how much radiator space. - Overclock.net - An Overclocking Community
post #1 of 12 (permalink) Old 11-07-2019, 09:32 AM - Thread Starter
mfdoom7's Avatar
Rep: 13 (Unique: 11)
Currently i have alpha cool st30 280mm and 360mm and 9900k + 1080ti both oc. i have spare 240mm radiator EKWB coolstream SE 240 i was wondering if i gain more cooling power. i run my fans @ 700 rpm 3x silent wings 3 and 2x140mm alphacool stock fans. do i gain more than 3c cooling or less ? gpu temp is not problem its the cpu.
My System
(19 items)
i7 8700k
Asrock Extreme4
GeForce® GTX 1080 Ti Gaming OC 11G
16gb 2400 cl16 Crucial Ballistix
WD wd10ezex
WD wd10ezrz
Samsung evo 840 250Gb
Samsung evo 850 500Gb
Seasonic G Series G-650
Alphacool eisbaer 280
Corsair Carbide Air 540
Operating System
Windows 8.1
DELL U2515H
Keyboard
Compaq GYUR86SK PS/2 Multimedia Keyboard SK-2860 with 8 extra buttons
Mouse
Logitech G402
Mouse
a4tech gaming x7
Audio
logitech x-530 + JBL GT series gt5-1204br and Pioneer GM-D9601
Other
bitfenix recon
mfdoom7 is offline
post #2 of 12 (permalink) Old 11-07-2019, 09:50 AM
Overclocker in training
ThrashZone's Avatar
Rep: 113 (Unique: 77)
Hi,
Probably not but won't really hurt anything either
Little more work for the pump but se240 isn't restrictive either.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is online now
post #3 of 12 (permalink) Old 11-07-2019, 10:07 AM
StAndrew's Avatar
Rep: 13 (Unique: 9)
Cooling from more radiators gives diminishing returns. Depending on how your case is setup, using exhaust air from one radiator to cool another (ie if one radiator is intake and the other as exhaust, you lose efficiency.
My recommendation is, if you have the extra radiator, put it in on your next water change. If you don't, don't spend the money unless its burning a hole in your pocket. The extra radiator will help you run fans at a lower speed.
My setup is a 360, 280, 240, and 120; literally everywhere that can mount a radiator has a radiator. All radiators drawing air in so they all are running at close to maximum efficiency and a 250mm fan mounted on the side panel runs as exhaust. I can run my fans around 800RPM's so that only my pump noise is readily noticeable and cool an 8700k and 1080ti rather well. CPU reaches 50s - 60s when gaming and the GPU rarely goes over 32C; generally not much more than 7-10* over ambient.
Asus Prime Z370, Intel 8700k @5.0Ghz, Nvidia GTX 1080 Ti, 16GB @3400 CL14, Watercooling: x2 MCP355 pumps, x1 280 on front of case, x1 360 on top of case, x1 140 on back of case, x1 240 on bottom of case
StAndrew is offline
post #4 of 12 (permalink) Old 11-07-2019, 11:08 AM
charliehorse55's Avatar
Rep: 778 (Unique: 512)
Doing a rough calculation in my head, I don't think you'd get a 3C drop. Perhaps 0-1.5C. The limiting factor here isn't as much the water temperature, but the contact between the CPU die and the waterblock. Check out lapping, or potentially even going direct die. Those techniques can often give 5C+ drops.
charliehorse55 is offline
post #5 of 12 (permalink) Old 11-07-2019, 11:10 AM - Thread Starter
mfdoom7's Avatar
all radiator fans take air from outside. so its good as it gets
My System
(19 items)
i7 8700k
Asrock Extreme4
WD wd10ezex
WD wd10ezrz
Operating System
Windows 8.1
DELL U2515H
Keyboard
Mouse
Logitech G402
Mouse
a4tech gaming x7
Audio
Other
bitfenix recon
mfdoom7 is offline
post #6 of 12 (permalink) Old 11-07-2019, 11:24 AM - Thread Starter
mfdoom7's Avatar
but it does make water temp better ?
My System
(19 items)
i7 8700k
Asrock Extreme4
WD wd10ezex
WD wd10ezrz
Operating System
Windows 8.1
DELL U2515H
Keyboard
Mouse
Logitech G402
Mouse
a4tech gaming x7
Audio
Other
bitfenix recon
mfdoom7 is offline
post #7 of 12 (permalink) Old 11-07-2019, 11:26 AM
TeslaHUN's Avatar
Rep: 20 (Unique: 18)
According to this post : https://www.overclock.net/forum/25429247-post2364.html
Radiator surface area is never enough. He will win more than 0-1,5C for sure.
TeslaHUN is offline
post #8 of 12 (permalink) Old 11-07-2019, 11:42 AM
ThrashZone's Avatar
Hi,
Water temp will likely average out the same.
Temp spikes might be a hair less with more rad space but about it on low fan speeds.
Higher rpm speeds might show more advantage.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #9 of 12 (permalink) Old 11-07-2019, 12:12 PM
StAndrew's Avatar
Rep: 13 (Unique: 9)
Yeah, there is a point where you have enough radiators that the water temp normalizes with ambient air temps before circulating back to your block and your CPU temps are limited by the waterblock efficiency only.
OP, do your temps scale well with fan speeds? If so, another radiator would help. If not, another radiator will allow lower fan speeds but won't give much more in terms of overall performance.
StAndrew is offline
post #10 of 12 (permalink) Old 11-07-2019, 01:52 PM
Yes. With your rig, I would estimate the water-air delta to be around 8C with the 700rpm fans. Adding a 240 rad would increase the total radiator surface area by 30%, lowering your water temperatures to 8/1.3 = ~6C. So I would expect a 2C drop. Assuming all radiators are intaking cold air from outside the case.
(I did the math this time)
