your preference; performance or silence?
5. Soft tubing FTW.
Asus Prime Z370, Intel 8700k @5.0Ghz, Nvidia GTX 1080 Ti, 16GB @3400 CL14, Watercooling: x2 MCP355 pumps, x1 280 on front of case, x1 360 on top of case, x1 140 on back of case, x1 240 on bottom of case
StAndrew is offline
post #4 of 24 (permalink) Old 10-21-2019, 08:02 AM
Overclocker in training
ThrashZone's Avatar
Rep: 81 (Unique: 60)
Hi,
Doubt it matters once someone has ek on the brain it's pretty senseless to suggest other products keep on keeping on
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #5 of 24 (permalink) Old 10-21-2019, 08:11 AM
StAndrew's Avatar
Rep: 12 (Unique: 8)
Quote: Originally Posted by ThrashZone View Post
Hi,
I like EK products but had seen too many warranty issues to be a fan. Swiftech for me.
I had a swiftech pump go bad and emailed them. They didnt ask for the pump back, just sent a new one within a day of initiating the claim. Put in the new pump and the CPU block was leaking. I think the water boiled in the CPU block when the pump failed and the acrylic had spider cracks. Again, within one day of emailing, a brand new block was sent out, didn't need to send the CPU block back either. While arguably they aren't at the forefront of performance or price, Swiftech gets my business 100%.
StAndrew is offline
post #6 of 24 (permalink) Old 10-21-2019, 08:58 AM
Shawnb99's Avatar
Rep: 26 (Unique: 18)
Don't forget to add a flow meter and temp sensor for the water
My Baby
(24 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Watercool HEATKILLER IV PRO
2x Swiftech MCP35X2 with MCP35X2 Heat Sink
2x Hardware Labs Black Ice Nemesis 360GTR
2x Hardware Labs Black Ice Nemesis 360GTS
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
2x Noctua NA-A15 PWM
24x EK Vadar F4120ER
Case Labs Magnum M8 with Pedestal
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Mr. Speakers Aeon Closed
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #7 of 24 (permalink) Old 10-21-2019, 10:16 AM - Thread Starter
Rep: 2 (Unique: 2)
I should clarify that I'm selling my old computer completely with the full water cooling loop so I'll be doing a fresh start, don't really care about the brand as long as the performance I get corresponds with the price paid.
EK makes it easy to price out a build and that came right around $700 from their website. I'd like to stay around that or lower unless there is a good case to bump up the specs.
I don't think either either the 3900x or 2080ti has much overclocking headroom will likely be pushing for the best stable overclock.
For noise I'm not going for a silent build but don't want this unnecessarily load, think on the EK site I put down silent overclocking.
1. I'll look into that techpowerup link but I'm liking the heatkiller block. Don't know what there best option for am4 is.
2. Once again thanks for pointing out the heatkiller option, will likely come down to cost though if performance is equal.
3. Those HWL radiators look really nice, will have to look through what they have and see what I can fit in my case.
4. What would be the best layout for the loop, guess I just stuck with series out of simplicity but my GPU sees the hotter water of my cpu.
5. Will probably stick with soft and be creative with fittings to clean up the build. best size and brand?
My rig
(16 items)
7700k
MSI Z270 gaming M5
SeaSonic PRIME 650W
EKWB 360rad+280rad
IN Win 303
Operating System
Dell U2412M
Dell S2417DG
Samsung JU7100 40"
Keyboard
OCN ducky shine
Mouse
Corsair scimitar
Audio
Creative X7
Audio
post #8 of 24 (permalink) Old 10-21-2019, 11:12 AM
I can count to potato
Fluxmaven's Avatar
Rep: 25 (Unique: 10)
The quietest fans relative to performance would be Noctua NF-A12x25. Paired with with 2x HardwareLabs GTS 360mm would be a good setup.
Loop flow order does not matter. The Liquid temps will equalize after a couple minutes of running and then temps will gradually rise and fall based on load.
Bitspower make the best fittings, but they are pricey. I especially trust them for rotary fittings. For regular straight fittings, it doesn't really matter much.
for colored tubing I like PrimoFlex Advanced LRT tubing, but it's a bit on the thicker side. Bitspower compression fittings are tight, so it can be very hard to get the compression rings on. Cheaper Barrow fittings go together easier with the LRT tubing.
For clear tubing, I like Mayhems ultra clear.
If you don't mind matte black, EPDM rubber tubing will be the easiest from a maintenance standpoint. EK ZMT is probably the most common.
There is no best size. I always run 1/2x3/4 (13/19mm) because I like the look of bigger tubes.
Darling
(19 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
MSI Ventus OC RTX 2080
GTX 1080 FE
TridentZ B-die 3200cl14
WD Black SN750 with heatsink
WD Black SN750
Micron 5100 Pro (SATA m.2)
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Keyboard
Clueboard w/ 67g Zealios
Mouse
Glorious Model O
Mousepad
Tekmat AR-15 gun cleaning mat
Audio
JBL 306 MKII studio montors
Audio
Focusrite 2i4 Gen2
Audio
Monolith 10" THX sub
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
Basic Geil 2133 4x2GB
WD Blue 3D m.2
Corsair AX760
Custom loop with external MO-RA3
InWin D-Frame Mini
i7 6700
MSI h270 tomahawk arctic
EVGA GTX 960 FTW 4GB
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig C7
Maingear Shift
Fluxmaven is offline
post #9 of 24 (permalink) Old 10-21-2019, 11:31 AM
StAndrew's Avatar
Rep: 12 (Unique: 8)
What HWL series? Make sure you get a fan with high enough static pressure, some of the HWL radiators have some pretty high fins per inch.
StAndrew is offline
post #10 of 24 (permalink) Old 10-21-2019, 05:20 PM
Ironsmack's Avatar
Except the SR2 series. At 9 FPI, they're optimized for lower RPM fans.
