can you upgrade this kit? - Overclock.net - An Overclocking Community
post #1 of 13 (permalink) Old 11-10-2019, 07:42 AM - Thread Starter
Legion123's Avatar
Rep: 3 (Unique: 3)
Guys
i would like to build my first water loop (got AIO atm) my pc is noisy (50db) and i need something quieter. i have a carbide air 540 case, rtx 2080ti and 7700 i7. i never done water look so was looking at this kit since i dont know what parts to pick:
https://www.overclockers.co.uk/ek-wa...wc-99d-ek.html
my question is can this kit be upgraded? can i add water block for the card without issues? as in will this pump be sufficient? i also wanted to add 1 more rad (280) again - can i ?
Legion123 is offline
post #2 of 13 (permalink) Old 11-10-2019, 08:10 AM
Overclocker in training
ThrashZone's Avatar
Rep: 90 (Unique: 65)
Hi,
Yes you could add another rad if you want too D5 pump is good rad in kit is okay PE series.
You shouldn't settle on a ek kit though
Heatkiller is a hell of a lot better quality and price shouldn't be all that different.
Not much to a loop
D5 pump/ reservoir and a mount.
CPU block
6- straight barb fitting which you should use (3/8-5/8"= 10-15mm) not 10-13mm= 3/8-1/2" which is in the kit.
Radiator.
https://shop.watercool.de/epages/Wat...leK/Categories
Post what case you have and maybe some images of what you're working with now.
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #3 of 13 (permalink) Old 11-10-2019, 09:46 AM - Thread Starter
Legion123's Avatar
Rep: 3 (Unique: 3)
legion123
i have carbide air 540
are you talking about this kit?
https://www.aquatuning.co.uk/water-c...te-kit?c=23067
btw rad cant be more than 300mm thick because of the card - look at the pic and the gap
Name:	2019-11-10 17.26.15.jpg
post #4 of 13 (permalink) Old 11-11-2019, 10:27 AM
ThrashZone's Avatar
Hi,
No
I meant most the items are on the link I posted
Basic heatkiller D5 reservoir and short stand
https://shop.watercool.de/epages/Wat...Products/30203
https://shop.watercool.de/epages/Wat...Products/30230
D5 vario pump
https://shop.watercool.de/epages/Wat...Products/30047
Heatkiller 4 pro Pure copper cpu Intel water block
https://shop.watercool.de/epages/Wat...Products/18002
Straight barb fittings Barrow need 6 minimum
https://shop.watercool.de/epages/Wat...Products/50318
Rest you can get from mayhems UK
Fitting here too
https://www.mayhems.net/collections/...ng-g1-4-chrome
Soft tubing
https://www.mayhems.net/collections/...10-16mm-tubing
Mayhems Biocide and inhibitor use what ever distilled water you have locally for clear fluid option they also have non staining dyes
https://www.mayhems.net/collections/...s-biocide-15ml
https://www.mayhems.net/collections/...inhibitor-15ml
https://www.mayhems.net/collections/non-staining-dyes
2080ti water blocks
https://shop.watercool.de/epages/Wat...TX%202080Ti%22
Radiators
Hardware labs GTS series 360mm is under 30mm thick
http://hardwarelabs.com/nemesis/gts/360gts/
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #5 of 13 (permalink) Old 11-11-2019, 10:54 AM - Thread Starter
Legion123's Avatar
Rep: 3 (Unique: 3)
thats quite a list - thanks
any reason you recommending heatkiller? i have actually looked at some alphacool stuff and it seemed good? especially the 5" reservoir
post #6 of 13 (permalink) Old 11-11-2019, 11:07 AM
ThrashZone's Avatar
Hi,
I too have a alphacool reservoir base with a D5 vario pump in it
It's fine too you showed it in the other kit
If you remove the restrictive parts it's fine little tube for sprinkler effect and it also has a round item with holes in it remove those and it's fine.
Heatkiller is top of the line though you'll be happier with it nothing restrictive to remove
It does have other mounting options I just posted to the short stand there is also a mount to fan screws like the other one has if that is preferred
Fan wise be-quiet is highly recommended around here forgot that item
https://www.bequiet.com/en/casefans
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #7 of 13 (permalink) Old 11-11-2019, 02:08 PM
Kronos8's Avatar
Rep: 5 (Unique: 4)
Before buying any kit from any vendor, I would strongly suggest to examine your case and determine the dimensions of the rads your case can fit. Just by looking at your picture, I notice you can only have a 240 (2 x 120) at the top, probably 30mm thick max and maybe a 360 (3 x 120) at the front. The thickness of the rad at the front is something you should measure and determine. You need 25mm for the fans and 30mm for the rad. Do you have that space? For the exact dimensions of any rad, I would go to vendors site and have a look. If you don't have that space, you may have to consider a small modification to your case, placing the rad out of the case or even a new case. And keep in mind that, just by looking at your picture, it may conflict with top radiator, if you want to use a second in the future. And of course, you have to decide where you will place the reservoir and if you have the space needed in your case. Measure and plan before you buy. I hope I helped you.
Kronos_8_PC
(25 items)
6770K
ASUS Z170 Deluxe
MSI GTX 1080Ti Armor
G.Skill 4x16 GB at 3200 MHz
Samsung 950 Pro NVMe 256GB
Crucial MX200 250GB
Optical Drive
None yet
SeaSonic Snow Silent 1050W
XSPC D5 VARIO pump
EK-Supremacy EVO (Original CSQ) CPU Water Block
Phobya G-Changer 360 V.2 Radiator
EK-Vardar F4-120 (2200RPM) x 3 fans
Phobya G-Silent 12 Slim Edition 1800RPM x 3 fans
EK-D5 X-RES 140 (Original CSQ) Acetal
EK VGA Supremacy Universal Waterblock
Koolance MVR-100 Water Block
COOLERMASTER HAF X BLACK
Operating System
None yet
LG M2752D
Keyboard
MICROSOFT WIRELESS DESKTOP 3050
Mouse
Mouse
None yet
Audio
None yet
Other
ENERGENIE EG-UPS-033 720W
Other
SCYTHE KM08-BK KAZE MASTER FLAT II FAN CONTROLLER BLACK
Kronos8 is offline
post #8 of 13 (permalink) Old 11-12-2019, 03:39 AM - Thread Starter
Legion123's Avatar
Rep: 3 (Unique: 3)
Quote: Originally Posted by ThrashZone View Post
Hi,
yeah i already bought these - they arriving tomorrow, was going to replace my case fans but if i buy water loop ill use them on the rad
post #9 of 13 (permalink) Old 11-12-2019, 03:41 AM - Thread Starter
Legion123's Avatar
Rep: 3 (Unique: 3)
yeah already done - thanks in my second post i mentioned rad cant be more than 30mm because of the card. Carbide air will fit 280 top (which is what i have right now) and 360 front - reservoir needs to be in the back compartment but im just wondering whether i should go for the 5" bay reservoir instead...
post #10 of 13 (permalink) Old 11-12-2019, 07:17 AM
ThrashZone's Avatar
Hi,
No they tend to leak
I'd stick to conventional tube reservoir heatkiller or alphacool both are well manufactured.
Get a taller one if in a different location
I selected the heatkiller basic because it would likely fit above the graphics card if not below it but you would need the fan mount not the short stand
The alphacool comes with both mounting options already you just use one or the other.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
