Peltier Cooling Water in Loop - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 11-18-2019, 01:28 AM - Thread Starter
jcrandall623's Avatar
Rep: 5 (Unique: 5)
Hello OCN,
I'm wondering if anyone has tried to use Peltier to cool the water in the loop. The concept is the rad would cool to ambient temps, and the Peltier would cool it below ambient.
Would this even produce enough of a temp change that would affect performance or even require less rads to achieve similar performance?
The science side of me makes me think that it would just even out, but what made me think that it would achieve different results is that the cold being directed to the water temps and the heat from Peltier being dissipated into the ambient temp would direct the colder temps to where we want it.
Regardless of whether you've tried it or not, I would like to know people's thoughts.
jcrandall623 is offline
post #2 of 4 (permalink) Old 11-18-2019, 01:30 AM
The last VRM burner
Rep: 45 (Unique: 27)
Yes https://www.overclock.net/forum/62-p...build-log.html
PC for all
(21 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Iris Pro 6200
F3-2400C11D-16GAB Samsung Rev. Q
Corsair MP510
Samsung Evo 860
Seasonic Focus Plus 750W
Artcic Liquid Freezer II 360mm
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent + 1.6x6mm o-rings
Mouse
SteelSeries Rival 600
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #3 of 4 (permalink) Old 11-19-2019, 05:48 PM
Ashcroft's Avatar
Rep: 92 (Unique: 72)
Peltiers suck. Don't waste your money and time.
For a system that combines radiators and peltiers the rads would only serve to stop the Peltier from being able to achieve anything.
A cooling loop doesn't really have a hot and cold side. The whole loop warms up until the rads are warm enough to dissipate the wattage the system is generating. Its always natural to assume that hot water comes out of the water blocks and ambient temp water comes out of the radiators but that's just not how it works.
Ashcroft is offline
post #4 of 4 (permalink) Old 11-19-2019, 10:22 PM - Thread Starter
Rep: 5 (Unique: 5)
Quote: Originally Posted by BroadPwns View Post
Hi, thanks for the fast reply, but that's a bit more extreme than I was thinking. Interesting build though.
Hmm, ok. I do think the rads would OP the peltier. I was thinking by separating the hot of peltier from the waterloop, i cant create some net gain on the water side, but yea, it's more of a macro system that micro things won't affect.
