My second loop, high temperature problem - Overclock.net - An Overclocking Community
post #1 of 50 (permalink) Old 11-14-2019, 11:36 AM - Thread Starter
LeoYunta's Avatar
Rep: 10 (Unique: 10)
Hi guys,
I just finished my second loop, but this time I wanted to change the route of my tubes, but I got really high temperature idle (50/60) instead of 30 in my first loop.
I use 2x360mm radiator, and push configuration on em.
I think my order is bad, but I just want a confirmation before I do it again.
PUMP > Radiator > GPU > CPU > radiator.
I think I should : PUMP > CPU > radiator > GPU > radiator
if you think the order doesn't change anything then I think it's cause of my pump, the outlet is doing an "S" maybe it should be straight to have a better flow ?
Thank you guys
LeoYunta is offline
post #2 of 50 (permalink) Old 11-14-2019, 11:46 AM
Invalid Media
J7SC's Avatar
Rep: 42 (Unique: 21)
Quote: Originally Posted by LeoYunta View Post
Hi guys,
Thank you guys
I presume your reservoir is before and above the pump... so (Res) > PUMP > CPU > radiator > GPU > radiator is what I usually use with good temps. Also check if ALL the air is out (especially in GPU crevasses) as that can easily affect temps. Finally, if you have a second pump available, I would mount that between 1st rad and GPU.
J7SC is offline
post #3 of 50 (permalink) Old 11-14-2019, 11:46 AM
Overclocker in training
ThrashZone's Avatar
Rep: 108 (Unique: 77)
Hi,
Need a picture to see where the pump actually is
If on the bottom usually one would go
Pump outlet/ gpu/ cpu/ rad/ rad/ reservoir.
Water equalizes ultimately.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #4 of 50 (permalink) Old 11-14-2019, 11:52 AM - Thread Starter
LeoYunta's Avatar
Thanks for you answer guys, sorry for the mess about the cable
Here you go for the picture
LeoYunta is offline
post #5 of 50 (permalink) Old 11-14-2019, 11:54 AM
skupples's Avatar
Rep: 624 (Unique: 342)
order doesn't mean much, aside from reservoir before pump, and less 90s = more flow, and 90s directly off of pump = neutered flow.
i'd say stuck air, or biffed mount.
skupples is offline
post #6 of 50 (permalink) Old 11-14-2019, 11:56 AM - Thread Starter
LeoYunta's Avatar
Well actually I think I know why if anything seems normal, I actually inverted the in and out on the radiator above, I mean I know there is now inlet and outlet, but see the picture, to have a better look I inverted it so it's probably ******** ?
LeoYunta is offline
post #7 of 50 (permalink) Old 11-14-2019, 12:00 PM
skupples's Avatar
which ports you use on a raidator doesn't really matter, unless its x-flow style.
the only * I can think of with that, is that any horizontally mounted radiators would benefit from water being delivered to the top port, as the radiator would be easier to fill/bleed. gravity is your friend.
skupples is offline
post #8 of 50 (permalink) Old 11-14-2019, 12:02 PM
ThrashZone's Avatar
Hi,
Which gpu is that ?
Are you sure you're going into the gpu's inlet and not the outlet ?
Looks like you have the cpu inlet right.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #9 of 50 (permalink) Old 11-14-2019, 12:04 PM
ThrashZone's Avatar
Hi,
Yep 1080ti
Switch the gpu ports dude inlet is on the left not the right
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #10 of 50 (permalink) Old 11-14-2019, 12:06 PM
Shawnb99's Avatar
Rep: 43 (Unique: 29)
What else was changed when you rerouted the tubing? Order is meaningless, the water temps will even out in the end no matter the order.
Look at what else was changed. Did you remount the CPU block, could be that. Most radiators shouldn't have in/out ports, it shouldn't matter. The CPU block does though, maybe that's backwards. I'd check for a bad CPU mount or a switch of the CPU block ports. How many 90 degree bends are new?
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
