Help me with the drain port please. - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 10-27-2019, 07:44 AM - Thread Starter
sblantipodi's Avatar
Rep: 29 (Unique: 27)
Guys,
I am trying to build a rig like that, with a LianLi PC O11 Dynamic, two 360mm rads and a distro plate.
I want to do something like this but with soft tubing.
Where can I put the drain port? Any idea?
sblantipodi is offline
post #2 of 6 (permalink) Old 10-27-2019, 08:33 AM
Overclocker in training
ThrashZone's Avatar
Rep: 92 (Unique: 67)
Hi,
Only place i see it going and doing something if you lay the case down on it's glass door side is on the bottom rad
Otherwise you'd need to tap another hole on the bottom of the rad for a true gravity drain.
Multi port rad would of came in handy here.
Name:	boom drain.PNG
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #3 of 6 (permalink) Old 10-27-2019, 08:42 AM - Thread Starter
Quote: Originally Posted by ThrashZone View Post
Hi,
if the rad lays down to the case, how can I fit a drain port on the rad? any idea? thanks for the answer
post #4 of 6 (permalink) Old 10-27-2019, 08:52 AM
ThrashZone's Avatar
Hi,
Just have to use a T valve with a shut off valve somehow.
It would look better to just get another rad for the bottom with ports on both sides of the rad
http://www.xs-pc.com/radiators-ex-se...iport-radiator
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #5 of 6 (permalink) Old 10-27-2019, 08:53 AM - Thread Starter
Hi,
thanks!!!!!!!!!!!!!
post #6 of 6 (permalink) Old 10-27-2019, 08:59 AM
ThrashZone's Avatar
Hi,
No problem
Don't forget extra plugs
That one I linked to looks like it has 6 ports on it
Just need to drill a hole through the bottom of the case and add a L fitting and a shutoff valve.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
